Re: CellEditors in M3 [message #113950 is a reply to message #113844] |
Fri, 28 November 2008 08:05  |
Originally posted by: rherrmann.innoopract.com
Igor,
this was a known issue and is fixed meanwhile. See here for more
information:
255963: [Table] TableItem#getBounds() returns wrong x and y
values if scrolling
https://bugs.eclipse.org/bugs/show_bug.cgi?id=255963
RĂ¼diger
Igor Pavlenko wrote:
> I have a question to developers team.
> I found a problem with CellEditors in M3.
> If we have a TableViewer with cell editors inside and if there are a lot
> of rows in TableViewer and the vertical scrollbar is visible and it is
> scrolled down then the location of active CellEditor is incorrect. It
> seems that the location is calculated without information about vertical
> scroll position.
> I can create a bug, but it is in M3 version. So, it is possible that
> this bug is well-known. Should I create a bug?
> And I also have to make a desision if it is possible to use CellEditors
> in our application. It is possible if this bug will be fixed in M5. Is
> it possible?
> Thank you, Igor
FUDForum. Page generated in 0.01974 seconds
