Home » Eclipse Projects » Remote Application Platform (RAP) » ToolItem text not visible on first login, adjust after refresh or second login to applicatoin.(widget not displayed correctly)
ToolItem text not visible on first login, adjust after refresh or second login to applicatoin. [message #869878] |
Fri, 04 May 2012 15:48 |
George R Malary Messages: 36 Registered: March 2012 Location: New Jersey |
Member |
I think this may be a know limitation of determining sizes for widgets, but I'm not sure.
1) We have a perspective Toolbar which shows when we login to application.
When we launch application, and login for the first time, the ToolItem is displayed, but is cutting off text. (see attached image: ToolItem-CutsOffText.png)If you see the page load, you can see it shows the correct text, and the resizes the ToolItem, cutting off text.
If you refresh the page, or logout of the application, and log back in, the ToolItem is displayed properly. (see attached image: ToolItem-ShowsCorrectText.png).
Is there a way around this behavior? Can I layout() the Toolbar or pack() the items after load? I have tried that unsuccessfully.
2) On a more general note, I see widgets move around occassionally when text is change in them, or when localization causes widgets to have to grow. Are there any suggestions to limit the jittering of objects, and best practices for handling resizing of objects? I try to solve these issues by layout() and pack() of the containers, but possibly there is a better practice.
Re: ToolItem text not visible on first login, adjust after refresh or second login to applicatoin. [message #870326 is a reply to message #869878] |
Mon, 07 May 2012 16:13 |
Ivan Furnadjiev Messages: 2426 Registered: July 2009 Location: Sofia, Bulgaria |
Hi George,
the ToolItem issue is probably related to the text size determination in
the first run. Could you open a bugzilla with a snippet to reproduce it?
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Current Time: Thu Apr 25 08:16:00 GMT 2024
Powered by FUDForum. Page generated in 0.03682 seconds
