Home » Archived » M2M (model-to-model transformation) » [QVTO] Large script - editor slow
[QVTO] Large script - editor slow [message #869583] Thu, 03 May 2012 12:15 Go to next message
I have a large transformation script and the qvto editor becomes
extremely slow. (I'm not sure yet if this is also a problem of using
custom types which the editor doesn't know). Anyway I can edit fragments
while strategically commenting out other areas, but when I enable all
qvto code, the editor chokes on the script (CPU busy for many minutes).
I may have issues in the script, but is there a way to split scripts
into smaller fragments?
TIA
Marius
Re: [QVTO] Large script - editor slow [message #869585 is a reply to message #869583] Thu, 03 May 2012 12:21 Go to previous messageGo to next message
What's even worse: when the editor is chewing on the script, I can
hardly use Eclipse anymore. If I open any other(!) editor window,
Eclipse hangs completely and the CPU is idle. I then need to kill
Eclipse and start over. Not good.
Marius
Re: [QVTO] Large script - editor slow [message #869742 is a reply to message #869583] Fri, 04 May 2012 03:19 Go to previous messageGo to next message
Turns out this was indeed the problem. In my workspace I have the
referenced Ecore models, but the qvt editor doesn't know about them
(rather, the models aren't registered in the global EMF registry). So I
had written a small helper plugin which loads a list of .ecore models
into the global EMF registry on startup. However, when such a model
references custom types, the qvto chokes badly on each reference trying
to resolve that custom type. I'm now only loading the XSD models with
that helper, and deploy the generated ecore models as plugins into my
dropins/ folder. Now the model is complete and the qvt editor is happy
(and so am I.)
Marius
Re: [QVTO] Large script - editor slow [message #869820 is a reply to message #869742] Fri, 04 May 2012 08:02 Go to previous messageGo to next message
I suspect that you have side stepped the problem. EMF works quite well
with dynamic models; a bit slower but not dramatically so. Perhaps your
problem was that you were repeatedly loading the model again and again.
Using a single Java model may just have avoided the repetition.
Ed Willink
> (and so am I.)
> Regards
> Marius
Re: [QVTO] Large script - editor slow [message #869841 is a reply to message #869820] Fri, 04 May 2012 09:35 Go to previous message
Perhaps... anyway my (hopefully final) approach to this is to simply
start my Ecore model in a runtime workbench, add my XSD model there also
using my special startup-loader plugin and edit the QVT there in a
project that's linked to my original workspace. That way I don't need to
re-deploy and restart Eclipse, I merely need to restart the runtime
workbench which is much more lightweight.
Everything works great now, and I really love QVT. Hopefully development
will continue (I'm afraid I won't be able to give much back... well,
perhaps a bug report here and there).
Marius
Previous Topic:Model contains "definitions", Ecore specifies "Definition"
Next Topic:Connecting RP to OM2M
Current Time: Thu Jun 19 10:06:23 EDT 2025
Powered by FUDForum. Page generated in 0.05328 seconds
