Re: Unable to run Chart Report with CrossTabs using BIRT 2.6.2 [message #869883 is a reply to message #869838] |
Fri, 04 May 2012 15:49 |
The issue may be that the custom class is not being located or one of
the classes that it depends on.
Jason
On 5/4/2012 9:31 AM, Hariharan Ramalingam wrote:
> Jason,
> Websphere logs does not display any errors either.
> The log has only the following. [5/2/12 15:47:52:634 EDT] 00000055
> ServletWrappe I SRVE0242I: [Maistro] [/maistroReport] [ViewerServlet]:
> Initialization successful.
> [5/2/12 15:48:12:177 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/layout/FramesetFragment.jsp]:
> [5/2/12 15:48:12:259 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/control/ToolbarFragment.jsp]:
> [5/2/12 15:48:12:338 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/layout/ReportFragment.jsp]:
> [5/2/12 15:48:12:402 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/layout/SidebarFragment.jsp]:
> [5/2/12 15:48:12:495 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/DialogContainerFragment.jsp]:
> [5/2/12 15:48:12:574 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/SimpleExportDataDialogFragment.jsp]:
> [5/2/12 15:48:12:656 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/ExceptionDialogFragment.jsp]:
> [5/2/12 15:48:12:872 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/ParameterDialogFragment.jsp]:
> [5/2/12 15:48:13:261 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/parameter/HiddenParameterFragment.jsp]:
> [5/2/12 15:48:13:364 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/ExportReportDialogFragment.jsp]:
> [5/2/12 15:48:13:442 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/PrintReportDialogFragment.jsp]:
> [5/2/12 15:48:13:533 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/PrintReportServerDialogFragment.jsp]:
> [5/2/12 15:48:14:990 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/dialog/ConfirmationDialogFragment.jsp]:
> [5/2/12 15:48:15:078 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/layout/ReportContentFragment.jsp]:
> [5/2/12 15:48:15:175 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/control/NavigationbarFragment.jsp]:
> [5/2/12 15:48:15:273 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/layout/DocumentFragment.jsp]:
> [5/2/12 15:48:15:336 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport]
> [/webcontent/birt/pages/control/ProgressBarFragment.jsp]: Initialization
> successful.
> [5/2/12 15:48:15:401 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/control/TocFragment.jsp]:
> [5/2/12 15:48:17:993 EDT] 00000055 ServletWrappe I SRVE0242I: [Maistro]
> [/maistroReport] [/webcontent/birt/pages/common/processing.jsp]:
> We have a custom adapter extending DataSourceEventAdapter and we have
> logging statements in beforeOpen method implementation. It doesn't seem
> to be invoking the beforeOpen method.
> NOTE: Other Reports that has no charts in it works fine as expected
Re: Unable to run Chart Report with CrossTabs using BIRT 2.6.2 [message #871686 is a reply to message #871289] |
Mon, 14 May 2012 17:15 |
Hari,
Can you open a bugzilla entry for this and attaching that trace?
Jason
On 5/11/2012 2:56 PM, Hariharan Ramalingam wrote:
> Environment seems to be the same when compared to the reported Bug #345738. Our development environment is Windows and test environment is UNIX with JDK version is 1.5. We are having problems only in the UNIX environment. We are not sure if our issue is exactly same, as we don't have the stack trace.
> We tried running the report with log directory specified in the web.xml. Is there any other place where we need to specify the log directory and try ?
> Also, we enabled class loader tracing to get a clue. There is an instance of classcastexception in the trace. The trace file is attached.
> Please see if you would be able to suggest any solution based on the trace log.
> Hari
FUDForum. Page generated in 0.04759 seconds
