Trying to load UTP 1.1 (xmi from OMG) [message #868821] |
Wed, 02 May 2012 15:36 |
I am trying to generate an ecore file from the xmi provided here:
OMG org site, spec/UTP/1.1/ (xmi file, I cannot post urls)
in order to follow the complete standard performing transformations with QVT.
I am reciving an error, and even I can not see the content of the file with the "Sample Reflective Ecore Model Editor"
Errors:
* Package with uri ':// (omg site) /spec/XMI/2.1' not found.
* Class 'Documentation' is not found or is abstract.
* Package with uri ':/ (omg site) /spec/UML/20090901' not found.
* Class 'Profile' is not found or is abstract.
Has anyone tried that?
[Updated on: Wed, 02 May 2012 15:37] Report message to a moderator
Re: Trying to load UTP 1.1 (xmi from OMG) [message #868841 is a reply to message #868837] |
Wed, 02 May 2012 16:09 |
I am using the last version of Eclipse (Indigo)
Could you try to load the file?
In order to try to load the model with the UML Model Editor as you suggested, I have changed the extension xmi to uml, and I could load it, but it is not what I expected, I mean: this is not being recognized as a UML Profile (see the attached img)
I can imagine that there is a problem with the definition of the xmi. According with its content, it seems to have been generated with MagicDraw. Do you know if there is any particular issue about the xmi generated with this tool.
What would you suggest me in order to work with the UML Testing Profile?
1.- use the standard implementation provided by OMG
2.- develop the profile from the scratch, with the UML 2 Tools or Papyrus
3.- ???
Thank you for your quickly response!
Re: Trying to load UTP 1.1 (xmi from OMG) [message #869396 is a reply to message #868869] |
Thu, 03 May 2012 10:42 |
I am not being able to do that, so it seems that I should create the UML testing profile for Eclipse from the scratch (I cannot believe that it has to be done by this way being a standard ... I feel like I am not understanding something....)
Thank you anyway!
Re: Trying to load UTP 1.1 (xmi from OMG) [message #869460 is a reply to message #868869] |
Thu, 03 May 2012 12:40 |
the file in uml 2.3 is provided by omg ... I did not choose to use it
I tried what you suggested but it did not work, or perhaps, I do not know how to do that ...
I've changed a couple of URIs references, ... what else should I do?
thank you so much!!
FUDForum. Page generated in 0.03776 seconds
