Plugins IU directly in category.xml [message #868734] |
Wed, 02 May 2012 13:14 |
Hi all,
I want to put directly plugins in my category.xml (I don't want to use
features for those plugins, that I don't own, I just want to mirror
them, they are available in Orbit without feature).
I know p2 can publish directly plugins. I noticed category.xml editor
does not provide entry for Plugins,
So, simple question:
Is there a way (independently of category editor) to add plugins in
category.xml ?
The goal, ultimately, would be to support it also in Tycho.
Thanks in advance.
Mickael
Re: Plugins IU directly in category.xml [message #868787 is a reply to message #868768] |
Wed, 02 May 2012 14:35 |
>> I think it's also possible to list units directly. But I'm not sure
>> if/where it's documented properly. I discovered the query feature by
>> looking at the source code.
> Will have a look at source then.
I found the UI part in org.eclipse.pde.internal.core.idite, but nothing
related to Queries or bundles as IU.
Which class gave you hints for queries?
Re: Plugins IU directly in category.xml [message #868843 is a reply to message #868787] |
Wed, 02 May 2012 16:09 |
Found org.eclipse.equinox.internal.p2.updatesite package.
The <iu id="bundle.name"> element looks promising, but it looks like
CategoryPublisher application only works on existing repository and is
only good at organizing an already existing repo.
What I want is to create a repo and publish some plugins in it, without
making them part of a feature.
But I also found that Tycho seems to use its own implementation, based
on ContextValue "TychoConstants.CTX_PUBLISHED_ROOT_IUS", use by
AssembleRepositoryMojo, to invoke MirrorAppicaiton and
MirrorApplicationServiceImpl....
Both Headless command and Tycho Mojo rely on the CategoryXMLAction and
SiteXMLAction for that. SiteXMLAction seems to perform some cool stuff
for <iu> but I can't get it to work.
Any help on its usage would be very welcome.
Re: Plugins IU directly in category.xml [message #869420 is a reply to message #868843] |
Thu, 03 May 2012 11:24 |
Hi Mickael,
Am 02.05.2012 18:09, schrieb Mickael Istria:
That's how it works. The p2 category Ant task (and application) takes
any existing p2 repository and adds categories to it (depending on a
given category.xml).
So you don't need categories for this. You can simply mirror or publish
any plug-in to any repository. Features are really just a way to group
bundles. My understanding was that you wanted to have categories as a
way to use "groups" of bundles in a Target Platform (or so).
-Gunnar
Gunnar Wagenknecht
gunnar@xxxxxxxx
http://wagenknecht.org/
Re: Plugins IU directly in category.xml [message #870771 is a reply to message #869420] |
Wed, 09 May 2012 15:15 |
> bundles.
But there is no way to do it by editing a category.xml file, isn't
there? I'll need to use p2 tasks or scripts (which I tried to avoid as
much as possible in our Tycho-based build process).
Sorry if I was not clear. What I want is to give a category.xml
containing a bundle that is not part of a feature to Tycho and get as
result a repository which contain the IU for this bundle.
Mickael Istria
JBoss, by Red Hat
My blog: http://mickaelistria.wordpress.com
My Tweets: http://twitter.com/mickaelistria
FUDForum. Page generated in 0.03679 seconds
