Home » Modeling » TMF (Xtext) » Null pointer when serializing cross references
Null pointer when serializing cross references [message #868097] Tue, 01 May 2012 16:41 Go to next message
Andrew Gacek is currently offline Andrew GacekFriend
Member
I have a simple expression language with cross references. When I try to serialize it, I get a null pointer exception (see bottom). It appears to be something related to scoping, but I don't know what. My language does not yet have any interesting scope: everything is global at the file level. Here is what I have in my mwe2 config:
// scoping and exporting API
fragment = scoping.ImportURIScopingFragment {}
fragment = exporting.SimpleNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
Is there something I'm doing wrong which is triggering this error?
Andrew
	at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider$2.iterator(SimpleLocalScopeProvider.java:71)
	at com.google.common.collect.Iterables$8.iterator(Iterables.java:687)
	at com.google.common.collect.Iterables$6.iterator(Iterables.java:582)
	at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.setExportedObjects(MultimapBasedSelectable.java:97)
	at org.eclipse.xtext.scoping.impl.MultimapBasedSelectable.<init>(MultimapBasedSelectable.java:36)
	at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider.getAllDescriptions(SimpleLocalScopeProvider.java:75)
	at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider$1.get(SimpleLocalScopeProvider.java:57)
	at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider$1.get(SimpleLocalScopeProvider.java:1)
	at org.eclipse.xtext.util.OnChangeEvictingCache.get(OnChangeEvictingCache.java:67)
	at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider.getScope(SimpleLocalScopeProvider.java:54)
	at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.delegateGetScope(AbstractDeclarativeScopeProvider.java:72)
	at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.getScope(AbstractDeclarativeScopeProvider.java:102)
	at org.eclipse.xtext.serializer.tokens.CrossReferenceSerializer.serializeCrossRef(CrossReferenceSerializer.java:100)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.getToken(SequenceFeeder.java:448)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:214)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.sequence_Atom(AbstractMyDslSemanticSequencer.java:131)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.createSequence(AbstractMyDslSemanticSequencer.java:76)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptAction(SequenceFeeder.java:292)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:90)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.sequence_Expr(AbstractMyDslSemanticSequencer.java:200)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.createSequence(AbstractMyDslSemanticSequencer.java:60)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptEObjectRuleCall(SequenceFeeder.java:299)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.acceptRuleCall(SequenceFeeder.java:325)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:215)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.sequence_Equation(AbstractMyDslSemanticSequencer.java:182)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.createSequence(AbstractMyDslSemanticSequencer.java:66)
	at org.eclipse.xtext.serializer.acceptor.SequenceFeeder.accept(SequenceFeeder.java:239)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.accept(BacktrackingSemanticSequencer.java:380)
	at org.eclipse.xtext.serializer.sequencer.BacktrackingSemanticSequencer.createSequence(BacktrackingSemanticSequencer.java:423)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.sequence_Model(AbstractMyDslSemanticSequencer.java:230)
	at org.xtext.example.mydsl.serializer.AbstractMyDslSemanticSequencer.createSequence(AbstractMyDslSemanticSequencer.java:92)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:84)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:103)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:117)
	at org.eclipse.xtext.serializer.impl.Serializer.serialize(Serializer.java:50)
	at org.xtext.example.mydsl.plugin.actions.SampleAction$1.exec(SampleAction.java:79)
	at org.xtext.example.mydsl.plugin.actions.SampleAction$1.exec(SampleAction.java:1)
	at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:32)
	at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:78)
	at org.xtext.example.mydsl.plugin.actions.SampleAction.run(SampleAction.java:65)
	at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:251)
	at org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPluginAction.java:229)
	at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
	at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
	at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
Re: Null pointer when serializing cross references [message #868175 is a reply to message #868097] Tue, 01 May 2012 17:30 Go to previous messageGo to next message
Member
From poking around in the debugger, it seems that the error is caused because .eResource() returns null for everything that the serializer is returning. Do I need to somehow assign a resource prior to serializing? Here is how I currently serialize:
Injector injector = Guice.createInjector(new MyDslRuntimeModule());
Serializer serializer = injector.getInstance(Serializer.class);
String text = serializer.serialize(model);
Re: Null pointer when serializing cross references [message #868214 is a reply to message #868175] Tue, 01 May 2012 17:57 Go to previous message
Member
I have resolved this issue by avoiding calling the serializer directly. Instead I have roughly
document.readOnly(new IUnitOfWork<Void, XtextResource>() {
	public java.lang.Void exec(XtextResource state) throws Exception {
		Model model = (Model) state.getContents().get(0);
		model = ECoreUtil.copy(model);
		// Do some transformations on model
		URI uri = getOutputURI(state.getURI());
		Resource res = state.getResourceSet().createResource(uri);
		res.getContents().add(model);
		res.save(null);
		return null;
and
private URI getOutputURI(URI uri) {
	String filename = uri.lastSegment();
	uri = uri.trimSegments(1);
	int i = filename.lastIndexOf(".");
	uri = uri.appendSegment(filename.substring(0, i) + ".transformed" + filename.substring(i));
	return uri;
I'm still not sure if this is the proper way to do things, but at least it seems to work.
-Andrew
Previous Topic:How to unit test global scoping
Next Topic:EOF not matching RULE_EOL
Current Time: Fri Jan 15 15:32:01 GMT 2021
Powered by FUDForum. Page generated in 0.01383 seconds
