Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » HowTo generate and run a standalone cdo server?
HowTo generate and run a standalone cdo server? [message #113577] Fri, 29 February 2008 11:17 Go to next message
Originally posted by: mam05eux.studserv.uni-leipzig.de
I wanted to teste CDO on some computers.
So the tutorial (library) works fine on one computer but now i wanted to
generate a standalone cdo server which can be run on an external server
so that I´m able to develop models on more than one pc.
I tried to find an approach to generate a server but there is nothing on
the internet, i think ;)
I took a look at the source code of the example server but that didn´t
make me much smarter.
So please help me!!! :)
Second question is if there is any possibility to run such a server
without eclipse?
Re: HowTo generate and run a standalone cdo server? [message #113629 is a reply to message #113577] Fri, 29 February 2008 16:31 Go to previous message
Eike Stepper is currently offline Eike StepperFriend
Hi Stanley,
Comments below...
Stanley Hillner wrote:
> Hello,
> so that IÂŽm able to develop models on more than one pc.
> I took a look at the source code of the example server but that didnÂŽt
I'm currently not at home so I can only direct you to some existing test
code:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/tests/org.eclipse.emf.cdo.tests/src/org/ecl ipse/emf/cdo/tests/ImportXML.java?root=Modeling_Project& view=markup
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/hibernate/org.eclipse.emf.cdo.tests.hiberna te/src/org/eclipse/emf/cdo/tests/hibernate/HibernateTest.jav a?root=Modeling_Project&view=markup
Currently I have no snippet at hand which demonstrates the setup of a
standalone DBStore. The above test cases use a MEMStore and a
HibernateStore. You should be able to use something like
CDODBUtil.createStore(...).
If all this does not help, please remind me during the weekend that I
write something useful for you.
> without eclipse?
Aeh, all of the above examples run the server standalone, i.e. without
Eclipse. Wasn't that what you asked for initially?
Cheers
/Eike
Re: HowTo generate and run a standalone cdo server? [message #615589 is a reply to message #113577] Fri, 29 February 2008 16:31 Go to previous message
Hi Stanley,
Comments below...
> Hello,
code:
> without eclipse?
Cheers
/Eike
Previous Topic:[TENEO] [JDO] library tutorial - connection getting closed
Next Topic:Performance problems with udge database
Current Time: Tue Aug 16 13:44:57 GMT 2022
Powered by FUDForum. Page generated in 0.01815 seconds
