Home » Archived » Test and Performance Tools Platform (TPTP) » Control Center Dialog is not allowing to enter project name
Control Center Dialog is not allowing to enter project name [message #113388] Thu, 27 September 2007 11:43 Go to next message
Pushparaj is currently offline PushparajFriend
Member
Hi All,
I am trying to use TPTP to recod user events for my eclipse based
applications. So i am following the tutorilal,
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html#2.0
But its not allowing to enter the project name in the project creation
wizard. because that wizard is not in focus.
Re: Control Center Dialog is not allowing to enter project name [message #113440 is a reply to message #113388] Thu, 27 September 2007 14:12 Go to previous messageGo to next message
Rohit Shetty is currently offline Rohit ShettyFriend
Hi Pushparaj,
Can you give more details on the TPTP/Eclipse/AutoGUI version you are using
and the environment you are working in (OS etc).
Also, Does this problem occur when you record or when you playback your
recording.
Rohit Shetty
"Pushparaj" <pushparaj_94@yahoo.com> wrote in message
news:683344111cd4cf2cd6bfe1a8c26b5269$1@www.eclipse.org...
> Hi All,
Re: Control Center Dialog is not allowing to enter project name [message #113670 is a reply to message #113440] Mon, 01 October 2007 11:44 Go to previous messageGo to next message
Member
Hi Rohit,
I am using,
TPTP - 4.4.0.2
Eclipse - 3.3
Auto GUI - 4.4.0.2
I am facing this problem when i am trying do record.
I am following the tutorial,
Pushparaj
Re: Control Center Dialog is not allowing to enter project name [message #113681 is a reply to message #113670] Mon, 01 October 2007 11:47 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Pushparaj,
Is this Linux or Windows? Did you try selecting the wizard with your
mouse?
Paul
news:394bf50cf7553fc21bb1ea286228ba7b$1@www.eclipse.org...
> Hi Rohit,
> I am using,
> TPTP - 4.4.0.2
> Eclipse - 3.3
> Auto GUI - 4.4.0.2
> I am facing this problem when i am trying do record. I am following the
> tutorial,
> Pushparaj
Re: Control Center Dialog is not allowing to enter project name [message #113743 is a reply to message #113681] Mon, 01 October 2007 13:02 Go to previous messageGo to next message
Member
Hi Paul,
I am using Linux.
Yes. i am selecting the wizard using mouse.
Pushparaj.
Re: Control Center Dialog is not allowing to enter project name [message #113769 is a reply to message #113743] Mon, 01 October 2007 13:12 Go to previous messageGo to next message
Member
Hi Paul,
I am using Linux.
Yes. I am using mouse to select the wizard.
If i am using the menu File-> Project, i am not able to select the 'next'
button.
If i am using the menu File-> Java Project, i am not able enter the
project name in the wizard.
Pushparaj.
Re: Control Center Dialog is not allowing to enter project name [message #113805 is a reply to message #113769] Tue, 02 October 2007 13:14 Go to previous messageGo to next message
Hi Pushparaj,
This appears to be a defect caused by the controller freezing while
trying to identify its parent due to SWT events not being called correctly.
Please open a defect with your configuration (OS vendor/version, JRE
vendor/version, TPTP/AGR version, etc.):
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
Component: Test.Execution.AutoGUIRunner
Paul
news:54ac47dd7a4f7fb9701569ffcfe64529$1@www.eclipse.org...
> Hi Paul,
> I am using Linux.
> button.
> Pushparaj.
Re: Control Center Dialog is not allowing to enter project name [message #113881 is a reply to message #113805] Tue, 02 October 2007 16:25 Go to previous messageGo to next message
Member
Hi Paul,
Is any other way or workaround to use TPTP in linux?
Pushparaj
Re: Control Center Dialog is not allowing to enter project name [message #113934 is a reply to message #113881] Wed, 03 October 2007 10:26 Go to previous messageGo to next message
Hi Pushparaj,
This problem is specific to your machine and configuration. We test the
AGR on Linux (SLES 10)/IBM JRE 1.5 SR4 with success. What OS vendor/version
and JRE vendor/version are you using?
You could try to delete your workspace and create a new project/test
suite.
Paul
news:8609aa63e9cb1aaee6822019aa21cc87$1@www.eclipse.org...
> Hi Paul,
> Pushparaj
Re: Control Center Dialog is not allowing to enter project name [message #114584 is a reply to message #113934] Mon, 08 October 2007 10:43 Go to previous messageGo to next message
Member
I am using Redhat linux(RHEL 4). kernel version 2.6.18-1.2798.
and sun/jre 1.5
I am facing the same problem even after removing workspace/creating new
test suite.
Pushparaj.
Re: Control Center Dialog is not allowing to enter project name [message #114684 is a reply to message #114584] Tue, 09 October 2007 11:59 Go to previous message
Hi Pushparaj,
Although this configuration (OS/JRE vendor/version) is not tested each
release, there should be no blocking issues. Please open a defect:
Component: Test.UI.AutoGUIUI
Paul
news:05e8e05a38b73cd68be648902a2d6a07$1@www.eclipse.org...
> and sun/jre 1.5
> test suite.
> Pushparaj.
Previous Topic:unable to get agent TimeCollector
Next Topic:TPTP on AIX
Current Time: Fri Jul 30 11:09:18 GMT 2021
Powered by FUDForum. Page generated in 0.02377 seconds
