Home » Eclipse Projects » Virgo » Problems loading ApplicatioContext file in a WAB
Problems loading ApplicatioContext file in a WAB [message #867281] Tue, 01 May 2012 08:02 Go to next message
taher mosbah is currently offline taher mosbahFriend
Greetings,
Im having a hard time getting a Spring project to run on Virgo 3.0.2, and more precisely reading the applicationContext file, here is my StackTrace:
[2012-05-01 09:44:37.681] DEBUG Thread-130                   o.e.gemini.web.tomcat.internal.loading.BundleWebappClassLoader      Searching the application's bundle
[2012-05-01 09:44:37.681] TRACE Thread-130                   org.springframework.osgi.util.DebugUtils                          Could not find class [org.springframework.web.context.ContextLoaderListener] required by [null(BizTouch.Web)] scanning available bundles
[2012-05-01 09:44:37.682] DEBUG Thread-130                   o.e.gemini.web.tomcat.internal.loading.BundleWebappClassLoader    loadClass(org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader, false)
[2012-05-01 09:44:37.682] DEBUG Thread-130                   o.e.gemini.web.tomcat.internal.loading.BundleWebappClassLoader      Searching the application's bundle
[2012-05-01 09:44:37.683] TRACE Thread-130                   org.springframework.osgi.util.DebugUtils                          Could not find class [org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader] required by [null(BizTouch.Web)] scanning available bundles
[2012-05-01 09:44:37.683] ERROR Thread-130                   o.a.c.core.ContainerBase.[Catalina].[localhost].[/BizTouch.Web]   Error configuring application listener of class org.springframework.web.context.ContextLoaderListener java.lang.ClassNotFoundException: org.springframework.web.context.ContextLoaderListener
	at org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:306)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
	at org.apache.catalina.core.DefaultInstanceManager.loadClass(DefaultInstanceManager.java:415)
	at org.apache.catalina.core.DefaultInstanceManager.loadClassMaybePrivileged(DefaultInstanceManager.java:397)
	at org.apache.catalina.core.DefaultInstanceManager.newInstance(DefaultInstanceManager.java:118)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4660)
	at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5226)
	at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5221)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
	at java.util.concurrent.FutureTask.run(FutureTask.java:138)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:885)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:907)
	at java.lang.Thread.run(Thread.java:619)
my Manifest file:
Manifest-Version: 2.0
Tool: Bnd-0.0.386
Meta-Persistence: META-INF/persistence.xml
Bundle-Name: com.apptivit.biztouch.web
DynamicImport-Package: *
Bundle-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-SymbolicName: com.apptivit.biztouch.web
Import-Library: org.springframework.spring;version="[3.0.5.RELEASE,3.0.5.RELEASE]"
Import-Bundle: com.springsource.com.mysql.jdbc;version="[5.1.6,5.1.6]"
Import-Package: com.apptivit.biztouch.business.timeline;com.apptivit.biztouch.dao;javax.el;javax.servlet;javax.servlet.http;javax.servlet.jsp;javax.servlet.jsp.el;javax.servlet.jsp.tagext;com.apptivit.biztouch.models;org.eclipse.virgo.web.dm
Bundle-Vendor: Apptiv-IT
Web-ContextPath: BizTouch.Web
Spring-Context: WEB-INF/spring/appServlet/appServlet-context.xml
my web.xml file :
	<!-- The definition of the Root Spring Container shared by all Servlets
		and Filters -->
	<context-param>
		<param-name>contextConfigLocation</param-name>
		<param-value>/WEB-INF/spring/root-context.xml</param-value>
	</context-param>
	<context-param>
		<param-name>contextClass</param-name>
		<param-value>org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext</param-value>
	</context-param>
	<!-- Creates the Spring Container shared by all Servlets and Filters -->
	<listener>
		<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
	</listener>
	<!-- Processes application requests -->
	<servlet>
		<servlet-name>appServlet</servlet-name>
		<servlet-class>org.springframework.web.servlet.DispatcherServlet</servlet-class>
		<init-param>
			<param-value>/WEB-INF/spring/appServlet/appServlet-context.xml</param-value>
		</init-param>
		<init-param>
			<param-value>org.springframework.osgi.web.context.support.OsgiBundleXmlWebApplicationContext</param-value>
		</init-param>
		<load-on-startup>1</load-on-startup>
	</servlet>
	<servlet-mapping>
		<url-pattern>/</url-pattern>
	</servlet-mapping>
</web-app>
I'm ready to provide the complete project if needed, I experimented with various
configurations and always get the same problem.
Many thanks.
Re: Problems loading ApplicatioContext file in a WAB [message #867349 is a reply to message #867281] Tue, 01 May 2012 08:44 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn NormingtonFriend
Looks like you're missing an import. Remember that Spring web is not part of the core Spring framework and so is not covered by Import-Library: org.springframework.spring;...
Re: Problems loading ApplicatioContext file in a WAB [message #867397 is a reply to message #867349] Tue, 01 May 2012 09:18 Go to previous messageGo to next message
Thank you for your quick reply,
This link at spring source repository states that spring web is part of spring library : springsource.com/repository/app/library/version/detail?name=org.springframework.spring&version=3.0.5.RELEASE
sorry for the formatting because I can't post links
anyway, I tried to add the import explicitly but I always get the same error...
I'm really out of ideas.
[Updated on: Tue, 01 May 2012 09:18]
Report message to a moderator
Re: Problems loading ApplicatioContext file in a WAB [message #867433 is a reply to message #867397] Tue, 01 May 2012 09:41 Go to previous messageGo to next message
My mistake about the spring library. The usual advice is either to start with a known good WAB and add in your changes incrementally to narrow down the problem or to start with the failing WAB and gradually strip it down until you find a single change that removes the problem. Often this turns up an error in the application, but if not, you'll have a minimal testcase that can be the basis for a bug.
Re: Problems loading ApplicatioContext file in a WAB [message #867462 is a reply to message #867433] Tue, 01 May 2012 09:59 Go to previous messageGo to next message
Thanks for the advice, I tried that approach earlier, just a new dynamic web application with web bundle nature, but I got exactly the same problem,
I tried changing spring library to 3.1.1, changing Virgo to 3.0.3 with no chance.
The weird thing is that "org.springframework.web-3.0.5.RELEASE.jar" exists in my
VIRGO_HOME/repository/ext and contains the said missing class .
Re: Problems loading ApplicatioContext file in a WAB [message #867486 is a reply to message #867462] Tue, 01 May 2012 10:18 Go to previous messageGo to next message
Actually with a fresh web application bundle with just spring config files and on controller, I'm getting this:
[2012-05-01 12:14:12.154] TRACE  TCP Connection(2)-127.0.0.1 o.e.v.kernel.deployer.core.internal.PipelinedApplicationDeployer  < private void org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.uninstallArtifact(org.eclipse.virgo.kernel.install.artifact.InstallArtifact)
[2012-05-01 12:14:12.157] DEBUG  TCP Connection(2)-127.0.0.1 o.e.v.kernel.deployer.core.internal.PipelinedApplicationDeployer  < public org.eclipse.virgo.kernel.deployer.core.DeploymentIdentity org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(java.net.URI, org.eclipse.virgo.kernel.deployer.core.DeploymentOptions) org.eclipse.virgo.kernel.deployer.core.DeploymentException: IOException parsing XML document from OSGi resource[/applicationContext.xml|bnd.id=137|bnd.sym=BizTouch.webTest]; nested exception is java.io.FileNotFoundException: OSGi resource[/applicationContext.xml|bnd.id=137|bnd.sym=BizTouch.webTest] cannot be resolved to URL because it does not exist
	at org.eclipse.virgo.kernel.deployer.core.internal.BlockingSignal.awaitCompletion(BlockingSignal.java:87)
	at org.eclipse.virgo.kernel.deployer.core.internal.BlockingAbortableSignal.awaitCompletion(BlockingAbortableSignal.java:63)
	at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.start(PipelinedApplicationDeployer.java:303)
	at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:208)
	at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:167)
	at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:96)
	at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:33)
	at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
	at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
	at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:262)
	at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
	at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:761)
	at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1424)
	at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMIConnectionImpl.java:72)
	at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1262)
	at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1357)
	at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:786)
	at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:305)
	at sun.rmi.transport.Transport$1.run(Transport.java:159)
	at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
	at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
	at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
	at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
Caused by: java.io.FileNotFoundException: OSGi resource[/applicationContext.xml|bnd.id=137|bnd.sym=BizTouch.webTest] cannot be resolved to URL because it does not exist
you can find the test project as attachment:
[Updated on: Tue, 01 May 2012 10:21]
Re: Problems loading ApplicatioContext file in a WAB [message #869449 is a reply to message #867486] Thu, 03 May 2012 12:20 Go to previous messageGo to next message
Hi, I'm starting over with just a web bundle and adding spring project nature without maven integration, my spring servlet configuration file is recognized successfully, but I'm getting the following exception :
Exception sending context destroyed event to listener instance of class org.springframework.web.context.ContextLoaderListener java.lang.NoClassDefFoundError: org/apache/commons/logging/LogFactory
	at org.springframework.web.context.ContextCleanupListener.<clinit>(ContextCleanupListener.java:43)
	at org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:144)
	at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4819)
	at org.apache.catalina.core.StandardContext.stopInternal(StandardContext.java:5466)
	at org.apache.catalina.util.LifecycleBase.stop(LifecycleBase.java:232)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:160)
	at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:895)
	at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:871)
	at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:615)
	at org.eclipse.gemini.web.tomcat.internal.TomcatServletContainer.startWebApplication(TomcatServletContainer.java:124)
	at org.eclipse.gemini.web.internal.StandardWebApplication.start(StandardWebApplication.java:95)
	at org.eclipse.virgo.web.core.internal.WebBundleLifecycleListener.onStarted(WebBundleLifecycleListener.java:122)
	at org.eclipse.virgo.kernel.install.artifact.internal.StandardArtifactStateMonitor.onStarted(StandardArtifactStateMonitor.java:271)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.asyncStartSucceeded(AbstractInstallArtifact.java:319)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact.access$0(AbstractInstallArtifact.java:316)
	at org.eclipse.virgo.kernel.install.artifact.internal.AbstractInstallArtifact$StateMonitorSignal.signalSuccessfulCompletion(AbstractInstallArtifact.java:252)
	at org.eclipse.virgo.kernel.core.internal.BundleStartTracker$1.run(BundleStartTracker.java:140)
	at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
	at java.lang.Thread.run(Thread.java:680)
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.apache.commons.logging.LogFactory in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0]
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:138)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
	... 20 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.apache.commons.logging.LogFactory
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:134)
	... 21 common frames omitted
I'm already have commons-logging in my dependencies.
Sincerly.
Re: Problems loading ApplicatioContext file in a WAB [message #869600 is a reply to message #869449] Thu, 03 May 2012 17:09 Go to previous messageGo to next message
I actually identified the problem, wich is the listner in web.xml, here is my web.xml :
	<display-name>TestWebBundle</display-name>
	<context-param>
	</context-param>
<!-- 	<listener> -->
<!-- 		<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class> -->
<!-- 	</listener> -->
	<servlet>
		<servlet-name>dispatcher</servlet-name>
	</servlet>
	<servlet-mapping>
	</servlet-mapping>
</web-app>
The bundle deployes successfully but I got this exception on runtime :
org.springframework.beans.FatalBeanException: Class [org.springframework.context.config.ContextNamespaceHandler] for namespace [springframework.org/schema/context] does not implement the [org.springframework.beans.factory.xml.NamespaceHandler] interface
	org.springframework.beans.factory.xml.DefaultNamespaceHandlerResolver.resolve(DefaultNamespaceHandlerResolver.java:126)
	org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1330)
	org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1325)
	org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:135)
	org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:93)
	org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:493)
	org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:390)
	org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
	org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
	org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:143)
	org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:178)
	org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:149)
	org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:124)
	org.springframework.web.context.support.XmlWebApplicationContext.loadBeanDefinitions(XmlWebApplicationContext.java:93)
	org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
	org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:467)
	org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:397)
	org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:442)
	org.springframework.web.servlet.FrameworkServlet.createWebApplicationContext(FrameworkServlet.java:458)
	org.springframework.web.servlet.FrameworkServlet.initWebApplicationContext(FrameworkServlet.java:339)
	org.springframework.web.servlet.FrameworkServlet.initServletBean(FrameworkServlet.java:306)
	org.springframework.web.servlet.HttpServletBean.init(HttpServletBean.java:127)
	javax.servlet.GenericServlet.init(GenericServlet.java:244)
	org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
	org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
	org.eclipse.virgo.web.tomcat.support.ApplicationNameTrackingValve.invoke(ApplicationNameTrackingValve.java:33)
	org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
	org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
	org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:987)
	org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
	org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:309)
if I uncomment the listner on web.xml, my bundle fails to start giving the following :
[2012-05-03 18:02:35.519] ERROR start-signalling-4           o.a.c.core.ContainerBase.[Catalina].[localhost].[/TestWebBundle]  Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener java.lang.NoClassDefFoundError: org.eclipse.virgo.web.dm.ServerOsgiBundleXmlWebApplicationContext not found from bundle [TestWebBundle_1.0.0 [133]]
	at org.eclipse.gemini.web.tomcat.internal.loading.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:107)
	at org.eclipse.gemini.web.tomcat.internal.loading.BundleDelegatingClassLoader.loadClass(BundleDelegatingClassLoader.java:139)
	at org.eclipse.gemini.web.tomcat.internal.loading.ChainedClassLoader.doLoadClass(ChainedClassLoader.java:173)
	at org.eclipse.gemini.web.tomcat.internal.loading.ChainedClassLoader.loadClass(ChainedClassLoader.java:163)
	at org.eclipse.gemini.web.tomcat.internal.loading.BundleWebappClassLoader.loadClass(BundleWebappClassLoader.java:293)
	at org.springframework.util.ClassUtils.forName(ClassUtils.java:257)
	at org.springframework.web.context.ContextLoader.determineContextClass(ContextLoader.java:292)
	at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:245)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4779)
	at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5273)
	at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150)
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedNoClassDefFoundError: org/eclipse/gemini/blueprint/context/support/OsgiBundleXmlApplicationContext in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0] in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0]
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:140)
	at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:345)
	at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:229)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1207)
	at org.eclipse.gemini.web.tomcat.internal.loading.BundleDelegatingClassLoader.findClass(BundleDelegatingClassLoader.java:91)
	... 28 common frames omitted
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.defineClass(KernelBundleClassLoader.java:242)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:601)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:567)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:490)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:478)
	at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:458)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
	at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:400)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:476)
	... 33 common frames omitted
Caused by: java.lang.NoClassDefFoundError: org/eclipse/gemini/blueprint/context/support/OsgiBundleXmlApplicationContext
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:188)
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.defineClass(KernelBundleClassLoader.java:238)
	... 45 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext in KernelBundleClassLoader: [bundle=TestWebBundle_1.0.0]
	... 50 common frames omitted
Caused by: java.lang.ClassNotFoundException: org.eclipse.gemini.blueprint.context.support.OsgiBundleXmlApplicationContext
	... 51 common frames omitted
As an attachement you can find my test project,(sorry file size is too big)
Sincerly.
[Updated on: Thu, 03 May 2012 17:15]
Re: Problems loading ApplicatioContext file in a WAB [message #870389 is a reply to message #869600] Mon, 07 May 2012 22:06 Go to previous messageGo to next message
The last problem turned to be caused by a conflict in spring jars, I solved it by referening the jars shiped with Virgo in my classpath. Thank you.
[Updated on: Mon, 07 May 2012 22:07]
Re: Problems loading ApplicatioContext file in a WAB [message #870672 is a reply to message #870389] Wed, 09 May 2012 10:04 Go to previous messageGo to next message
teresa tang is currently offline teresa tangFriend
May I know how do you fix it ? I met the same problem too.
Re: Problems loading ApplicatioContext file in a WAB [message #870677 is a reply to message #870672] Wed, 09 May 2012 10:19 Go to previous messageGo to next message
@Teresa tang, I just started a new dynamic web project, added web application nature (have to install osgi bundle facet from : download.eclipse.org/virgo/milestone/tooling) and that's all, for the configuration just follow the greenpages samples (this is the most up to date verion : github.com/dsklyut/virgo-samples-greenpages) , if you have any other problems it will be a pleasure to help.
Re: Problems loading ApplicatioContext file in a WAB [message #870857 is a reply to message #870677] Thu, 10 May 2012 01:50 Go to previous message
Thanks for your reply and help.
I resolved the problem, the war can not build by the ant directly
[Updated on: Thu, 10 May 2012 07:48]
Previous Topic:Snaps Parent Application Context Not Loading
Next Topic:How to change the value of LimitRequestFieldSize in virgo tomcat server
Current Time: Tue Apr 16 20:35:11 GMT 2024
Powered by FUDForum. Page generated in 1.59685 seconds
