Re: How to call data binding from a toolbar handler [message #869031 is a reply to message #868456] |
Wed, 02 May 2012 21:49 |
Hi Lanz,
making the databinding in the handler is somewhat strange: the detail view should be aware of selection change (whoever is firing it) and provide for its own databinding.
I suggest the following pattern.
1) in the view that contains the table in which the selection changes do this when you create the tableviewer
getViewSite().setSelectionProvider(viewer);
(this will fire the selection change to whoever will register for this event)
2) in the detail view, when creating the widgets do this:
PlatformUI.getWorkbench().getActiveWorkbenchWindow()
.getSelectionService()
.addSelectionListener(new ISelectionListener() {
public void selectionChanged(IWorkbenchPart part,
ISelection selection) {
//Selection is changed => call the databinding
3) since the databindings on a new selection should be made after having removed the databindings on the old selection, it is advisable using a WritableValue attribute, which takes care of this automatically. Just do this:
define, in the detail view, a WritableValue
private WritableValue value = new WritableValue();
the use it to bind to the widgets (an example of this can be found among our tutorials (search "RCP Vision WindowBuilder: advanced databinding with CDO" on Google), just see the part after the definition of the WritableValue)
Hope this help
Let me know
Vincenzo Caselli
RCP Vision
FUDForum. Page generated in 0.02945 seconds
