Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Is there a way to separate notation that define column length?
Re: [Teneo] Is there a way to separate notation that define column length? [message #114667 is a reply to message #113027] |
Thu, 13 March 2008 18:19   |
David Wynter Messages: 4624 Registered: July 2009 |
Just come back to this. When I select "Generate EMF - Hibernate OR
Mapping (joined-subclass)" I will be generating a hbm fle that supports
a table per subclass and thus have no need for a discriminator column. I
do this and then search the generated hibernate.hbm.xml file for the
keyword discriminator and it does not exist, so far so good. Then I
delete my existing schema and run my HibInit class (based on the
tutorial code) which I assume picks up the hibernate.hbm.xml from the
model directory and uses that to generate the tables.
The trouble is I still get the dtype column in every table. I know I
must be missing something, I searched for a hibernate.hbm.xml that might
be lurking somewhere else but no, it is not.
Here are the porperties again
props.setProperty(Environment.DRIVER, "com.mysql.jdbc.Driver");
props.setProperty(Environment.USER, "\gf\");
props.setProperty(Environment.PASS, "\g0rd");
props.setProperty(Environment.URL, "jdbc:mysql://localhost:3306/" +
dbName);
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.MySQLInnoDBDialect.class.getName());
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH ,
"30");
props.setProperty(PersistenceOptions.ID_COLUMN_NAME, "id");
props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY,
"false");
props.setProperty(PersistenceOptions.JOIN_COLUMN_NAMING_STRA TEGY, "simple");
props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "false");
props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE,
"DATE");
props.setProperty(PersistenceOptions.DISABLE_ECONTAINER_MAPP ING, "true");
props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
props.setProperty(PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG,
"true");
// create the HbDataStore
HbDataStore hbds = HbHelper.INSTANCE.createRegisterDataStore(hbName);
// set the relational database to use and other properties
// to set Teneo specific options call
hbds.setPersistenceProperties(props);
hbds.setHibernateProperties(props);
// sets its epackages stored in this datastore
hbds.setEPackages(new EPackage[]{GensecPackage.eINSTANCE});
Thx.
David
Martin Taal wrote:
> Hi David,
> You can specify annotations in a separate xml file, see here:
> http://www.elver.org/hibernate/ejb3_format.html#xml
> Note that you can also specify on edatatype level, so if your string
> types map to edatatypes in ecore then you only need to specify the
> column annotation on the edatatype and it will be re-used in every
> location where your string type is used.
> When I look at the Teneo testcases I can see that the discriminator is
> only added in case of single-table inheritance. Can you check and
> confirm? If you have a re-producable case then I can look at it in more
> detail (just enter a bugzilla in that case).
> gr. Martin
> david wrote:
>> Hi,
>> I have a large hibernate.hbm.xml being generated by Teneo from an
>> standardised XSD. I would like to be able to add the notations for
>> defining the column lengths (which of course are not specified in the
>> XSD) but not have them overwritten when I regenerate whenever the
>> standardized XSD has a new version released. So is it possible to have
>> these annotations defining the column lengths for the String type
>> elements and somehow merge them by element name with the generated
>> hibernate.hbm.xml? Is XSLT my only option?
>> The other query I had was to do with the generation of a discriminator
>> column (dtype) by Hibernate. Regardless of which Teneo option
>> (superclass or joined-subclass) I choose I seems to get this column.
>> The model I had does not have inheritance for the elements, so I do
>> not need the discriminator column.
>> Thx.
>> David
Re: [Teneo] Is there a way to separate notation that define column length? [message #114694 is a reply to message #114667] |
Thu, 13 March 2008 20:26  |
Hi David,
Afaics you did not set the mapping file option for Teneo. Therefore Teneo generates the mapping
in-memory, the default inheritance strategy is single table. So the in-mem mapping will follow that.
There are two ways to solve this:
- if you want to use a statically generated mapping file then set the mapping file option
PersistenceOptions.USE_MAPPING_FILE to true, then Teneo will search in the classpath of the model
package, if your mapping file is located somewhere else then use the MAPPING_FILE_PATH option.
- if you want to use the in-memory mapping logic (which is the same as the menu-driven generation)
then you should pass the INHERITANCE_MAPPING option to the datastore and set it to JOINED
gr. Martin
david wrote:
> "jdbc:mysql://localhost:3306/" + dbName);
> "30");
> "false");
> "simple");
> "DATE");
> "true");
> HbDataStore hbds =
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> more detail (just enter a bugzilla in that case).
>> gr. Martin
>> david wrote:
>>> Hi,
>>> have these annotations defining the column lengths for the String
>>> type elements and somehow merge them by element name with the
>>> generated hibernate.hbm.xml? Is XSLT my only option?
>>> discriminator column (dtype) by Hibernate. Regardless of which Teneo
>>> option (superclass or joined-subclass) I choose I seems to get this
>>> column. The model I had does not have inheritance for the elements,
>>> so I do not need the discriminator column.
>>> Thx.
>>> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Is there a way to separate notation that define column length? [message #615868 is a reply to message #113027] |
dbName);
"30");
"false");
"DATE");
"true");
Thx.
David
Martin Taal wrote:
> Hi David,
> gr. Martin
> david wrote:
>> Hi,
>> Thx.
>> David
Re: [Teneo] Is there a way to separate notation that define column length? [message #615871 is a reply to message #114667] |
Hi David,
gr. Martin
david wrote:
> "30");
> "false");
> "simple");
> "DATE");
> "true");
> HbDataStore hbds =
> Thx.
> David
> Martin Taal wrote:
>> Hi David,
>> gr. Martin
>> david wrote:
>>> Hi,
>>> Thx.
>>> David
The Netherlands
Current Time: Thu Aug 18 13:51:27 GMT 2022
Powered by FUDForum. Page generated in 0.02798 seconds
