Re: Plugin does not work properly in standard mode [message #113731 is a reply to message #112904] |
Mon, 01 October 2007 12:19 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Sumina,
Dependencies on your test project's classpath are deployed to the target
machine when launching a test (see
http://help.eclipse.org/help33/topic/org.eclipse.hyades.test .doc.user/ref/rdeploymentGroundRules.htm).
Currently, inserting artificial wait times and verification hooks (e.g.
logging current state and status) is the only method to debug AGR tests.
However, there is room here for improvement, especially with status
monitoring and logging when executing a test. Please open an enhancement
for adding status monitoring and logging when executing a test:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20T esting
Component: Test.Execution.CommonRunner
Paul
"Sumina" <sumina.kapoor@sungard.de> wrote in message
news:cd66e5b2d50331c7fdfc20bd7e39d9b1$1@www.eclipse.org...
> The product which I am testing is integrated with Eclipse. It is an
> eclipse plugin and it is integrated by adding the links to it under
> <eclipse_home>/links.
> I have a test case which creates a project with the elements from the
> above mentioned plug in. When I run it in quick mode, it works fine. But
> in standard mode, it does not create all the data, especially some data
> that is related to a portal which my product is supposed to create.
> Is there any way to make sure that all the functionalities of my plugin
> are available in standard mode as well? I tried importing all the packages
> under my plugin into manifest.mf dependencies tab, but that didn't help.
> Thanks in advance.
> Best regards,
> Sumina
FUDForum. Page generated in 0.01495 seconds
