Re: error in initializing data store [message #112534 is a reply to message #112520] |
Mon, 18 February 2008 05:36  |
Hi Yucel,
As far as I can see you are using an old version (build 200708101732) of the
HbAnnotationModelBuilder class, so I assume an old version of the
org.eclipse.emf.teneo.hibernate.mapper plugin (which contains this class).
gr. Martin
Yucel Turkkan wrote:
> We are using 200802122150 version of teneo.
> During DataStore initialization, in HbAnnotationModelBuilder class,
> doCreate method, we are getting the following exception at this line:
> paElement.setAnnotatedElement((ENamedElement) eModelElement);
> We would appreciate your help on this,
> Yucel
> Exception stack:
> 2008-02-18 01:40:38,687 ERROR [com.txe.runtime.relational.Runtime]
> org.eclipse.emf.teneo.annotations.pamodel.PAnnotatedEModelEl ement.setAnnotatedElement(Lorg/eclipse/emf/ecore/ENamedEleme nt;)V
> java.lang.NoSuchMethodError:
> at
> org.eclipse.emf.teneo.hibernate.annotations.HbAnnotationMode lBuilder.doCreate(HbAnnotationModelBuilder.java:56)
> at
> org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder .create(BasicPamodelBuilder.java:89)
> at
> org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder .pElement(BasicPamodelBuilder.java:137)
> at
> org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder .addRecurse(BasicPamodelBuilder.java:300)
> at
> org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:83)
> at
> org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:66)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.getPaModel(HbDat aStore.java:1094)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.getEntityNameStr ategy(HbDataStore.java:1134)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.setInterc eptor(HbSessionDataStore.java:128)
> at
> org.eclipse.emf.teneo.hibernate.HbDataStore.initializeDataSt ore(HbDataStore.java:208)
> at
> org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:78)
> at
> com.txe.runtime.relational.Runtime.initializeDataStore(Runti me.java:78)
> at
> com.txe.runtime.relational.resource.RelationalURIFactory.get DataStoreDescriptor(RelationalURIFactory.java:135)
> at
> com.txe.runtime.relational.resource.RelationalURIFactory.get DataStoreDescriptor(RelationalURIFactory.java:141)
> at
> com.txe.runtime.relational.resource.RelationalURIFactory.isF actoryForType(RelationalURIFactory.java:106)
> at com.txe.runtime.util.URIUtils.getURIFactory(URIUtils.java:61 )
> at com.txe.runtime.util.URIUtils.getContainerURI(URIUtils.java: 146)
> at
> com.txe.runtime.emf.edit.view.util.VirtualURIFactory.createU RI(VirtualURIFactory.java:44)
> at
> com.txe.runtime.resource.URIFactoryImpl.createURI(URIFactory Impl.java:62)
> at com.txe.runtime.util.URIUtils.createURI(URIUtils.java:154)
> at
> com.brane.runtime.core.rcp.internal.auth.AuthenticationManag er.getRoles(AuthenticationManager.java:142)
> at
> com.brane.runtime.core.rcp.internal.auth.AuthenticationManag er.getRole(AuthenticationManager.java:157)
> at
> com.brane.runtime.ui.dialogs.DefaultLoginSplashHandler.check Users(DefaultLoginSplashHandler.java:86)
> at
> com.brane.runtime.ui.dialogs.DefaultLoginSplashHandler.init( DefaultLoginSplashHandler.java:66)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:595)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbe nch.java:611)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2248)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> com.brane.runtime.ui.application.DefaultApplication.start(De faultApplication.java:22)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: error in initializing data store [message #615507 is a reply to message #112520] |
Hi Yucel,
gr. Martin
> Yucel
> Exception stack:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
FUDForum. Page generated in 0.02293 seconds
