Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » error in initializing data store
error in initializing data store [message #112520] Mon, 18 February 2008 00:14 Go to next message
Yucel Turkkan is currently offline Yucel TurkkanFriend
We are using 200802122150 version of teneo.
During DataStore initialization, in HbAnnotationModelBuilder class,
doCreate method, we are getting the following exception at this line:
paElement.setAnnotatedElement((ENamedElement) eModelElement);
We would appreciate your help on this,
Yucel
Exception stack:
2008-02-18 01:40:38,687 ERROR [com.txe.runtime.relational.Runtime]
org.eclipse.emf.teneo.annotations.pamodel.PAnnotatedEModelEl ement.setAnnotatedElement(Lorg/eclipse/emf/ecore/ENamedEleme nt;)V
java.lang.NoSuchMethodError:
at
org.eclipse.emf.teneo.hibernate.annotations.HbAnnotationMode lBuilder.doCreate(HbAnnotationModelBuilder.java:56)
at
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder .create(BasicPamodelBuilder.java:89)
at
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder .pElement(BasicPamodelBuilder.java:137)
at
org.eclipse.emf.teneo.annotations.mapper.BasicPamodelBuilder .addRecurse(BasicPamodelBuilder.java:300)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:83)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:66)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.getPaModel(HbDat aStore.java:1094)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.getEntityNameStr ategy(HbDataStore.java:1134)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.setInterc eptor(HbSessionDataStore.java:128)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.initializeDataSt ore(HbDataStore.java:208)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:78)
at
com.txe.runtime.relational.Runtime.initializeDataStore(Runti me.java:78)
at
com.txe.runtime.relational.resource.RelationalURIFactory.get DataStoreDescriptor(RelationalURIFactory.java:135)
at
com.txe.runtime.relational.resource.RelationalURIFactory.get DataStoreDescriptor(RelationalURIFactory.java:141)
at
com.txe.runtime.relational.resource.RelationalURIFactory.isF actoryForType(RelationalURIFactory.java:106)
at com.txe.runtime.util.URIUtils.getURIFactory(URIUtils.java:61 )
at com.txe.runtime.util.URIUtils.getContainerURI(URIUtils.java: 146)
at
com.txe.runtime.emf.edit.view.util.VirtualURIFactory.createU RI(VirtualURIFactory.java:44)
at
com.txe.runtime.resource.URIFactoryImpl.createURI(URIFactory Impl.java:62)
at com.txe.runtime.util.URIUtils.createURI(URIUtils.java:154)
at
com.brane.runtime.core.rcp.internal.auth.AuthenticationManag er.getRoles(AuthenticationManager.java:142)
at
com.brane.runtime.core.rcp.internal.auth.AuthenticationManag er.getRole(AuthenticationManager.java:157)
at
com.brane.runtime.ui.dialogs.DefaultLoginSplashHandler.check Users(DefaultLoginSplashHandler.java:86)
at
com.brane.runtime.ui.dialogs.DefaultLoginSplashHandler.init( DefaultLoginSplashHandler.java:66)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:595)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at
org.eclipse.ui.internal.Workbench.createSplashWrapper(Workbe nch.java:611)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2248)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
at
com.brane.runtime.ui.application.DefaultApplication.start(De faultApplication.java:22)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
Re: error in initializing data store [message #112534 is a reply to message #112520] Mon, 18 February 2008 05:36 Go to previous message
Martin Taal is currently offline Martin TaalFriend
Hi Yucel,
As far as I can see you are using an old version (build 200708101732) of the
HbAnnotationModelBuilder class, so I assume an old version of the
org.eclipse.emf.teneo.hibernate.mapper plugin (which contains this class).
gr. Martin
> Yucel
> Exception stack:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: error in initializing data store [message #615507 is a reply to message #112520] Mon, 18 February 2008 05:36 Go to previous message
Hi Yucel,
gr. Martin
> Yucel
> Exception stack:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Previous Topic:error in initializing data store
Next Topic:TENEO : Link not created
Current Time: Tue Apr 16 23:23:05 GMT 2024
Powered by FUDForum. Page generated in 9.75840 seconds
