Home » Language IDEs » C / C++ IDE (CDT) » C Syntax Help(How to get C Syntax help in Eclipse)
C Syntax Help [message #863721] Sun, 29 April 2012 12:19 Go to next message
Friends, I am new to this forum and Eclipse IDE... So please excuse, if this question is a repeat...!!
I used to use Turbo C long back (DOS environ) to write basic C programs... I am not a professional programmer.... I am now trying to learn to use Eclipse IDE for writing C Codes... However, I am unable to familiarize myself quickly.... Can anyone help me with the following please:
In my old DOS based Turbo C, if I had to get Syntax help, I would just type the word, for instance, 'print' and take the cursor to this word and press Ctrl + F1.. All possible matches related to 'print' would be displayed in help with examples etc.... It would also suggest other possible functions similar to 'printf'.....!!!
I wish to know, is there any similar method to get syntax help in Eclipse...??
Thanks in advance and Regards
Rahul
Re: C Syntax Help [message #868618 is a reply to message #863721] Wed, 02 May 2012 05:52 Go to previous message
You should install the LibHover plugin from the Linux Tools project (works on Windows as well). The plugin is available from withn Eclipse via Help->Install new software
Previous Topic:Getting the GDB (DSF) create Process launcher to stop in shared library breakpoints
Next Topic:header include path order
Current Time: Mon Jul 14 05:59:53 EDT 2025
Powered by FUDForum. Page generated in 0.06824 seconds
