Home » Archived » Java WorkFlow Tooling (JWT) » Has anyone looked into Imixs. <Open Source Workflow/> .org
Re: Has anyone looked into Imixs. <Open Source Workflow/> .org [message #10308 is a reply to message #10241] |
Tue, 10 January 2006 09:19 |
Originally posted by: fabrice.dewasmes.openwide.fr
Charlie wrote:
> http://www.imixs.org/websites/imixs-org_en.nsf/chapter/0030. ?OpenDocument
> Just curious what others in this group have to say about it.
> Obviously it's not EMF/GMF, so what are the relative advantages to using
> EMF and or GMF if any?
I didn't know about this project and it seems interesting. However they
use a 'proprietary' (meaning non standard) workflow model. But this is
interesting and the UI seems pretty clean ! Looking at javadoc shows
that they do not use EMF but only GEF. This is the approach we have used
in our early implementation.
To me, the interest of using EMF is :
- generating classes that have nearly no value add
- persistence of the model instances. This is the most interesting part
especially when you use an XSD schema and you want to generate XML
instances that conforms to this schema. This avoids use of direct XML
manipulation or Object-XML mapping such as XMLBeans or JAXB (even if I
find XMLBeans pretty useful).
This alone is not sufficient to switch to EMF. I think the real interest
of using GEF would be to also use GMF. But at this time the project
seems not sufficiently stable to use it... I will give it a new try
using your pointers about versions to use.
Fabrice
> Charlie
u asked, I answer by IMHO [message #10672 is a reply to message #10308] |
Thu, 12 January 2006 12:25 |
Originally posted by: vgv8.yahoo.com.br
I am just fan of .NET and in comparison I see clearly many things are bad to
me as user in GEF with EMF (and GMF as the bridge bewtween them). And from
developing the wrong things you get huge wrong things
I just cannot restrict me from some comments:
- inixs.com is IBM Business partner and do not use EMF;
- GMF is possibly tapping the problems on top of somewhat excessively
ambiguous and exaggerated initial ideas, arquitectures and thereafter
problems (GEF with EMF),
it may possibly just insist on wrong arquitectures and vision
- I hate the idea that Swing as proven, elaborated MVC solution with a lot
of ready solutions is somewhat incompatible with Eclipse platform.
- - As a matter of fact, I think the attitude to melt the platform and
IDE was bad concept )oSGI tries to revert it partially but it resemles me
shooting out your own legs)
Might be it had more sense just to have more simple or integrated with
IDE/platform solutions. But the problems are also in platform and IDE.
Guennadi Vanine
"Fabrice Dewasmes" <fabrice.dewasmes@openwide.fr> wrote in message
news:dpvua1$lsc$1@utils.eclipse.org...
> interesting and the UI seems pretty clean ! Looking at javadoc shows that
> they do not use EMF but only GEF. This is the approach we have used in our
> of using GEF would be to also use GMF. But at this time the project seems
> not sufficiently stable to use it... I will give it a new try using your
> Fabrice
>> Thanks,
>> Charlie
Re: u asked, I answer by IMHO [message #13185 is a reply to message #10672] |
Fri, 13 January 2006 10:46 |
I noticed this.
Participating in an eclipse plugin is about writing a set of frameworks
or tools, plugins etc... for eclipse not rewriting eclipse ;) As I've
said using eclipse swing bridge is not a good idea.
Fabrice
> Guennadi Vanine
>>Fabrice
>>>Thanks,
>>>Charlie
on bridges and gaps [message #13324 is a reply to message #13185] |
Fri, 13 January 2006 14:27 |
> Participating in an eclipse plugin is about writing a set of frameworks or
> Fabrice
IMHO using Eclipse Swing Bridge is no worse idea than using Eclipse or
making bridge between Sun and IBM.
It is just compromise and dialectics:
should this world have bridges or only straight gaps?
Guennadi Vanine
I need clarifications [message #13425 is a reply to message #10308] |
Fri, 13 January 2006 22:40 |
Fabrice:
I should tell that I had not been looking into GEF with EMF for more than a
month
(since I shifted back to Vision,Requirements basics and was out for another
project).
I should repeat that my interest is adjust XML format to a proprietory
format and fix it. Since BPM engine is considered fixed or , at least, not
available to my consideration.
That is only Workflow designer with fixed rigid necessities.
First of all, there are 2 kind of friendlinesses:
- user-friendliness for user or biz analyst (that doesn't know anything
about programming - formats, standards, XML, underlying frameworks, Java)
- developer friendliness
As for developer friendliness I may tell, that it is impossible in my
context to specify all workflow only from client side:
- hierarchy of users are specified in the database (by data modeling) or in
LDAP;
- from the other side, current workflow designer (and therefore a new one I
recreate) permits Java scripting
http://www.beanshell.org/
It is again is not for END-users.
Developer-friendliness targets possibility to have flexibility to change the
compiled designer easily
From the other side there is no need for my designer in changing workflow
models and XML formats.
If to have more ambitious opensource multipurpose project interoperable
project like JWT you MISSED to note the main developer-friendliness or even
user-friendliness:
- it is ability to specify workflow models and this is somewhat
orthogonal/independent on graphic representations and XML formats
I couldn't understand your phrases:
What is the interest in thing without "value add"?
What do you mean under model instances?
For me the problem is that:
- compiled product (user-friendliness) should read definitions of Workflow
and for Workflow Nodes for sidebar to insert in workflow inside the same
defintion of Workflow model (in GEF with EMF there are really EMF ECore
metamodel to 4 others models in XMI, Java, etc. that should be syncronized);
- for developer ("developer-friendliness") I should easily redefine models
or read it from a file and recompile product
This was what I missed in GEF with EMF. If I specify models through EMF
ECore metamodel (and then recieve models in Java, XMI, etc.), I should do
all through EMF ECore model.
And my requirement is to introduce/adjust my own XML/XMI format according to
my XSD.
How do I change it?
I didn't have much time to understand it but as I understood EMF XMI is
given? How can I change XSD for EMF XMI and for EMF ECore model?
It is also the same problem as why, for ex., MyEclipse (plugin) doesn't
recognize EMF XMI.
http://www.myeclipseide.com/PNphpBB2+file-viewtopic-t-10320. html
Let me remind that MyEclipse permits UML, dataabase modeling,
reverse-engineering (but not with EMF formats)
Interoperability with tools! Isn't it JWT objective. As a matter of fact I
even do not know which free tools work with EMF!!! See my earlier posts on
having problems with OmondoEclipseUML
http://www.forum-omondo.com/viewtopic.php?t=827
Yeeeah. I have contrary reuirement. Nobody wants to study EMF and would like
to redefine everything in kust XML
Can you give any links on Object-XML mapping and ECore XMI redefinition
according to XSD
It all seemed to me as the problems for other frameworks and projects
outside of GEF and EMF
There a lot of very interesting things in the world (and I have only 24 H in
my day)
GMF to me is, so far, is not even conceptual issues. It is a tool for GEF
with EMF work
(that IMHO doesn't address many conceptual issues)
> seems not sufficiently stable to use it... I will give it a new try using
me too
Guennadi Vanine
impossible to specify (dynamic) behaviours thru static modeling tools [message #15118 is a reply to message #13425] |
Fri, 13 January 2006 23:03 |
The problem with EMF XSD is that it specifies static models throgh
class-types diagrams.
But how shall I attach to GEF with EMF some dynamic elements?
How shall I change at tun-time XSD? I do not know what user will enter and
cannot specify it thru model.
I need to attach to graphical elements (workflow nodes) specified thru model
some datastructures of arbitrary format at runtime.
I have graphical elements - workflow nodes.
And I need to double click it in a datagrid windows (or in property view)
add data and it should be incorporated inside XML of workflow elements
definitions but at run-time.
How shall I incorporate this into EMF XML?
I have a reuirement to have final XML representation to be fused in one XML
before deployment to server side BPM engine.
One of the thought (amongst other) that I have is to produce the EMF ECore
model once and then just use the produced Java code for manual hacking
This problem is quite similar to the problem of incompatibility with Swing
use.
Any modeling tools, frameworks are for static specification, some predefined
during modeling carcass but I do not know any application without dynamic
behaviour.
Guennadi Vanine
"Guennadi Vanine" <vgv8@yahoo.com.br> wrote in message
news:dq9a8n$pa2$1@utils.eclipse.org...
> Fabrice:
> a month
> another project).
> in LDAP;
> I recreate) permits Java scripting
> the compiled designer easily
> even user-friendliness:
> syncronized);
> to my XSD.
> How do I change it?
> recognize EMF XMI.
> like to redefine everything in kust XML
> according to XSD
> in my day)
> with EMF work
> me too
> Guennadi Vanine
static vs dynamic data [message #15139 is a reply to message #15118] |
Fri, 13 January 2006 23:37 |
Once more.
Any Workflow Designer should permit adding data at run-time according to
somewhat in end-user mind (it is not just editing graphics).
EMF with GEF is very good to specify a priory known during modeling behavior
and structure of purely graphical elements specified at modeling time.
When you redefine the EMF ECore model u should resyncronize, regenerate from
it Java, XMI, XSD models.
But how do someone attach to statically specified structures and behaviours
dynamic data at run-time?
But it doesn't help and even to the contrary to run-time necessities
I should somehow:
- separate static, definable during modeling structures (workflow nodes
coordinates, shapes, etc.),
- attach to them at run-time dynamic data,
- fuse both in one XML file for deployment
- upload, deploy to server BPM engine
and permit the contrary order:
- download workflow definition
- distinguish pure graphic and semantic data for further editing
If GEF with EMF helps treating just visual (static or known during modeling)
data, with pure graphical editors, workflow editors should attach unknown
beforehand data
Might be I miss something but for workflow editors, EMF arquitecture
complicate instead of helping things.
At least, I could not find any ready answers to these problems. I just
should study other frameworks, projects. But I am not sure that EMF is right
architecture at all for this (though it depends, as I told many times, on
resources and scope of project. Mine is not to define frameworks but create
specific application)!
You may contact me for on-line discussion at:
MSN Messenger: VGV888<AT>HOTMAIL.com
YAHOO IM: VGV8
Guennadi Vanine
I looked in [message #15172 is a reply to message #10241] |
Sat, 14 January 2006 02:52 |
Hi, Carhlie and all,
I tried to look in IX Workflow Modeler (upon your pointing)
but couldn't download it (the links are broken)
I couldn't get download, then the forum has 2 posts for 1.5 years
(1 visitor question and one reply)
My dream to be the first or second one came true, I am the second registered
user there.
Look for more details in my post there in forum.
But it is not exactly what I need - I need associate to graphical elements
(Workflow Nodes) a data (by Datagrid, Property View) at RUNTIME and
incorporate it in the same XML-file describing workflow. That simple in
Swing and that complicated with EMF.
I am just impressed by the volume of the OpenSource projects, their support
and absence of any interest. Kind of decentralization, desintegration that
jump into eyes after .NET flourishing communities.
Guennadi Vanine
"Charlie" <cafulnecky@yahoo.com> wrote in message
news:dpv5pg$g5s$1@utils.eclipse.org...
> Charlie
and where is the trick? [message #15476 is a reply to message #15377] |
Sun, 15 January 2006 15:19 |
Hi, Charlie,
Here is conceptual problem with any modeling.
It is impossible to add to statical models (specified through
"class-diagram" type static) behavioral artifacts. No such tools were
invented conceptually.
And even for such static modeling in EMF, there are no free integrated
trustworthy tools.
I do not see how to make a trick with EMF. I cannot restrict a user to some
GENERIC template for adding data at run-time and then fuse it in one XML
with pure graphical data (on shapes).
Guennadi Vanine
Current Time: Wed Apr 24 19:41:11 GMT 2024
Powered by FUDForum. Page generated in 0.03154 seconds
