Re: TreeViewer scattering [message #112607 is a reply to message #112594] |
Tue, 18 November 2008 09:31 |
Originally posted by: rsternberg.innoopract.com
Hi Daniel,
Daniel Zweifel wrote:
> I've seen the same effect in our application when enabling/disabling a
> filter for the entries in the tree.
could you add that information to the bug mentioned?
Thank you, Ralf
> Benjamin Muskalla wrote:
>> Hi,
>> this issue looks like 244952: [Tree] replacing child nodes leads to
>> overlap [https://bugs.eclipse.org/bugs/show_bug.cgi?id=244952]. The
>> fundamental problem is a bug in the qooxdoo tree widget.
>> As qooxdoo will not solve this bug in the 0.7 stream we may consider
>> to look if we can work around it. I'm not sure if this is possible but
>> I'll try to investigate.
>> Greets
>> Benny
>> Michal NkD Nikodím wrote:
>>> Hi,
>>> I am using TreeeViewer with filtering and there are possible bug.
>>> All in included snippet view.
>>> Step 01 show initial state of Snippet view.
>>> Step 02 filter by letter 'e'
>>> Step 03 clear filter and collapse node "presonal car"
>>> Step 04 filter by letter 'e' => scattering
>>> Tested on RAP 1.1 and 1.2 M2 . Both have same bug.
>>> Maybe I have some wrong code in snippet. Maybe I don't some thing
>>> with providers for TreeViewer which I have to. Please could you look
>>> this ?
>>> Thx
FUDForum. Page generated in 0.03634 seconds
