Home » Eclipse Projects » Remote Application Platform (RAP) » cross scripting issues - can RAP serve HTML documents?
cross scripting issues - can RAP serve HTML documents? [message #111489] Thu, 06 November 2008 16:50 Go to next message
Alex is currently offline AlexFriend
I need to access the elements of an HTML page which is embedded in a
custom widget using a qx.ui.embed.Iframe
Currently the embedded HTML page is served by an apache running on
localhost:80, while RAP is running on localhost:9090. If I understood
correctly, security measures restrict the Iframe object from modifying the
embedded contents or executing javascript, because they come from a
different server.
My simple question is, what is necessary to serve the embedded document
(up to now http://localhost/tmp/test.html) from the RAP server, for
example at http://localhost:9090/resources/test.html?
My guess was that I have to define an extension at point
org.eclipse.rap.ui.resources with a class that implements
org.eclipse.rwt.resources.IResource. However defining "public String
getLocation() { return "resources/test.html"; }" in that class doesn't
serve the file (resource/test.html in the project tree) at
http://localhost:9090/resources/test.html. What is wrong?
Thank you
Alex
Re: cross scripting issues - can RAP serve HTML documents? [message #111530 is a reply to message #111489] Thu, 06 November 2008 18:31 Go to previous messageGo to next message
Stefan   is currently offline Stefan Friend
Hi Alex,
you can use the extension point
"org.eclipse.equinox.http.registry.resources" to specify a directory
with your html-files. The field "alias" would be "/resources" (same as
in URL), the field "base-name" must point the location in your bundle,
where these html-files are (e.g. "/html").
Hope that helps,
Stefan.
Alex schrieb:
> Hello,
> the embedded contents or executing javascript, because they come from a
> different server.
> Thank you
> Alex
Re: cross scripting issues - can RAP serve HTML documents? [message #111543 is a reply to message #111530] Thu, 06 November 2008 19:55 Go to previous messageGo to next message
Thank you Stefan,
I think this is exactly what I'm looking for. However, I'm using the the
jetty server (this is the default, isn't it?) not the equinox http server.
Nevertheless I followed your suggestion, but accessing the test page
leaves a blank page (no background image, no error message). Is the
org.eclipse.equinox.http.registry.resources extension point supposed to
work with the jetty server, or is there another solution for jetty, or do
I have to configure RAP to use the equinox server (how)?
Alex
Stefan Roeck wrote:
> Hi Alex,
> Hope that helps,
> Stefan.
Re: cross scripting issues - can RAP serve HTML documents? [message #111556 is a reply to message #111530] Thu, 06 November 2008 21:21 Go to previous message
It works as you wrote. First I inserted some typos which caused troubles,
but now it's fine.
Thank you
Alex
Stefan Roeck wrote:
> Hi Alex,
> Hope that helps,
> Stefan.
Previous Topic:RAP 1.2 M2 target platform package, wrong content??
Next Topic:Changing tree node image when expanding/collapsing
Current Time: Tue Mar 21 14:19:06 GMT 2023
Powered by FUDForum. Page generated in 0.02531 seconds
