Re: Modifying a file that's not open in an editor? [message #865444 is a reply to message #865169] |
Mon, 30 April 2012 11:55   |
Sebastian Zarnekow Messages: 3108 Registered: July 2009 |
Hi Stephan,
please file a ticket. IModificationContext#getXtextDocument could work
with the plain IXtextDocument and use the IDocumentProvider to save the
changes.
You may want to customize the
org.eclipse.xtext.ui.editor.model.edit.IssueModificationContext.Factory
to achieve that for your language.
Sebastian
Am 30.04.12 11:13, schrieb Stephan Herrmann:
> Thanks for suggestions.
> Christian Dietrich wrote on Fri, 27 April 2012 21:48
>> Hi,
>> what about letting Xtext opening the editor for you by calling
>> org.eclipse.xtext.ui.editor.model.edit.IModificationContext.getXtextDocument(URI)
>> ~Christian
> This seems to be the one closest to what I want to do, great.
> One caveat: it seems the URI must be a platform URI, classpath: doesn't
> work (might be worth documenting in API doc :)
> Actually opening editors for secondary files is tolerable in my case
> since normally only one additional file is affected. However, if a quick
> fix should affect more files opening all these might become an issue.
> Especially when I start implementing refactorings I don't want to open
> all affected files in editors.
> Is there any other API for rewriting that does not depend on an editor?
> Anything similar to JDT's ASTRewrite? (I wouldn't want to go back to
> serializing entire files because the layout of the source code must be
> preserved as much as possible.)
> thanks,
> Stephan
FUDForum. Page generated in 0.03006 seconds
