Home » Archived » BIRT » client size graph resize(using javascript to resize graph from JSP)
client size graph resize [message #859482] Fri, 27 April 2012 17:00 Go to next message
Missing name Missing name is currently offline Missing name Missing nameFriend
Member
I currently am running my graph in a birt viewer within my application on a JSP. I give the user the option to minimize/maximize the chart using an onclick js function. I have figured out how to enlarge the birt viewer/iframe, however, the graph/image remains the same size. Is there any way to enlarge the image as well?
here is my current code that works to enlarge/shrink the birt viewer, but as mentioned before, the graph remains the same size within the viewer:
<birt:report
id="blah"
reportDesign="blahblah.rptdesign"
isHostPage="false"
height="250"
width="444"
format="html">
</birt:report>
<script type="text/javascript">
function chartGrow(){
var x = document.getElementsByTagName("iframe");
x[0].style.height = 500 + "px";
x[0].style.width = 888 + "px";
function chartShrink(){
x[0].style.height = 250+"px";
x[0].style.width = 444+"px";
</script>
Re: client size graph resize [message #859948 is a reply to message #859482] Fri, 27 April 2012 21:55 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
I am assuming you do not want to execute the report again. The chart is
just an image (Except for SVG output), so you may be able to use various
methods described here:
http://stackoverflow.com/questions/170624/javascript-image-resize
to get a handle on the image use getElementById. To set the id for a
chart select the chart in the designer and then click on the bookmark
property in the properties editor. If you enter "testchart" The
following will be generated in the output html.
<img id="testchart"
src="/viewer/preview?__sessionId=20120427_174940_821&amp;__imageid=custom834c87136f5c7e8361.png"
alt="" style=" width: 427.5pt; height: 262.5pt;display: block;"></img>
If you do not mind re-running the report you can put script in to set
the size:
http://birtworld.blogspot.com/2008/04/birt-resizing-charts.html
Jason
> <birt:report id="blah"
> isHostPage="false"
> height="250"
> width="444"
> format="html">
> </birt:report>
> </script>
Re: client size graph resize [message #865554 is a reply to message #859948] Mon, 30 April 2012 13:04 Go to previous messageGo to next message
Member
Jason,
that sounds like exactly what i wanted, however, i am using API to build the image, is there any way to set the image ID name using the API?
thanks,
John
Re: client size graph resize [message #865736 is a reply to message #865554] Mon, 30 April 2012 14:41 Go to previous messageGo to next message
John,
In your first post it looked like you were using the birt report tag
libraries. How are you calling the API from your JSP?
Jason
On 4/30/2012 9:04 AM, Missing name Mising name wrote:
> Jason,
> thanks,
> John
Re: client size graph resize [message #865791 is a reply to message #865736] Mon, 30 April 2012 15:19 Go to previous messageGo to next message
Member
Jason,
sorry i should have specified how i was using everything. in my JSP i have the following:
<birt:report
id="blah"
reportDesign="smallChart.rptdesign"
isHostPage="false"
format="html"
height="250"
width="444">
</birt:report>
</script>
so the HTML output is actually:
<div id="params_blah" style='display:none'>
</div>
<form id="form_blah" method="post"></form>
function loadViewerblah(){
var formObj = document.getElementById( "form_blah" );
var paramContainer = document.getElementById("params_blah");
var oParams = paramContainer.getElementsByTagName('input');
if( oParams )
for( var i=0;i<oParams.length;i++ )
var param = document.createElement( "INPUT" );
param.type = "HIDDEN";
param.name= oParams[i].name;
param.value= oParams[i].value;
formObj.appendChild( param );
formObj.action = "/progname/preview?__report=smallChart.rptdesign&__masterpage=true&__format=html";
formObj.target = "blah";
formObj.submit( );
</script>
<iframe name="blah" frameborder="no" scrolling = "auto" style='height:250px;width:444px;' ></iframe>
<script type="text/javascript">loadViewerblah();</script>
</script>
and i have a java class that is contructing the graph using the API. since i am not getting an <img> tag i feel like there is no ID name for me to grab a hold of.
thanks
john
[Updated on: Mon, 30 April 2012 15:20]
Report message to a moderator
Re: client size graph resize [message #865909 is a reply to message #865791] Mon, 30 April 2012 16:32 Go to previous messageGo to next message
John,
Where in that code are you calling your class that creates the chart? I
saw this but generates the chart using the normal engine:
Jason
On 4/30/2012 11:19 AM, Missing name Mising name wrote:
> Jason,
> have the following:
> <birt:report
> id="blah"
> isHostPage="false"
> format="html"
> height="250"
> width="444">
> </birt:report>
> </script>
> </div>
> if( oParams )
> for( var i=0;i<oParams.length;i++ ) {
> formObj.action =
> formObj.submit( );
> </script>
> <iframe name="classic" frameborder="no" scrolling = "auto"
> </script>
> thanks
> john
Re: client size graph resize [message #865964 is a reply to message #865909] Mon, 30 April 2012 17:11 Go to previous messageGo to next message
Member
Jason,
I have created a method in a java file. in the action class i call that method and build the graph passing in parameters, whch allows me to run it dynamically. it then saves it within my application as a .rptdesign. from there i can call it in the jsp as i mentioned above. here is a cleaned out version of how i am building the graph using the API:
public class ChartBuildAction {
static Logger log = Logger.getLogger(ChartBuildAction.class);
ReportDesignHandle reportDesignHandle = null;
ElementFactory elementFactory = null;
IMetaDataDictionary dict = null;
ComputedColumn cs1, cs2 = null;
public static void main( String[] args ) throws SemanticException, IOException{
String save = "";
String key = "";
new ChartBuildAction( ).createReport(save, key,0,0,0,0,0,0,0);
Platform.shutdown();
log.debug("Finished");
public void createReport(String saveClause, String keyword, int num1, int num2, int num3, int num4, int num5, int num6, int num7) throws SemanticException, IOException
DesignConfig config = new DesignConfig( );
IDesignEngine engine = null;
try{
Platform.startup( config );
IDesignEngineFactory factory = (IDesignEngineFactory) Platform.createFactoryObject( IDesignEngineFactory.EXTENSION_DESIGN_ENGINE_FACTORY );
engine = factory.createDesignEngine( config );
}catch( Exception ex){
ex.printStackTrace();
SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
// Create a new report
reportDesignHandle = session.createDesign( );
// Element factory is used to create instances of BIRT elements.
elementFactory = reportDesignHandle.getElementFactory( );
dict = new DesignEngine( null ).getMetaData( );
createDataSources( );
createDataSets(keyword, num1, num2, num3, num4, num5, num6, num7 );
createStyles( );
createBody(keyword );
reportDesignHandle.saveAs( saveClause + "/smallChart.rptdesign" );//$NON-NLS-1$//$NON-NLS-2
private void createStyles( ) throws SemanticException{
StyleHandle labelStyle = elementFactory.newStyle( "Label" );//$NON-NLS-1$
labelStyle.setProperty( StyleHandle.FONT_WEIGHT_PROP,DesignChoiceConstants.FONT_WEIGHT_BOLD );
labelStyle.setProperty( StyleHandle.FONT_FAMILY_PROP, "Arial Black" );//$NON-NLS-1$
labelStyle.setProperty( StyleHandle.COLOR_PROP, "#FFFFFF" );//$NON-NLS-1$
StyleHandle dataStyle = elementFactory.newStyle( "Data" );//$NON-NLS-1$
dataStyle.setProperty( StyleHandle.FONT_WEIGHT_PROP,DesignChoiceConstants.FONT_WEIGHT_BOLD );
dataStyle.setProperty( StyleHandle.FONT_FAMILY_PROP, "Century" );//$NON-NLS-1$
dataStyle.setProperty( StyleHandle.COLOR_PROP, "#009B9B" );//$NON-NLS-1$
reportDesignHandle.getStyles( ).add( labelStyle );
reportDesignHandle.getStyles( ).add( dataStyle );
private void createBody(String keyword ) throws SemanticException
reportDesignHandle.getBody( ).add( createPieChart(keyword ) );
private ExtendedItemHandle createPieChart(String keyword){
ExtendedItemHandle eih = elementFactory.newExtendedItem("tinyChart", "Chart" );//$NON-NLS-1$
try
eih.setName("tinyChart");
eih.setHeight( "240pt" );//$NON-NLS-1$ used to be 235pt
eih.setWidth( "425pt" );//$NON-NLS-1$ used to be 420pt
eih.setProperty( ExtendedItemHandle.DATA_SET_PROP, "Data Set" );//$NON-NLS-1$
PropertyHandle computedSet = eih.getColumnBindings( );
cs1.setExpression( "dataSetRow[\"Name\"]" );//$NON-NLS-1$
computedSet.addItem( cs1 );
cs2.setExpression( "dataSetRow[\"Amount\"]" );//$NON-NLS-1$
computedSet.addItem( cs2 );
catch ( SemanticException e )
e.printStackTrace( );
ChartWithoutAxes cwoaPie = ChartWithoutAxesImpl.create( );
cwoaPie.setType( "Pie Chart" );//$NON-NLS-1$
cwoaPie.setSubType( "Standard Pie Chart" );//$NON-NLS-1$
cwoaPie.setDimension(ChartDimension.TWO_DIMENSIONAL_LITERAL);
cwoaPie.getPlot().getClientArea().getOutline().setVisible(false);
cwoaPie.getTitle( ).setVisible( true );
cwoaPie.getTitle().getLabel().getCaption().getFont().setSize(14);
cwoaPie.getTitle().getLabel().getCaption().setValue("SNAP");
cwoaPie.getBlock( ).setBounds( BoundsImpl.create( 0, 0, 500, 240 ) ); //DO NOT DELETE!!!!!!
cwoaPie.getBlock( ).setBackground( GradientImpl.create( ColorDefinitionImpl.create( 197, 217, 224 ),ColorDefinitionImpl.create( 255,255,255 ),-30,false ) );
cwoaPie.getPlot( ).getClientArea( ).setBackground( ColorDefinitionImpl.TRANSPARENT( ) );
Legend chartLeg = cwoaPie.getLegend();
chartLeg.getClientArea().getOutline().setVisible(false);
chartLeg.setOrientation(Orientation.HORIZONTAL_LITERAL);
chartLeg.getText().getFont().setWordWrap(true);
chartLeg.getText().getFont().setSize(8);
chartLeg.setPosition(Position.BELOW_LITERAL);
if(keyword.contains("MA")){
chartLeg.getInsets().setLeft( -2 );
chartLeg.getInsets().setRight( 10 );
}else{
chartLeg.getInsets().setRight( -2 );
chartLeg.getInsets().setBottom( -2 );
chartLeg.getInsets().setTop(-2);
chartLeg.setBackground( ColorDefinitionImpl.TRANSPARENT( ) );
SampleData sd = DataFactory.eINSTANCE.createSampleData( );
BaseSampleData sdBase = DataFactory.eINSTANCE.createBaseSampleData( );
sdBase.setDataSetRepresentation( "Category-A, Category-B" );//$NON-NLS-1$
sd.getBaseSampleData( ).add( sdBase );
OrthogonalSampleData sdOrthogonal = DataFactory.eINSTANCE.createOrthogonalSampleData( );
sdOrthogonal.setDataSetRepresentation( "4,12" );//$NON-NLS-1$
sdOrthogonal.setSeriesDefinitionIndex( 0 );
sd.getOrthogonalSampleData( ).add( sdOrthogonal );
cwoaPie.setSampleData( sd );
Series seCategory = SeriesImpl.create( );
Query query = QueryImpl.create( "row[\"Name\"]" );//$NON-NLS-1$
seCategory.getDataDefinition( ).add( query );
SeriesDefinition series = SeriesDefinitionImpl.create( );
series.getSeries( ).add( seCategory );
cwoaPie.getSeriesDefinitions( ).add( series );
PieSeries ps = (PieSeries) PieSeriesImpl.create( );
ps.setExplosion(4);
Query query2 = QueryImpl.create( "row[\"Amount\"]" );//$NON-NLS-1$
ps.getDataDefinition( ).add( query2 );
ps.setSliceOutline(ColorDefinitionImpl.BLACK());
cwoaPie.setScript(
"var allnull = true;"+
"function afterDataSetFilled( series, dataSet, icsc ){"+
"if( series.getSeriesIdentifier() == '' ){"+
"var list = dataSet.getValues();"+
"for(i=0;i<list.length;i++){"+
"if( list[i] > 0 && list[i] != null){"+
"allnull = false;"+
"function beforeRendering( gcs, icsc ){"+
"var chart = gcs.getChartModel();"+
"if( allnull ){"+
"chart.getPlot().setVisible(false);"+
"var svheight = chart.getPlot().getBounds().getHeight();"+
"var svwidth = chart.getPlot().getBounds().getWidth();"+
"chart.getPlot().getBounds().setHeight(0);"+
"chart.getPlot().getBounds().setWidth(0);"+
"chart.getTitle().getBounds().setHeight(svheight);"+
"chart.getTitle().getBounds().setWidth(svwidth);"+
"function beforeGeneration( cm, icsc ){"+
"if( allnull ){" +
"cm.getPlot().getOutline().setVisible(true);"+
"cm.getTitle().getLabel().getCaption().setValue('There is No Data to Display');"+
"function beforeDrawDataPointLabel( dph, label, icsc ){"+
"if( label.getCaption().getValue() == '0%' ){"+
"label.setVisible(false);"+
cwoaPie.getTitle().getLabel().getCaption().getFont().setName("Arial");
cwoaPie.getTitle().getLabel().getCaption().setColor(ColorDefinitionImpl.create(6, 55, 95));
cwoaPie.getTitle().getLabel().getCaption().getFont().setWordWrap(true);
ps.getLabel().getCaption().getFont().setSize(9);
ps.getLabel().getCaption().getFont().setBold(true);
ps.getLabel().getCaption().setColor(ColorDefinitionImpl.BLACK());
SeriesDefinition seGroup = SeriesDefinitionImpl.create( );
series.getSeriesDefinitions( ).add( seGroup );
seGroup.getSeries( ).add( ps );
series.getSeriesPalette().getEntries( ).clear( );
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(117,168,250));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(243,239,100));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(255,100,100));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(102,229,142));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(204,243,255));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(249,188,236));
series.getSeriesPalette().getEntries().add( ColorDefinitionImpl.create(255,191,0));
DataPointComponent dpc = DataPointComponentImpl.create( DataPointComponentType.PERCENTILE_ORTHOGONAL_VALUE_LITERAL,JavaNumberFormatSpecifierImpl.create( "##%") );//$NON-NLS-1$
ps.getDataPoint( ).getComponents( ).clear( );
ps.getDataPoint( ).getComponents( ).add( dpc );
ps.getLeaderLineAttributes().setVisible(false);
ps.setLabelPosition(Position.INSIDE_LITERAL);
Trigger mouseOver = TriggerImpl.create(TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create(150, null)));
ps.getTriggers().add(mouseOver);
try
//Add chart instance to IReportItem
eih.getReportItem( ).setProperty( "chart.instance", cwoaPie );//$NON-NLS-1$
catch ( ExtendedElementException e )
return eih;
private void createDataSources( ) throws SemanticException
ScriptDataSourceHandle dataSourceHandle = elementFactory.newScriptDataSource( "Data Source" );//$NON-NLS-1$
reportDesignHandle.getDataSources( ).add( dataSourceHandle );
private void createDataSets(String keyword, int num1, int num2, int num3, int num4, int num5, int num6, int num7 ) throws SemanticException
if(num1 <= 0){num1 = 0;}
if(num2 <= 0){num2 = 0;}
if(num3 <= 0){num3 = 0;}
if(num4 <= 0){num4 = 0;}
if(num5 <= 0){num5 = 0;}
if(num6 <= 0){num6 = 0;}
if(num7 <= 0){num7 = 0;}
ScriptDataSetHandle dataSetHandle = elementFactory.newScriptDataSet( "Data Set" );//$NON-NLS-1$
dataSetHandle.setDataSource( "Data Source" );//$NON-NLS-1$
int endNum = 0;
endNum = 7;
dataSetHandle.setOpen( "i=0;"//$NON-NLS-1$
+ "sourcedata = new Array( new Array(2), new Array(2), new Array(2), "//$NON-NLS-1$
+ "new Array(2), new Array(2), new Array(2), new Array(2));"//$NON-NLS-1$
+ "sourcedata[0][0] = \"Pending > 90 Days\";"//$NON-NLS-1$
+ "sourcedata[0][1] = "+num1+";"//$NON-NLS-1$
+ "sourcedata[1][0] = \"Pending > 60 Days\";"//$NON-NLS-1$
+ "sourcedata[1][1] = "+num2+";"//$NON-NLS-1$
+ "sourcedata[2][0] = \"Pending > 45 Days\";"//$NON-NLS-1$
+ "sourcedata[2][1] = "+num3+";"//$NON-NLS-1$
+ "sourcedata[3][0] = \"Pending > 30 Days\";"//$NON-NLS-1$
+ "sourcedata[3][1] = "+num4+";"//$NON-NLS-1$
+ "sourcedata[4][0] = \"Pending < 30 Days\";"//$NON-NLS-1$
+ "sourcedata[4][1] = "+num5+";"//$NON-NLS-1$
+ "sourcedata[5][0] = \"Active No Action\";"//$NON-NLS-1$
+ "sourcedata[5][1] = "+num6+";"//$NON-NLS-1$
+ "sourcedata[6][0] = \"Active Needs Action\";"//$NON-NLS-1$
+ "sourcedata[6][1] = "+num7+";" );//$NON-NLS-1$
dataSetHandle.setFetch( "if ( i < "+ endNum +" ){"//$NON-NLS-1$
+ "row[\"Name\"] = sourcedata[i][0];"//$NON-NLS-1$
+ "row[\"Amount\"] = sourcedata[i][1];"//$NON-NLS-1$
+ "i++;"//$NON-NLS-1$
+ "return true;}" + "else return false;" );//$NON-NLS-1$//$NON-NLS-2$
cs1 = StructureFactory.createComputedColumn( );
cs1.setName( "Name" );//$NON-NLS-1$
cs1.setExpression( "row[\"Name\"]" );//$NON-NLS-1$
cs1.setDataType( "string" );//$NON-NLS-1$
cs2 = StructureFactory.createComputedColumn( );
cs2.setName( "Amount" );//$NON-NLS-1$
cs2.setExpression( "row[\"Amount\"]" );//$NON-NLS-1$
cs2.setDataType( "integer" );//$NON-NLS-1$
PropertyHandle computedSet = dataSetHandle.getPropertyHandle(
ScriptDataSetHandle.COMPUTED_COLUMNS_PROP );
reportDesignHandle.getDataSets( ).add( dataSetHandle );
Re: client size graph resize [message #867931 is a reply to message #865964] Tue, 01 May 2012 14:57 Go to previous messageGo to next message
When you create the chart and have the extended item handle just set the
bookmark on it like:
eih.setBookmark("\"MyChart\"");
Jason
On 4/30/2012 1:11 PM, Missing name Mising name wrote:
> Jason,
> IOException{
> String save = "";
> String key = "";
> try{
> } SessionHandle session = engine.newSessionHandle( ULocale.ENGLISH ) ;
> createStyles( );
> );//$NON-NLS-1$
> );//$NON-NLS-1$
> try
> );//$NON-NLS-1$
> }else{
> ps.setExplosion(4);
> cwoaPie.setScript(
> "allnull = false;"+
> "if( allnull ){"+
> "function beforeGeneration( cm, icsc ){"+ "if( allnull ){" +
> Display');"+
> 55, 95));
> Trigger mouseOver =
> ps.getTriggers().add(mouseOver); try
> return eih;
> int endNum = 0;
> endNum = 7;
> "//$NON-NLS-1$
Re: client size graph resize [message #868009 is a reply to message #867931] Tue, 01 May 2012 15:45 Go to previous messageGo to next message
Member
Jason,
I am still unable to grab img after setting the bookmark and attempteding to use getElementByID. It claims that there is no object. I noticed earlier you had said doing this would cause the HTML to look like this:
<img id="testchart"
this is in the case that the bookmark is set as "testchart". I am getting a different output than the <img> tags, i am getting the following (even after setting the bookmark as "birtGraph"):
</div>
if( oParams )
formObj.submit( );
</script>
var graph = document.getElementById("birtGraph");
alert("offsetHeight = " + graph.offsetHeight);
Re: client size graph resize [message #868064 is a reply to message #868009] Tue, 01 May 2012 16:19 Go to previous messageGo to next message
Can you try and add reportContainer=div to your birt report tag?
Jason
On 5/1/2012 11:45 AM, Missing name Mising name wrote:
> Jason,
> like this:
> <img id="testchart"
> src="/viewer/preview?__sessionId=20120427_174940_821&__imageid=custom834c87136f5c7e8361.png"
> </div>
> if( oParams )
> formObj.action =
> formObj.submit( );
> </script>
Re: client size graph resize [message #868141 is a reply to message #868064] Tue, 01 May 2012 17:10 Go to previous messageGo to next message
Member
Jason,
adding the "reportContainer" tag allowed me to grab both the viewer and the image using getElementByID and the resizing worked as well.
thanks for all your help
john
Re: client size graph resize [message #868373 is a reply to message #868141] Tue, 01 May 2012 20:54 Go to previous messageGo to next message
Member
Jason,
as i mentioned before i am now able to grab both the image and the frame. The frame enlarges perfectly, however i am still having a slight issue with the image...
here is the JS function i am using:
var x = document.getElementById("blah");
x.style.width = 850+"px";
x.style.height = 400+"px";
graph.style.width = 600+"pt";
graph.style.height = "auto";
this function works to enlarge the image, however, it only enlarges the graphics, the bounds of the image still remain the same, so it cuts off. for example the actual image does enlarge, however, the image frame (not the iframe, but the bounds of the actual image itself) stays the same, and the image cuts off halfway through the graph so you only see a portion of it. I believe it is enlargeing the image, but the size of the image is already pre-definied from inside my java class when i use "eih.setHeight()" and "eih.setWidth()". Its hard to describe, but after altering the size, i only see half my image, and the other half is cut off, as if the graphic is too big for the image, so instead of a full pie, im getting a half circle, and my legend is cut off as well.
is there any way that i can alter the eih.setHeight/width size settings using javascript or am i only able to enlarge the actual graphic, but not the image?
thanks,
john
Re: client size graph resize [message #869667 is a reply to message #868141] Tue, 01 May 2012 20:54 Go to previous messageGo to next message
Member
Jason,
thanks,
john
Re: client size graph resize [message #869669 is a reply to message #868373] Tue, 01 May 2012 21:50 Go to previous message
Is the chart type an image or svg. Try png. Look at the attached
example report and run it.
Jason
On 5/1/2012 4:54 PM, Missing name Mising name wrote:
> Jason,
> not the image?
> thanks,
> john
Previous Topic:Bar chart x-axis labels
Next Topic:[PROBLEM] Viewer to PDF.
Current Time: Mon Mar 20 12:46:11 GMT 2023
Powered by FUDForum. Page generated in 0.03064 seconds
