Home » Modeling » UML2 » UML2 to Java Literals
Re: UML2 to Java Literals [message #873162 is a reply to message #859116] |
Thu, 17 May 2012 16:05 |
Rogério Costa Messages: 5 Registered: April 2012 |
This is my Atl configuration, hope this help a little more ... Should I need to register something more?
* To change this template, choose Tools | Templates
* and open the template in the editor.
public class UML2_2_JAVA extends AbstractPIMPSM_Factory
private IInjector injector;
private IExtractor extractor;
private IReferenceModel sourceMetamodel;
private IReferenceModel targetMetamodel;
private String transformationFilepath = null;
private String sourceMetaModelFilepath = null;
private String targetMetaModelFilepath = null;
private String sourceDataFilepath = null;
private String targetDataFilepath = null;
private IModel targetModel;
private IModel sourceModel;
private ModelFactory factory;
private ILauncher launcher;
public UML2_2_JAVA()
super();
public IModel getTargetModel()
return this.targetModel;
/// From now on, there are the functions
public void doCore() throws ATLCoreException
CoreService.registerLauncher("EMF-specific VM", EMFVMLauncher.class);
CoreService.registerFactory("EMF", EMFModelFactory.class);
CoreService.registerExtractor("EMF", EMFExtractor.class);
CoreService.registerInjector("EMF", EMFInjector.class);
injector = CoreService.getInjector("EMF");
extractor = CoreService.getExtractor("EMF");
// Defaults
this.factory = CoreService.getModelFactory("EMF");
/*Resource specification*/
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("ecore", new EcoreResourceFactoryImpl());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("xmi", UMLResource.Factory.INSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
/*Type specification*/
EPackage.Registry.INSTANCE.put(UMLPackage.eNS_URI, UMLPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("ecore", EcorePackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("h**p://www.omg.org/spec/UML/20110701", UMLPackage.eINSTANCE);
EPackage.Registry.INSTANCE.put("h**p://www.omg.org/spec/XMI/20110701", UMLPackage.eINSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("j2se5", new EcoreResourceFactoryImpl());
public void doMetaModels(String sourceTargetMMPath) throws ATLCoreException
{ this.doMetaModels(sourceTargetMMPath, null); }
public void doMetaModels(String sourceMMPath, String targetMMPath) throws ATLCoreException
// Metamodels
this.sourceMetaModelFilepath = sourceMMPath;
sourceMetamodel = factory.newReferenceModel();
injector.inject(sourceMetamodel, UMLPackage.eNS_URI);
if(targetMMPath != null) //This means, the metamodel is the same for both models (InputModel & OutputModel)
this.targetMetaModelFilepath = targetMMPath;
targetMetamodel = factory.newReferenceModel();
injector.inject(targetMetamodel, URI.createFileURI(targetMetaModelFilepath).toString());
public void doModels(String sourceDM) throws ATLCoreException
/// Creating models
sourceModel = factory.newModel(sourceMetamodel);
if(this.targetMetamodel == null)
{ targetModel = factory.newModel(this.sourceMetamodel);}
else
{ targetModel = factory.newModel(this.targetMetamodel); }
// Loading existing model
this.sourceDataFilepath = sourceDM;
injector.inject(sourceModel, URI.createFileURI(sourceDM).toString());
public void doTrans(String transformationPath) throws ATLCoreException, MalformedURLException, IOException
// Getting launcher
launcher = (EMFVMLauncher)CoreService.getLauncher("EMF-specific VM");
launcher.initialize(Collections.<String, Object> emptyMap());
// Launching //TODO: REVER ISTO
launcher.addInModel(sourceModel,"IN", "UML");
launcher.addOutModel(targetModel, "OUT", "JAVA");
// the loadModule function requires an absolute path to the ASM file
this.transformationFilepath = transformationPath;
URL asmFile = new File(transformationPath).toURI().toURL();
Object loadedModule = launcher.loadModule(asmFile.openStream());
//launcher.addLibrary("libName", new File("path").toURI().toURL().openStream());
Map <String, Object> optionsTransf = new TreeMap <String, Object>();
optionsTransf.put("showSummary", "true");
optionsTransf.put("printExecutionTime", "true");
optionsTransf.put("continueAfterError", "true");
optionsTransf.put("allowInterModelReferences", "true");
//optionsTransf.put("step", "true");
launcher.launch(ILauncher.DEBUG_MODE, new NullProgressMonitor(), optionsTransf, loadedModule);
* Saving model
public void doSave(String dataTargetfp) throws ATLCoreException
this.targetMetaModelFilepath = dataTargetfp;
//extractor.extract(targetModel, System.out, null);
extractor.extract(targetModel, URI.createFileURI(dataTargetfp).toString());
Re: UML2 to Java Literals [message #873228 is a reply to message #873162] |
Thu, 17 May 2012 18:50 |
Ed Willink Messages: 7655 Registered: July 2009 |
Your original message seems to have fallen foul of the forum/newsgroup
synchronisation bug and not been sent to the newsgroups that are usually
the more reliable and consequently are the outlet monitored by committers.
An ATL query is more likely to get a response on the ATL than UML
newsgroups.
Ed Willink
> super();
> injector = CoreService.getInjector("EMF"); extractor =
> // Defaults
> @Override
> ATLCoreException
> @Override
> { // Metamodels
> targetMetamodel =
> @Override
> /// Creating models
> else
> URI.createFileURI(sourceDM).toString()); }
> // Getting launcher
> VM"); launcher.initialize(Collections.<String, Object>
> emptyMap());
> the ASM file
> <String, Object>();
> optionsTransf, loadedModule); }
> * Saving model
Current Time: Fri Apr 19 20:58:18 GMT 2024
Powered by FUDForum. Page generated in 0.02895 seconds
