Home » Modeling » TMF (Xtext) » Woes migrating to 2.2.1 from 2.0.1 - need help
Woes migrating to 2.2.1 from 2.0.1 - need help [message #858055] |
Fri, 27 April 2012 01:32 |
Henrik Lindberg Messages: 2509 Registered: July 2009 |
In geppetto we have been on version 2.0.1 for some time and decided to
upgrade to 2.2.1.
Now I am facing issues regarding "build clean" and my linker not being
called. The symptoms are that problems reported by validation are
handled correctly, but problems added by the linker are not.
"Build clean" no longer seem to trigger linking of everything (it does
not hit my breakpoint). All I get is that the markers from linking
disappear, but the linker is then not called.
If I open a file, it gets validated and error markers appear. I have to
open each file to see all the errors.
In the console I sometimes see messages like this (when a file with
errors is opened):
!ENTRY org.eclipse.core.resources 4 376 2012-04-27 02:12:45.951
!MESSAGE Marker id 224733 not found.
I debugged and found that in 2.0.1 I received two calls to the linker
when doing a clean - in 2.2.1 only one.
What I do in MyLinker#afterModelLinked (in a separate class) is:
@Inject
private org.eclipse.xtext.resource.impl.ResourceDescriptionsProvider
indexProvider;
IResourceDescriptions descriptionIndex =
indexProvider.getResourceDescriptions(resource);
IResourceDescription descr =
descriptionIndex.getResourceDescription(resource.getURI());
When doing a "build clean", desc becomes null. So in 2.0.1, I just
waited for the second call, and then did the linking - if descr is null,
I just return from MyLinker#afterModelLinked.
Are there any particular things that changed that I should have taken
care of?
I also tried updating to 2.3.0, but there I found that xtext.builder and
xtext.ui requires xtext.xbase (and as a consequence many additional
depdendencies). I really don't want to include xbase since it is not
used. Should this be reported as a bug, or is the dependency on xbase
suppose to be there - if so, for what?
- henrik
Re: Woes migrating to 2.2.1 from 2.0.1 - need help [message #858745 is a reply to message #858055] |
Fri, 27 April 2012 09:19 |
Ed Willink Messages: 7655 Registered: July 2009 |
I avoid the dependencies by having a separate 'build'; plugin for the
*.mwe2 and ... releng scripts. Worth doing even for 2.0 or 1.0.
Ed Willink
On 27/04/2012 02:32, Henrik Lindberg wrote:
> upgrade to 2.2.1.
> to open each file to see all the errors.
> errors is opened):
> @Inject
> indexProvider;
> null, I just return from MyLinker#afterModelLinked.
> care of?
> and xtext.ui requires xtext.xbase (and as a consequence many
> additional depdendencies). I really don't want to include xbase since
> it is not used. Should this be reported as a bug, or is the dependency
> on xbase suppose to be there - if so, for what?
> Regards
> - henrik
Re: Woes migrating to 2.2.1 from 2.0.1 - need help [message #858797 is a reply to message #858055] |
Fri, 27 April 2012 09:45 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Henrik,
I'm not aware of any deps to xbase itself from the xtext core bundles.
We use the xbase.lib which contains very few utilitiy classes and has no
actual dependencies. What problems did you face with that?
We loaded the resource twice in Xtext 2.0. This happens only once, now,
thus the linking is not triggered twice. You may want to checkout
LazyLinkingResource#resolveLazyCrossReferences. It may be possible to
trigger the #afterModelLinked stuff manually prior to resolving the
cross references.
If I'm not mistaken the concept of the
org.eclipse.xtext.resource.DerivedStateAwareResource may help.
Sebastian
Am 27.04.12 03:32, schrieb Henrik Lindberg:
> upgrade to 2.2.1.
> errors is opened):
> @Inject
> indexProvider;
> care of?
> Regards
> - henrik
Re: Woes migrating to 2.2.1 from 2.0.1 - need help [message #859414 is a reply to message #859223] |
Fri, 27 April 2012 16:19 |
CIGAR !
I changed the code - instead of doing the custom linking in
the LazyLinker#afterModelLinked, I now do it in
This is what I do:
public class PPResource extends LazyLinkingResource {
@Inject
private DocumentationAssociator documentationAssociator;
@Inject
PPResourceLinker resourceLinker;
public void resolveLazyCrossReferences(CancelIndicator mon) {
super.resolveLazyCrossReferences(mon);
final ListBasedDiagnosticConsumer diagnosticsConsumer = new
ListBasedDiagnosticConsumer();
IMessageAcceptor acceptor = new
DiagnosticConsumerBasedMessageAcceptor(diagnosticsConsumer);
EObject model = this.getParseResult().getRootASTElement();
documentationAssociator.linkDocumentation(model, acceptor);
resourceLinker.link(model, acceptor, false);
if(!isValidationDisabled()) {
getErrors().addAll(diagnosticsConsumer.getResult(Severity.ERROR));
getWarnings().addAll(diagnosticsConsumer.getResult(Severity.WARNING));
Do you see any problems with moving the responsibility to this class,
doing what I do above?
- henrik
>> cross references.
> So, I think you are saying - override
> LazyLinkingResource#resolveLaxyCrossReferences and then trigger my code
> that is normally triggered from #afterModelLinked.
> I will try that - and do like I do now and do no linking if I do not get
> a resource description (i.e. the "build clean" run).
> Looked into DerivedStateAwareResource, but seems difficult to produce
> warnings and errors while producing the "derived state".
> - henrik
Re: Woes migrating to 2.2.1 from 2.0.1 - need help [message #860042 is a reply to message #859414] |
Fri, 27 April 2012 23:05 |
On 2012-27-04 18:19, Henrik Lindberg wrote:
> CIGAR !
Actually, I got too many Cigars...
Posting what looks like the solution here, for anyone else that may
stumble on this in the future.
The LazyLinkingResource#resolveLazyCrossReferences can/will be called a
number of times - in my typical case, 4 times resulting in 4 copies of
every diagnostic.
So, to round off the implementation, I added a guard around the linking
the same way as the DerivedStateAwareResource handled the same thing.
(Too much work to actually use this Resource as it also required a
specialized ResourceDescription (I already have one that does a number
of things), and I also did not want the result to depend on someone
getting the content of the resource (I only have side effects in terms
of diagnostics).
Now, much better.
- henrik
> I changed the code - instead of doing the custom linking in the
> This is what I do:
> @Inject
> @Inject
> @Override
> Regards
> - henrik
>>> cross references.
>> - henrik
Current Time: Thu Apr 25 06:37:45 GMT 2024
Powered by FUDForum. Page generated in 0.03666 seconds
