Insert javadoc comments ... [message #110637] |
Fri, 21 October 2005 11:09 |
Originally posted by: konrad.my-rho.de
I want to insert javadoc comments half-automatic in my code ... by
selecting a function and let add the javadoc body for it automatic.
If I use Source->Add Comment Eclipse creates not realy javadoc:
/* (non-Javadoc)
* @see
org.eclipse.swt.widgets.Layout#computeSize(org.eclipse.swt.w idgets.Composite,
int, int, boolean)
I want an automatic list of used parameters i.e. or a field @return ...
How can I customize these javadoc comments? And I read very often
"Source->Add Javadoc Comment" is the solution. But my Eclipse 3.1
doesn't have this menu entry :-(
Many Thanks
Re: Insert javadoc comments ... [message #110674 is a reply to message #110637] |
Fri, 21 October 2005 11:28 |
Originally posted by: hendrik_maryns.despammed.com
Konrad Mühler schreef:
> /* (non-Javadoc)
> * @see
> int, int, boolean)
I I type Ctrl-Alt-J, I get exactly what you want, and I didn't fiddle
with any options to get that, which means _you_ changed it in the
options somewhere.
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
Re: Insert javadoc comments ... [message #110686 is a reply to message #110674] |
Fri, 21 October 2005 12:00 |
> options somewhere.
It's a blank new installation of eclipse ... so it seems to be the
standard option.
Re: Insert javadoc comments ... [message #110776 is a reply to message #110686] |
Fri, 21 October 2005 23:01 |
>> options somewhere.
> standard option.
It is Alt+Shift+J
If the cursor is on a line of a method, it inserts Javadoc for the
method. Otherwise it inserts Javadoc for the class.
By the way, this is all easily findable in the Keys preferences under
the Source category. Or hit Ctrl+Shift+L to see a "pop-up Keys help."
HTH,
Eric
FUDForum. Page generated in 0.07933 seconds
