Re: group header page breaks [message #857680 is a reply to message #857656] |
Thu, 26 April 2012 19:14 |
How are you running the report? Are you using the Web Viewer /frameset
option? In the group editor you can set page break after to always.
See attached example
Jason
On 4/26/2012 2:51 PM, Aaron Titus wrote:
> Hello. I'm trying to create a report using a table with a single group,
> and I want to have a page break for each group such that the group
> header appears at the top of each page with the detail items beneath it.
> I cannot seem to get this to work. I am using BIRT
> 3.7.2.v20120213-4617w31231324 (eclipse Indigo download package that
> includes BIRT.)
> My table does include a group header, and there is one data element in
> the group header. For this group header row I set page break to Always.
> It does properly render the headers, however there are no page breaks at
> all. The entire table appears on a single page.
> Can anyone suggest what I am doing wrong?
Attachment: group.zip
(Size: 2.74KB, Downloaded 578 times)
Re: group header page breaks [message #857905 is a reply to message #857779] |
Thu, 26 April 2012 23:27 |
If you are in the birt designer you have an option to view the report in
html or in the Web Viewer. The Web Viewer does HTML pagination. The
iew as HTML option does not.
Jason
On 4/26/2012 5:27 PM, Aaron Titus wrote:
> Right now I am running the report by right-clicking on it and selecting
> Report > Run report in Eclipse. This brings up the report in a Birt
> Viewer pop-up window. Thanks for the example, I'll compare this to what
> I have.
> For future reference, is there any reason that using the Page break
> functionality on the group header row should not work, or is this a bug?
Re: group header page breaks [message #859896 is a reply to message #858063] |
Fri, 27 April 2012 21:27 |
That does look like a bug, but using the group editor should work. Can
you log a bugzilla entry for it? You can also put a page break after the
group footer that should accomplish the same thing.
Jason
On 4/26/2012 9:41 PM, Aaron Titus wrote:
> Ok, so what I found comparing your example to mine was that the page
> break was set at the group level instead of at the row level. After
> changing it to match yours, it worked. I still would like to know
> regarding the method I was doing before: is this a bug of some kind?
> Jason Weathersby wrote on Thu, 26 April 2012 15:14
Re: group header page breaks [message #859897 is a reply to message #858071] |
Fri, 27 April 2012 21:28 |
Do you have the report design perspective open?
Look at the attached image.
Jason
On 4/26/2012 9:45 PM, Aaron Titus wrote:
> Hi Jason, I don't see these options, at least they are not called that.
> In the version of Eclipse I have, the options for running the report are
> "Generate Document", 'Run Report" and "Debug Report". I don't know how
> to determine which one is the 'web viewer' and which one is 'view as
> html' as you have referred to it below. What I am doing is choosing "Run
> Report".
> Jason Weathersby wrote on Thu, 26 April 2012 19:27
>> in html or in the Web Viewer. The Web Viewer does HTML pagination. The
Re: group header page breaks [message #865737 is a reply to message #865663] |
Mon, 30 April 2012 14:42 |
Thanks for offering to create the bug entry.
Jason
On 4/30/2012 10:09 AM, Aaron Titus wrote:
> Thanks for all your help on this, Jason. The menu option you are using
> now makes sense. I will make a test case version of this using the
> sample data source like you sent to me, and I will then file the bug
> report using that.
> Thanks again!
FUDForum. Page generated in 0.03656 seconds
