Re: Column select feature [message #110421 is a reply to message #110405] |
Tue, 01 November 2005 20:04 |
Could you please be a little more specific? We already allow changing
the column header's text?
Or are you asking about us helping by creating a cell editor and putting
this in your code so that you can change the text of cell in a
table/tree at runtime?
Raymond Hurst wrote:
> Is the Visual Editor group planning on adding a column select feature? The
> text in the column select can be deleted or edited but only the text in the
> selected column field would be touched.
Rich Kulp
Re: Column select feature [message #110443 is a reply to message #110432] |
Tue, 01 November 2005 23:28 |
If you are talking about straight text selection, then that is part of
Eclipse's java editor. It has nothing to do with the Visual Editor. The
Visual Editor uses the Eclipse java editor for the text pane of the editor.
Rich Kulp
Re: Column select feature [message #611284 is a reply to message #110405] |
Rich Kulp
Re: Column select feature [message #611286 is a reply to message #110432] |
Rich Kulp
FUDForum. Page generated in 0.03529 seconds
