Home » Eclipse Projects » Remote Application Platform (RAP) » Tomcat as embedded server in osgi
Tomcat as embedded server in osgi [message #856524] Wed, 25 April 2012 18:58 Go to next message
Farooq Kamal is currently offline Farooq KamalFriend
Member
Is there bundle based version of tomcat which could run as an embedded server in standalone mode for RAP applications.
Jetty is letting us down Sad because of a nio channel select bug which suddenly takes the process usage to 100% https://bugs.eclipse.org/bugs/show_bug.cgi?id=357318
Re: Tomcat as embedded server in osgi [message #858933 is a reply to message #856524] Fri, 27 April 2012 11:17 Go to previous messageGo to next message
Ralf Sternberg is currently offline Ralf SternbergFriend
Hi Farooq,
RĂ¼diger once created a bundle-based version of Tomcat for the RWT
integration tests. You can find the bundle on our build server [1]. I'm
not sure whether this package is suitable for production use, but maybe
it helps you somehow.
Thanks for the pointer to the Jetty bug. This reminds me of a RAP bug
[2] that might be related to this issue.
Best regards, Ralf
[1]
http://build.eclipse.org/rt/rap/base-platforms/extra-dependencies/plugins/
[2] https://bugs.eclipse.org/bugs/show_bug.cgi?id=356988
Ralf Sternberg
Twitter: @EclipseRAP
Re: Tomcat as embedded server in osgi [message #858949 is a reply to message #858933] Fri, 27 April 2012 11:29 Go to previous message
Member
Thanks Ralf! I will test that in my app. During this time I switched jetty back to org.mortbay.jetty.server_6.1.23.v201012071420 and was able to run it with RAP 1.5 M6. Jetty 6 uses the older IO libraries so hopefully with solve the problem
Previous Topic:1.5M6 Table issue
Next Topic:RAP 1.4.2 TextCellEditor trouble on Firefox 12
Current Time: Wed Dec 01 16:50:57 GMT 2021
Powered by FUDForum. Page generated in 0.03114 seconds
