Home » Eclipse Projects » Remote Application Platform (RAP) » 1.5M6 Table issue(1.5M6 Table - Data is not being set)
1.5M6 Table issue [message #856334] Wed, 25 April 2012 15:15 Go to next message
Avrajit Chatterjee is currently offline Avrajit ChatterjeeFriend
Member
Recently we migrated from 1.5M4 to 1.5M6 RAP release.No changes in the code whatsoever. We have faced one peculiar issue where the table data is not showing up properly one of our tables .We have checked the response through firebug and found that the multiple TreeItem's background, images, foreground, text are identical in 1.5M4 and 1.5M6. Its rendering properly in M4 but not in M6. Surprisingly this issue -
1. is for only one of the table components in the application , rest are working fine
2. first time it shows all the table data properly but fails on subsequent requests
3. All data are coming in from server side proven by firebug response
4. its able to set the background colors of the cells properly but not the text(data)
We have faced this issue both in FF 3.6 and IE 8 which makes us believe that there is some glitch in the migration. Please let us know if this is a known issue and any solutions. In the mean time we will try to debug whats going wrong.
Re: 1.5M6 Table issue [message #856345 is a reply to message #856334] Wed, 25 April 2012 15:21 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Avrajit,
in 1.5M6 we did some changes on the client-side Table (Tree) to support
markup and optimized some renderings. If your code didn't change,
probably we broke something on the client. Could you open a bugzilla
with a simple snippet/project to reproduce the issue.
Ivan
On 4/25/2012 6:15 PM, Avrajit Chatterjee wrote:
> are working fine
> subsequent requests 3. All data are coming in from server side proven
> by firebug response
> the text(data)
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: 1.5M6 Table issue [message #857232 is a reply to message #856345] Thu, 26 April 2012 11:16 Go to previous message
Member
Hi Ivan,
I have raised a bug for this https://bugs.eclipse.org/bugs/show_bug.cgi?id=377746
I will soon attach a generic code snippet.
Avrajit
Previous Topic:Introduction to 'Tadpole for DB Tools'
Next Topic:Tomcat as embedded server in osgi
Current Time: Mon May 27 03:18:54 GMT 2024
Powered by FUDForum. Page generated in 0.04063 seconds
