Re: Concatenating logfiles as datasource based on report parameters [message #856418 is a reply to message #856031] |
Wed, 25 April 2012 16:34 |
You can do this but you will have to use a scripted data source. Take a
look at the attached example that combines multiple csv files. You
could add some parameters to determine which tsv files to combine.
Jason
On 4/25/2012 5:54 AM, Ruben Durk wrote:
> Hey there,
> I have a folder full of log files. Each logfile contains 3 columns:
> functionName (String of the function that is called)
> data (dateTime of the measurement)
> calls (integer of the number of calls in the 5 minute period)
> I have 2 servers that each make one logfile a day.
> Now what I want to do is to select the appropriate logfiles based on report paramters (e.g. select the data of both servers for the last two days) and merge/join these in one datasource so I can visualize the data.
> When joining logfiles from the same server, I just want to keep the 3 columns, but more rows.
> When joining logfiles from different servers, I want 4 columns. The 4th column indicates which server produced the data.
> Can this be done within Birt? I know of joint data sets, but these produce more columns.
> I added 4 example logfiles.
> Thanks in advance!
FUDForum. Page generated in 0.03531 seconds
