Home » Eclipse Projects » EclipseLink » use of a literal for EXISTS expressions
use of a literal for EXISTS expressions [message #855832] Wed, 25 April 2012 06:20 Go to next message
Ari Meyer is currently offline Ari MeyerFriend
I have this delete statement, which failed to parse:
DELETE FROM RmsImportRun r
WHERE NOT EXISTS (SELECT 1 FROM RmsProjwbs pw WHERE pw.rmsImportRun = r)
AND NOT EXISTS (SELECT 1 FROM RmsTask t WHERE t.rmsImportRun = r)
AND NOT EXISTS (SELECT 1 FROM RmsTaskactv ta WHERE ta.rmsImportRun = r)
AND NOT EXISTS (SELECT 1 FROM RmsTaskmemo tm WHERE tm.rmsImportRun = r)
AND NOT EXISTS (SELECT 1 FROM RmsTaskrsrc tr WHERE tr.rmsImportRun = r)
AND NOT EXISTS (SELECT 1 FROM RmsUdfvalue u WHERE u.rmsImportRun = r)
javax.persistence.PersistenceException: Exception [EclipseLink-8025]
(Eclipse Persistence Services - 2.3.2.v20111125-r10461):
org.eclipse.persistence.exceptions.JPQLException
Exception Description: Syntax error parsing the query
line 3, column 28: unexpected token [1].
Internal Exception: NoViableAltException(95@[1292:16: ( DISTINCT )?])
When I change the '1' to the alias, it works fine:
WHERE NOT EXISTS (SELECT pw FROM RmsProjwbs pw WHERE pw.rmsImportRun = r)
AND NOT EXISTS (SELECT t FROM RmsTask t WHERE t.rmsImportRun = r)
AND NOT EXISTS (SELECT ta FROM RmsTaskactv ta WHERE ta.rmsImportRun = r)
AND NOT EXISTS (SELECT tm FROM RmsTaskmemo tm WHERE tm.rmsImportRun = r)
AND NOT EXISTS (SELECT tr FROM RmsTaskrsrc tr WHERE tr.rmsImportRun = r)
AND NOT EXISTS (SELECT u FROM RmsUdfvalue u WHERE u.rmsImportRun = r)
That said, I see this example in Pro JPA 2, p. 225:
SELECT e
FROM Employee e
WHERE EXISTS (SELECT 1
FROM Phone p
WHERE p.employee = e AND p.type = 'Cell')
This query returns all the employees who have a cell phone number. This
is also an example of a subquery that returns a collection of values.
The EXISTS expression in this example returns true if any results are
returned by the subquery. Returning the literal 1 from the subquery is a
standard practice with EXISTS expressions because the actual results
selected by the subquery do not matter; only the number of results is
relevant.
So shouldn't the first version with the literal also be valid?
Ari
Re: use of a literal for EXISTS expressions [message #857390 is a reply to message #855832] Thu, 26 April 2012 13:50 Go to previous messageGo to next message
James Sutherland is currently offline James SutherlandFriend
SELECT 1 should be valid. Can you try the latest 2.4 milestone to see if the issue is fixed.
If not, please log a bug.
James : Wiki : Book : Blog : Twitter
Re: use of a literal for EXISTS expressions [message #859518 is a reply to message #857390] Fri, 27 April 2012 17:20 Go to previous messageGo to next message
Thanks, James -- will do.
Ari
Re: use of a literal for EXISTS expressions [message #870151 is a reply to message #857390] Mon, 07 May 2012 04:40 Go to previous messageGo to next message
You're right, James -- it works fine with the 2.4 milestone build. When
do you expect 2.4 to be released?
Also, minor FYI: http://www.eclipse.org/eclipselink/releases/ is out of
sync with http://www.eclipse.org/eclipselink/.
Ari
Re: use of a literal for EXISTS expressions [message #870286 is a reply to message #870151] Mon, 07 May 2012 15:01 Go to previous messageGo to next message
See,
http://wiki.eclipse.org/EclipseLink/Development/2.4.0
Re: use of a literal for EXISTS expressions [message #870587 is a reply to message #870286] Tue, 08 May 2012 20:40 Go to previous message
Got it -- thanks, James.
Ari
Previous Topic:EclipseLink References another Entity When Joining
Next Topic:eclipselink programmatically generate persistentunit
Current Time: Sun Jan 24 12:06:17 GMT 2021
Powered by FUDForum. Page generated in 0.02462 seconds
