Home » Language IDEs » ServerTools (WTP) » Error IWAB0489E: Error when deploying Web service to Axis runtime
Error IWAB0489E: Error when deploying Web service to Axis runtime [message #110085] Wed, 08 June 2005 18:30 Go to next message
Originally posted by: arun_lists.yahoo.com
This is a repost since I didn't get any responses earlier.
Please let me know what to look for or try. As it is, I cannot
proceed with using WebTools and may have to consider alternatives
if I don't find a solution soon.
My configuration is:
M4 complete install
JDK1.4.2_08
Tomcat 5.0.28
I am working my way through the "Bottom Up ..." tutorial for M4.
When I get to Step 12, I get the following error message:
IWAB0489E
That's it, no stack trace is printed.
How can I get this to work?
Arun
Re: Error IWAB0489E: Error when deploying Web service to Axis runtime [message #110659 is a reply to message #110085] Sat, 11 June 2005 09:54 Go to previous messageGo to next message
I got the same error code.
Does anyone have a clue on how to resolve this?
"Arun" <arun_lists@yahoo.com> wrote in message
news:792ea7c7e1dca6f0dadc71218f602270$1@www.eclipse.org...
> M4 complete install
> JDK1.4.2_08
> Tomcat 5.0.28
> IWAB0489E
> Arun
Re: Error IWAB0489E: Error when deploying Web service to Axis runtime [message #112612 is a reply to message #110659] Sun, 19 June 2005 04:16 Go to previous message
>>IWAB0489E
This error is caused by an incompatibility between Axis 1.1 and JRE 1.5:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=92603
They will try to solve it for M5 by supporting Axis 1.2.
I had the same problem and solved it by cleaning up my JRE installation.
When I tried java -version on the commandline, my 1.5 JRE answered,
although it was not in PATH. I uninstalled the JRE 1.5 *and* the JDK 1.5
(two separate items in the Windows Software list!) to the effect that my
1.4.2_08 JRE became visible on the commandline.
Afterwards I first generated the sample JSP pages using Right-click on
the java file in JavaSource and chose Web Services-Generate sample JSP.
After that worked to my great relief, I tried Web Services-Create Web
Service, and that went smoothly, too.
Does anyone know how to switch between the JRE versions that are used
when issuing java -version on the commandline? Uninstalling JDK/JRE 1.5
is not really a good solution.
Dietrich
Previous Topic:Help me with this wsdl parser!
Next Topic:Bottom Up Web Service Supporting Flexible Projects tutorial not working with M4
Current Time: Wed May 21 18:10:30 EDT 2025
Powered by FUDForum. Page generated in 0.03675 seconds
