Home » Archived » Test and Performance Tools Platform (TPTP) » How to add third-party jars to TPTP/JUnit test?
How to add third-party jars to TPTP/JUnit test? [message #110061] Sat, 25 August 2007 16:46 Go to next message
Originally posted by: no.ddress.now
New to TPTP - using Europa/Eclipse3.3/JDK1.5
How do I specify the inclusion of additional/required jars for a method
under test? The method makes a Hibernate call, but in relevant part
only returns a java.lang.NoClassDefFoundError. JUnit tests that do not
reference external jars run as expected. The Hibernate jars are present
in the Project using User Libraries.
Where/how do I add third-party jars to the JUnit classpath.
Thanks...
Re: How to add third-party jars to TPTP/JUnit test? [message #110248 is a reply to message #110061] Mon, 27 August 2007 11:49 Go to previous messageGo to next message
Paul Slauenwhite is currently offline Paul SlauenwhiteFriend
Hi Gerald,
You can check the product documentation,
http://help.eclipse.org/help32/topic/org.eclipse.hyades.test .doc.user/ref/rdeploymentGroundRules.htm.
Paul
"Gerald Rosenberg" <no@ddress.now> wrote in message
news:MPG.2139fcdead3d7799896a5@news.eclipse.org...
> Thanks...
Re: How to add third-party jars to TPTP/JUnit test? [message #110373 is a reply to message #110248] Mon, 27 August 2007 16:22 Go to previous messageGo to next message
Thanks for the response. However, I don't have an application, a
deployment scenario or location of any system/container to deploy into
(the capabilities of TPTP are truly impressively complex). Thus, I did
not think application deployment was relevant.
What I do have is just a trivially small method that (should) verify the
format of a datum as returned from a database. Could not find a
tutorial that addresses this nor figure out how to modify the local
deployment to include the database driver jars. I did look at adding an
artifact and deployment location, but since I have no external run-time
environment, did not see how to complete the configuration.
Obviously, I am missing something. A bit more of a hint on the correct
approach would be much appreciated.
In article <faudo9$6v4$1@build.eclipse.org>, paules@ca.ibm.com says...
> Hi Gerald,
> Paul
> > Thanks...
Re: How to add third-party jars to TPTP/JUnit test? [message #110740 is a reply to message #110373] Thu, 30 August 2007 11:29 Go to previous message
Hi Gerald,
As noted in
http://help.eclipse.org/help32/index.jsp?topic=/org.eclipse. hyades.test.doc.user/ref/rdeploymentGroundRules.htm,
any dependencies on the project classpath are automatically deployed to the
target host. You can add your JAR(s) to the Java or plug-in project
dependencies.
Paul
news:MPG.213c9a1c883d6f029896a6@news.eclipse.org...
>> Hi Gerald,
>> Paul
>> > Thanks...
Previous Topic:No more handles [gtk_init_check() failed] when using the IAC on linux
Next Topic:[AGR] java.lang.NullPointerException, AbstractTestExecutionService
Current Time: Sun Nov 17 14:58:15 GMT 2019
Powered by FUDForum. Page generated in 0.01948 seconds
