Home » Eclipse Projects » BIRT » Incomplete Report / Row Limitation?
Incomplete Report / Row Limitation? [message #855134] Tue, 24 April 2012 14:53 Go to next message
Anthony Auditore is currently offline Anthony AuditoreFriend
Hi everybody,
when I generate a BIRT crosstab Report, for example as XLS, the report is incomplete. The report should have about 2700-2900 rows in excel, instead I just get exactly 1400 rows. Half of the Data is missing. I have plenty of other crosstab reports, mostly smaller then this one. One of these other reports has about 2500 rows and is complete and full of data.
Is there any row limitation inside BIRT which I can adjust? Or is it maybe a bug?
I am using BIRT 2.3.2 .
Hope you can help.
Cheerio,
Anthony
Re: Incomplete Report / Row Limitation? [message #855195 is a reply to message #855134] Tue, 24 April 2012 15:40 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Is this happening only in the designer? If so look at the
window->preferences->Report Design->Preview->Data settings.
Jason
On 4/24/2012 10:53 AM, Anthony Auditore wrote:
> Hi everybody,
> data. Is there any row limitation inside BIRT which I can adjust? Or is
> it maybe a bug?
> Hope you can help.
> Cheerio,
> Anthony
Re: Incomplete Report / Row Limitation? [message #855861 is a reply to message #855134] Wed, 25 April 2012 06:57 Go to previous messageGo to next message
No, I generate the reports normally with batch-data, executed by a PHP-Script of a Data Warehouse (mysql database). The problem shows up in designer and when generated by batch.
I tried to adjust the data settings in the prefences multiple times but the problem still exists.
Excel can not be the problem because I tried to generate the report as html, same crap.
Re: Incomplete Report / Row Limitation? [message #856391 is a reply to message #855861] Wed, 25 April 2012 16:07 Go to previous message
Anthony
As a test can you download BIRT 3.7.2 all in one and try the same report?
Jason
> designer and when generated by batch. I tried to adjust the data
> html, same crap.
Previous Topic:rotate a text inside a table cell ?
Next Topic:Boss 6.1.0Final and Birt 3.7.2 Warning Osgi.service.log.package-info
Current Time: Fri Feb 21 13:40:14 GMT 2020
Powered by FUDForum. Page generated in 0.03421 seconds
