How do you find TPTP as a java profiler [message #109817] |
Thu, 23 August 2007 08:37 |
Originally posted by: namratab.mastek.com
Hi all,
To profile web applications i was looking for profiler which can be
used from within eclipse ide. On the eclipse.org site i read about TPTP
and started using it.I am new to tptp. I have used TPTP 4.3.1 with eclipse
3.2.2. But sometimes it shows unpredictable results. In the memory
statistics view, in the collected column i am always getting
zero..irrespective of running the garbage collector forcibly..
I have even tried tptp 4.4.0 with eclipse 3.3. But in this case
execution analysis and probe insertion in not working.Could not find the
root cause though.
Can u all please share your experiences about the tool.?
Re: How do you find TPTP as a java profiler [message #110261 is a reply to message #109981] |
Mon, 27 August 2007 11:58 |
I did refresh the views..but it seems the particular column of the
collected (objects) never shows value other than 0.. Other column values
are updated as application runs.
While using 440 'm working with eclipse 3.3. I have configured
oc4j10.1.3 in server view. I right click on server, say profile, set my
filter set and choose execution analysis option..but nothing happens.. :(
FUDForum. Page generated in 0.02769 seconds
