Re: Export to pdf option not available [message #855162 is a reply to message #854709] |
Tue, 24 April 2012 15:12 |
Does your runtime have a plugins folder or are you using the POJO
runtime? If you have a plugins folder does it contain the pdf emitter?
Jason
On 4/24/2012 3:12 AM, Debarshi Dasgupta wrote:
> Hello All,
> When I am trying to render birt report using jsf4birt the export to pdf
> option is not available. Please suggest me feasible solution for proving
> the export to pdf option using birt and jsf4birt.
Re: Export to pdf option not available [message #865724 is a reply to message #865023] |
Mon, 30 April 2012 14:36 |
I am not that familiar with jsf4birt, did you download the demo app and
look at it? I think it has an example for pdf.
Jason
On 4/30/2012 3:35 AM, Debarshi Dasgupta wrote:
> Hi Jason,
> My project is having a plugins folder and the hierarchy is follows :
> WebContent->WEB-INF->platform->plugins->
> - org.eclipse.birt.report.engine.emitter.pdf_2.5.1.v20090821.jar
> - org.eclipse.birt.report.engine.emitter.pdf.config_2.5.1.v20090917.jar
> Do I need to add any other jars or make any configurational changes to
> provide export to pdf option?
Re: Export to pdf option not available [message #871255 is a reply to message #871156] |
Fri, 11 May 2012 16:15 |
If you have the viewer deployed it should be in toolbar.
Jason
On 5/11/2012 3:51 AM, Debarshi Dasgupta wrote:
> Hi Jason,
> Please provide me the steps to be followed to provide export to pdf,xls
> option while viewing a report.
Re: Export to pdf option not available [message #871359 is a reply to message #871255] |
Sat, 12 May 2012 11:25 |
Debarshi Dasgupta Messages: 25 Registered: April 2012 |
Hi Jason,
As per www.eclipse.org/birt/phoenix/deploy/viewerSetup.php it is required to deploy the WebViewerExample on the tomcat server.
But doing that I am unable to get the export to pdf,xls option.
My questions are :
1. If I want to add viewer in my project what configrational settings are required?
2. I have seen many posts where it is mentioned to configure the emitters to have the export options. How can we configure emitters?
Request you to help on my above mentioned concerns. Thanks in advance !!
[Updated on: Sat, 12 May 2012 11:26] Report message to a moderator
Re: Export to pdf option not available [message #871752 is a reply to message #871359] |
Mon, 14 May 2012 19:39 |
If you deployed the viewer the export options should already be
available without any configuration. When you say add the viewer to
your project can you elaborate a bit? Are you using WTP?
Jason
On 5/12/2012 7:25 AM, Debarshi Dasgupta wrote:
> Hi Jason,
> My questions are :
> are required?
> 2. I have seen many posts where you it is mentioned to configure the
Re: Export to pdf option not available [message #872267 is a reply to message #871915] |
Tue, 15 May 2012 19:56 |
Can you list the process I would need to go through to reproduce your error?
Jason
On 5/15/2012 2:13 AM, Debarshi Dasgupta wrote:
> Hi Jason,
> I placed the WebViewerExample in the webapps folder of Tomcat server but
> still the export to pdf option was not available for my sample module.
> Then I tried working with the birt.war in "birt-runtime-3_7_2" and added
> my reports and jsp into it then the export to pdf/xls options were
> available.
> Though it was working there were some errors with the pre-bundled
> web-template.xml.
> 1. a. web-template.xml
> <web-app xmlns="//java.sun.com/xml/ns/j2ee"
> version="2.4"
> xmlns:xsi="//www.w3.org/2001/XMLSchema-instance"
> xsi:schemaLocation="//java.sun.com/xml/ns/j2ee
> //java.sun.com/xml/ns/j2ee/web-app_2_4.xsd">
> Please Note : The http: part is removed in my above post.. since I am
> not allowed to post links i have reomved the http part....
> Here I was getting "cvc-complex-type.2.3: Element 'web-app' cannot have
> character [children], because the type's content type is element-only"
> error
> b. @generated@
> "cvc-complex-type.2.3: Element 'web-app' cannot have character
> 2. Second error was in the webcontent/birt/ajax/utility folder with
> BirtUtility.js
> "Internal validation error java.lang.NullPointerException at
> org.eclipse.wst.jsdt.internal.compiler.lookup.CompilationUnitBinding.sourceMethod(CompilationUnitBinding.java:83)"
> Can you please guide with the above errors....
FUDForum. Page generated in 0.04927 seconds
