Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR, 4.4.0.2] missing information in test suite editor
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109664 is a reply to message #109628] |
Tue, 21 August 2007 10:38 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Matthias,
No, we have not seen this behavior. Can you attach your <Eclipse
installation directory/.metadata/.log file?
Paul
"Matthias Wiskow" <matthias.wiskow@windriver.com> wrote in message
news:fae8qj$pnd$1@build.eclipse.org...
> I created an AGR test suite with TPTP 4.4.0.1.
> When I open the test suite file (same project, same workspace) in TPTP
> 4.4.0.2, the Behavior page is not displayed and the Test Cases page shows
> only the list of test cases. Macro, Object Mine and General Information
> boxes are missing.
> After opening a new workspace and importing the test project, test suite
> editor shows up correctly.
> Any idea what goes wrong?
> Matthias
> Environment:
> - TPTP 4.4.0.2 AllinOne + correspondent AGR
> - Windows XP SP2
> - JRE 1.5 Update 11
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109748 is a reply to message #109735] |
Tue, 21 August 2007 14:37 |
Matthias Wiskow Messages: 25 Registered: July 2009 |
Paul and Joe,
thanks for your ideas.
I opened the same test suite with TPTP 4.4.0.1 again and saw the same
effect :-/
I cannot fully reproduce what I did during transition to TPTP 4.4.0.2,
but I suspect that I somehow broke workspace or project settings.
Since I can continue working with the imported project in a new
workspace without problems, I suggest to not follow up with this issue
now. I will watch it during next transition.
Is that OK for you?
Matthias
Joe Toomey wrote:
> I would guess that you have not installed the AGR into your 4.4.0.2
> install. In the absence of the AGR features, your AGR test will be
> opened using the generic test suite editor, which is what you are
> describing.
> If you think you have installed the AGR, double check your install to
> make sure the plug-ins and features are in the correct locations. If
> you are still stuck, post back and we'll walk you through the OSGI
> console to figure out why the AGR plug-ins are not starting.
> --Joe
Re: [AGR, 4.4.0.2] missing information in test suite editor [message #109831 is a reply to message #109748] |
Thu, 23 August 2007 10:23 |
Hi Mattias,
If you can consistently reproduce this issue and you can confirm the AGR
plug-ins are installed correctly, please open a defect against the TPTP
Testing produce and Test.UI.AGRGUIUI component.
Paul
news:faetbt$pq9$1@build.eclipse.org...
> Paul and Joe,
> effect :-/
> I cannot fully reproduce what I did during transition to TPTP 4.4.0.2, but
> Since I can continue working with the imported project in a new workspace
> without problems, I suggest to not follow up with this issue now. I will
> Is that OK for you?
> Matthias
>> describing.
>> make sure the plug-ins and features are in the correct locations. If you
>> are still stuck, post back and we'll walk you through the OSGI console to
>> Thanks,
>> --Joe
Current Time: Thu Apr 25 15:59:56 GMT 2024
Powered by FUDForum. Page generated in 0.03395 seconds
