Home » Archived » BIRT » org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet objec(Not sure if I'm using the right JDBC)
org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet objec [message #854074] Mon, 23 April 2012 16:31 Go to next message
Mike Johnson is currently offline Mike JohnsonFriend
I'm upgrading from 2.3.2 to 2.6.1. My issue is that the report runs fine in the report designer 2.6.1. but it blows in the the Success Factor LMS 6.4. I get a generic ORA-00933; sql command not properly ended. I did a dummy select statement guery of last name, first name, middle. I runs fine in the report designer, just blows in the LMS. We are using Oracle 11g database.
Re: org.eclipse.birt.report.data.oda.jdbc.JDBCException: SQL statement does not return a ResultSet o [message #854342 is a reply to message #854074] Mon, 23 April 2012 22:15 Go to previous message
Jason Weathersby is currently offline Jason WeathersbyFriend
Mike
Do you have the same oracle driver in the designer as in the runtime?
Jason
Previous Topic:Dropped elements still being rendered
Next Topic:Display image on top of text or through text
Current Time: Wed Mar 22 12:17:11 GMT 2023
Powered by FUDForum. Page generated in 0.02478 seconds
