Re: Does AGR need the Agent Controller for a standard local_deployment on Linux? [message #109316 is a reply to message #109305] |
Fri, 17 August 2007 13:28 |
Originally posted by: joel_patterson.verizon.net
Hi Paul,
I'm using 4.3. Was confused because I didn't need it on Windows and I
installed the exact same thing on Linux.
Paul Slauenwhite wrote:
> Hi Joel,
> You need neither the Integrated Agent Controller or the Agent Controller
> installed when running any type of test. Using 4.4, you should not need to
> install the Agent Controller separately since the Integrated Agent
> Controller will be automatically configured and started when you run the
> test for the first time.
> What version of TPTP are you using?
> Paul
> "Joel Patterson" <joel_patterson@verizon.net> wrote in message
> news:fa2s1u$avm$1@build.eclipse.org...
>> I've a suite of tests that runs fine in quick mode. I set up a standard
>> test and tried to run in under local_deployment.
>> I get an error that I need the Agent Controller.
>> Is this needed on Linux? Runs fine without on Windows.
Re: Does AGR need the Agent Controller for a standard local_deployment on Linux? [message #109354 is a reply to message #109329] |
Fri, 17 August 2007 14:39 |
Guess I'll need to use the Agent Controller since I need to test against
Eclipse 3.2.1 -- can't go to 4.4 because of that; requires Eclipse 3.3
right?
> Hi Joel,
> The Integrated Agent Controller is packaged in TPTP 4.3 but has several
> problems. Can you move up to TPTP 4.4 or install the Agent Controller?
> Paul
> news:fa47p4$jl0$1@build.eclipse.org...
>> Hi Paul,
>>> Hi Joel,
>>> Controller installed when running any type of test. Using 4.4, you
>>> should not need to install the Agent Controller separately since the
>>> Integrated Agent Controller will be automatically configured and started
>>> when you run the test for the first time.
>>> Paul
>>>> standard test and tried to run in under local_deployment.
FUDForum. Page generated in 0.03860 seconds
