Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] Multiple tests in Standard Mode
[AGR] Multiple tests in Standard Mode [message #109120] |
Wed, 15 August 2007 20:15 |
Originally posted by: joel_patterson.verizon.net
Hi, I've created several "mini-tests" -- each one building off the
results of the previous one. I can run them all in quick-mode and they
work fine.
But when I create a standard test suite, I add all the tests (as
siblings) and only the first one seems to run. So that's not the way.
Is there a way to batch all these tests together?
Thanks!
Re: [AGR] Multiple tests in Standard Mode [message #109157 is a reply to message #109145] |
Thu, 16 August 2007 13:46 |
--------------070806030408020504030300
Hi Paul,
Just as an FYI, I'm running AGR 4.3
I did notice that your test-suite uses the Object Mine where mine does not.
I attached the execution results as well. Only the first test runs,
and it passes, so you'd think the second test would then start.
Thanks!
-J
Paul Slauenwhite wrote:
> Hi Joel,
> When you define the behavior for an AGR test and add sibling invocations
> for each of your 'mini tests', each invocation will be invoked during test
> execution. For example,
> http://dev.eclipse.org/viewcvs/index.cgi/test-results/test/o rg.eclipse.hyades.test.java.tests/autoui/Test.Execution.JUni tRunner.testsuite?root=TPTP_Project&view=log.
> Can you attach your test suite to your reply?
> Paul
> "Joel Patterson" <joel_patterson@verizon.net> wrote in message
> news:f9vmst$ghf$1@build.eclipse.org...
>> Hi, I've created several "mini-tests" -- each one building off the results
>> of the previous one. I can run them all in quick-mode and they work
>> fine.
>> But when I create a standard test suite, I add all the tests (as siblings)
>> Thanks!
Content-Type: application/octet-stream;
name="AutomatedGUISuite.testsuite"
filename="AutomatedGUISuite.testsuite"
UEsDBBQACAAIAKZLEDcAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c+09/XejRpK/
33v3P7Deezk7iSU+JTEzzkYSkJ3b+bqxJ9l32X3zsIQtMgi0gGzPzsz/ft3Q INQCCUk0xlLl
JY4+Wl3VVdVV1VXVxYu/PEwd7s7yA9tzL06EFn/CWe7IG9vu7cXJhyvjvHfy l5/+8z9eDL3p
1HM/XllBOPO9G9uxnl29M/Dby7kdWtzD1H6WTiPiadDEbvAMfX5xMgnD2bN2 +/7+vuVNb1ue
f9v+++uX6ZBgeci9FI0QeV5Aw15djibW1Dy33SA03ZGV/IogNLAm5p3t+R9f uqHlm6MQIRAs
TWeNHHsWWNGck8/m2AraU29sOUF7FE3RviZTtO3MFC2EOAUqs/btAISLH8bT 2uOLE11VDbUv
6ZKm9OW+oA+6hqapfV5WBgNB0IYnHJpo5NuzMCLp7dzm8DzBCeeaU4RAfx56 UzO0xr98eBmx
AE0bkSi0TUKEFRA9Xu8OukICgtMHoqLxhszrQ1USxKFi9DqGxItowDB3QLcr D3TJwAO03AED
gddVUS0eoCvqsKcpxQNEQ+52jQiEno+kqmoIz+IBPWkodmSleMCw01FksV88 gNc1SRQiEEbu
ALmv9SVNRZQcdvJBqOqgr4l4QD4lB8OhwXcxCE3OHSAMFUnSeCQPmpKPg6wo Awkvs2BAR+mJ
oqAVD1B7fL9v9IsHyEp/IMgDPCB/mbqm9nRNxwO6uQM0XtQGfASiVyAPnUFf kBChtHxCiYqo
CmK0inyBUURD6+lYqgsGSN1eF1ETz1AgD10DbZVh8YBuT1R1o4sH5MuDjsTe 6KwZ0JeQUA1l
hCSCkCty8lBFsoRm0MUieZB5LRqQzyxJ6ff5HiaUns8LcaAYhoQJpefzQuqi zSlimdTzeSEP
NFFVsNjrBbtbHvZ1GbO7YMAA7W6Nx6TW80lt9GSRFzEljXw69DpoY8g9hIMR bxyjP+j0tKFk
DBQeKbuBgqbuaLwgd3gxdwBCQeqLiJJFA2SkMfu8iAdIuQN6XUMVRU0oHCB2 DH7YG+IB+UjK
mt6TugOxcEBPVNS+umYGFZkLXusWz6ArfaTGteIBAt/nNXWAQSj5qxjo/W6f Lx4gD3WxM+DF
wgHqcMCrvFQ8QBc1SRcHmQGy3tU0xHMVWcOOrkr9ntFRDIRDl88doCo9pW/w xQOMnqohHSMW
DuA7HcTHCISQO0AxkMAOscAUDEAbo6PFOOQPMIwOr/Od4gGqrg4GcgeDkPJx EHt9pLHxDHIB
oXhJlrBMdjv5IDq8itDAILr5ILoCsnsCnqGXv0yF7/R7vcUAXefVgdITeAFp yE4/stqShGWy
q+UOkIUBGtXFM+i5A0SxJyGxwjMYuQOkjthHslI8oKP21G6PLx5gGAOkQZCL 0ukJ+TMYHVk2
ogFi7oB+BxF60OULBxhIhXUG2mIGZAN7PXWIthNyHZRhf6gNZa2HmDXoxpp2 KApdVeYHPZUX
FQEZbqOPPRQ0wFBjbzD8PENeH/IxU38z9jVb2CtsmcgbbCEfMXpH3MEZdseD ELnz1kvkcP41
Gm6YI/S/91bgzX3kTCPXnuNeJL51kO+ZUm7jCefYN5Zju1bhWHExduSYQXAV Ib/R5W2XQwcZ
22E34yjHDrE+fPXy3aX+8be37/820N8M/7rVdAI93Qc01fDD+/f6m6vMlMjH tpGD7fxqOnM0
KPTnVgGYDa51FYTZ4JwzAEG79wxA0AcEBiDoIwYDEPQhhQEI+pjDAAR9UGIA gj5qMQBBH9aW
9Ff+WHExtnqiUkfDdeiQseJibPVbmjqIMgBBH2VZ8Jg6DDMAQR+nGYCgD+Qs CEUd6VlocCoo
sE7AyVhpMbZydOgQxDp0yFhpMZaBfVsOeLCwb1TIhIV9o4Iu64hKxrJEhw7x sFDbVJCIhQNH
hZlYSB8VqFq7N+OxEkN06LAYCweDCqytWzEZKy3GsrCFS2G8deiQsdJibPUb hwoastBGVNiR
yfZfDlyysJtU6JPF3qSCpyycPSr8uk76yFhpMbZydOhg7zp0yFhpMbb6ExUV Wl6HDhkrLsbu
jc6mQDYDEHQonAEIOpjOAAQdjmcAgg7osyAUlRJgQSgqqcAABJ2WYACCTmww AEGnRlhIFJVc
YSFRVHqGBbupBA8LdlMpoipAbEgyMQBBp6kYgKATXQxA0KkyBiDoZBsDEHS6 jgUvqIRf1pUo
GMtyxXR6kQXfqATluhWTseJiLIMtvZwOXYcOGSsuxlbPACr5yoIBVPqWxcah EsBV+OAbUsgM
QNBJaAYg6DQ2AxB0IpwBCDqVzoLdVDKexSqodD4DEHRBAJN9sVxSUAGITUUJ WZVZMFZcjK0c
nY7Q6w+QmUYgiCaIE/P/8+vrj/33v3x4rb+5uqQT8ud/nz6ISmeaD2JzlcVi xQVjxcXYHVac
lBqvq7NYKWxYqfT9mExzwvmkkGO5MiQqFG7dWb59Y4+iauDWxPM+Ba1fMx8N MfpoxV789uKk
3b+1Q9NHUHClczvwR3F5SETGtDKafIQ+TGi1tmpEpFfzMbCcm1fkp0nNMmJQ 4QwCRUQaIcM3
b6eWGwbcQ2A/i8tk1hWHPxv8+l5/sEZz/O7taDT3fSuqK88TQk0fCmpf4Bdy Hq8CAZg5Vmhh
SnHnaBV3hIwnnBdOLD+BXLhzFjPWsSp0zhxKakcT+mpfNNAJSx3wyB1BsjzM lTQOCQG3eW0F
e4RP90iythdtWoJepGX38VssskMzKFZNInIIMmxYKo7P48oOFVMJsku7dCP/ cmAvNmgub9MP
VzbRZjW7aRNtVOrtLPQ9Be61FQTmraW74/zdQ4BLKfAMbAR9Gv88aC9/PPO9 meWH9nqayDRN
+BPuLjYCI2/aMiNdlnIezfmHNQrjjzH+7yw/mKFP7DvrZCf4Cg1fSOF/54TP p+bI99KLNd/9
a+6Fz4UWH7/46bs/P2jP0Z8+/qM+xz8IJpbjLMT6ziI/ipUy2ocrZgB9psfL 4y61v8WjMcbx
q6zcIymPOO2aTus3z/90jVTD5DfbHXv35Ge+Fc5993zkjRO450IBrgnC+HKL 6Y5zUH5HiN1q
kdkjaYpfI8FFX6VQA89BNHqZh3Q4C2fUVnU9N/TtO2TuyQQj9IH1EKa/RwI8 D8h39/b41lp8
9eWLYTvW+Rvr/jtzOnuO/8Mr6TvhD5cT+yb84c35Au9v386/fEHs+vYt/nG7 kApFbENwODLf
Os78cWOOrNa9/W/TH7d+i/6noeV5t4V8KRKhkryJxWmVL0iepufWwwz9qoC2 MZLnM7Rj2651
HyN7GbET7yf0cT7hs8sN7sNW/HXQuvIt689EyMjOid/gosqNi0xWivHmZmY4 Sdmcs/vjXe/5
NFu3FkBzbEbEXCsVCWptwoX9WMVdIeA+kglKnGjeLW2sOnlXFZMSFU02A0Kz T9iWUIAQ4Glx
8Q3iA5eqnNvwecU6cXkxBZwvUomCUlLTbV6ngQ5iwaRRi+uUV+PtSI9vtHWZ dd2bdrhp1mJq
xbJ/HhLJLqOPK6bdnW3dt5dM0TjEjsI7c/QJ+3QPM8fzLb+IuO2VXbi1Cs9V DG2KMvVs9o37
PF8GbrxR6m5USt8ivYsPGV6AqJYo311kDx3sQd6K5A2HPeo1MOVwajd3Q+Qe AMZzZMr/MO/M
VVEbWzfm3AnPWVqGqqWtUha2s/RpHj8rM3Jkmbs4rBH/cpxEbx6iT62ghQcE rbfk7a/oHRMP
Noe5GawQq5AgJ0i1/uAZ7qlX3gidAWKX2OKGoe/8YKgVu1v7na/j88p5Pwmx nC+hvHTqJuiX
98+2lM1cjw5/GIVlfloOgrXzomCLwN1K6HI1eNlOo5d5wcycKKkwUDNR0vxg 5mowtqqQ5saw
bSEGOwc2N2dTNgU2N+ZuWAY2C4BLKfBdApsFk8o0TVgFNgvgKzR8CGyCQdva oG3QwIsP69XF
Ofc9u4aEE7XJfc98XRyRB2vAc6EqLVxw9TSDyirsnfXv5nuuG7Ozm27VstS/ BcClFPgu+rdg
UpmmCSv9WwBfoeGD/oXE0lNJLEG24illK0qGMlnyY+d8A+RVIK8CeRXIq0Be 5UnIG+RVIK8C
eRXIq0BeZevj5dPJq3zXkKjeUFVVaSjyi7Zpm6J6IquoHunglkFlFXZlUb3V dnHbRvVWmtPV
GdUjwKUUeBVRPTKpTNOkrqgega/Q8CGqB+as1jNTXWTaythUxmLkeSIy492z C/rmtVM5m71r
Jnxm64jg24DOeeh5zrXpt3ejfRu5LOMxZ3Kudc9Z6XdJ9JtvKd++ffny3pp6 dxYXTiwuXpI1
5qghEnkj4TdKt6fKiiTL5EMxdexXHCZ9bIfLE1sPi6m7eLbYKkU3ONcucIF+ gNfaSp4OY2cn
6y3w3MTxIrWdISGtmdeYpwx2rdvrQt28Z2T/bWIsaoo+RjQq4i3flNjjsSgx CZQYKDFQYqDE
nrISk0GJgRIDJQZK7CkrsY3na1BioMSapsQyojb1xvbN5+1VDb3NRvMgRIu4 DD871vgKTVJu
q/3p96HWv+r/zrd4Dr+/QDy10UKt8J1vj6zTM/KpwPNoyD//yfZaOKhyCA5D rhNynXvnOskT
dPjFE3Q25TolVrlOgoqwQGUVdmW5ztUnB22b61x5TlGduU4CXE6BV5HrJJMq NE3qynUS+B0a
/rHmOo/jZPLpWmRxMqkgobkXrXaoCQV+7++jXE68e84wbeTbc6+tcOKNg0e4 7zPzZvPZrgfW
UtxY9X3yV77/jaHlKUucBwuPq1MIbNV5Gip7drbGduj5eWW5WIfZTmTVP7h2 qMcDc8qIqz1y
Z07bs7gwmEtqdNOx/eez+bVjj+I2yhzBifsSfcVxM7Q98SElwD7JiLuxkYHm LtGmdW+54VtN
//i6f/k37oKL0fi9f/5//zz/xz/G6b/kzXn0TTzoOTU1mQ1LccFX2Huhvxp7 CG0Lvx1ZmcVw
XPv778kr7nvu55npm9Nobo57jajHXVucdxOFkW48f8r1z1X0D/pz3l/5FQZL fuV60S/dueO0
lj5xPPfW8tF8psuJPDeamNj7RD5Va2W6CFVuSpC4tsJ7y3K5/+I5LGP/hcMd mZ+EE9+7D7iX
jmPdmk7fv51jz1d/GFnRgYKz4zXghf0YI4oOAzEEO8C9gk3HHqfztRPixawm TD7NUP7HLK1/
XKLuGbcJmURYOC4Ci9gzRFOe4nnPnq989wZBOMVgcr6LQ0Ax2MW3UYAo4uHF kpiQb6LlXyxJ
CfkmJshFVko47ltWWghFyOLR3oswP8ssKVayS3DXzxCtL2eGLH7fNklstKYK RK+kHEXgNgvO
nWePuYAsMSMwu4hInhgUsTOP4EREM3HDFYoXsz2P5Cz2Z7ojkS3Hesc3Ec82 UTdez75bcM1W
2nZbhF78Yrt9QRR1tKolvZBRO9ssDJH09E/4Ry10xhxNrOA0NUBnWcS4eM4o T1E07elSVDO2
D8HEmzvjdQYi+k2GmN+WcIsV1EW0U6vAZ2S6mb1fCHwz0ffZrXhh8YaMF8Z9 /RrN0XIs9zac
IIlAX/A7LhcjRi0Tm7Frx3Q/bSD2Mg4/XSANWA0ShVq1DEK2O7Ye3t6c/vc/ /P+OsOJTei2+
cslXFeCLPVDTdvHPcJgNEy/Zlpvx3iw4+ykiTJVY02BHFJEiChtHf4he/ClK 8uy8Vzaq6/Ur
/xah8meBf16UZGpkLpdkcQtPr+adlc1ijqL5ru1xO6C+2SK/WXk6CTIgkGZj dwdjx8P9o17d
KBHmfCKZMI0XtQGPe3lpvXKZMJlVJoygIixQqbyjYgFIiQZZPh9GZhDTGerM hxHgcgq8inwY
mVShaVJXPozA79DwjzUftopyzvns7GiMkMd/7X5taOqMqUHZLBfI6Xbm6Cx6 43vTSE8iwWh0
DihLr+IEUPaRN6t1hjlrXuliESRttxJWm06wsUVFzVVZax8jVOtOraSZzc5e 5PYTuqw0AhTh
PdnTwUFXEjC5XQiEZkloKNk4wpKNrbbJFrX8CZ1f2UGZMv4iyaeSV2elzDKU 8IP30CTv4SnG
3BTRGMhyD8fctHIxN4VVzA2hovX0bgYV5jE3AlKkQZaPuZEZhHSGOmNuBLiU Aq8i5kYmlWma
1BVzI/AVGj7E3OiYW47FPALt7PFfVQi67SMYuX1mQTbWyQaU70L5LpTvQvnu uhmgfBfKd6F8
F8p398UHynehfPegyncRKaBsF8p2oWz3wBqXCLxudKJ4rVEudNxh1rgkRkVY oMI8dExASjTI
LdqXxDOI6Qy1ti+Jgcsp8Eral8STKjRNamtfEsPv0PAhdJz8NNVjOKzmIhWU ef4icRWTiEAS
DDjjTkVFOJ74sst/5RtYwlUl5w43ANxQ5r1BJ5x3XrTRFx4zYs7x7KopZsxX Af/72OxpdvPU
pTrkbOdUMg6Rm2qL+sp2PyHWhhNuNPd95CdwaNblIYKwY+vUqD4qcM1ZMPGQ /3GD/K9wx9ap
yYulvqkPTTmg/Kz/fai/u3r59g3DLXmZELLWqsJjaTu8RN02kV3PdT5HQT0f IXxHbx0cecq+
F/fZJlGH4dAcfQqRI25xO26TdLPF1X/Xj7NBmEg/ps32kl+ysjBH8JOcZytJ uC5Fo7NZ2GeK
ur7k8FG8hpXcbRqfp3K2XBLHy63aXVfXwD51XU03Psi/Q/4d8u+Qf4f8O+Tf If9eX/49smdJ
Ui8v0Z0O2DKXVy7fnZn9W4JFE0sBSvMBUvKQkoeUPKTkGxDxqjwVdDRdA5gl GZ7+DQRIdDQo
0bHKng8uzqzbN7Y1XmVIg253V9CMJbPUhvZg+eAijRk9j+7weZGsdCMrFtq6 Rk68efv+df8V
d9o9Ij3lR3rq8ZPlx9G/w7tm0pGmgVk4ePjnAT38E3pmgBKDJxiDEgMlBkrs YJQYk4cdghID
JQZK7PGVGFw924ucT+TqGS8P1WFH4GVFF8tdPeuyunpGUBEWqDC/ekZASjTI 8lfPyAxiOkOd
V88IcDkFXsXVMzKpQtOkrqtnBH6Hhg9Xz5KfLmq8TgUecog8owTRAeQQSTS+ WEoOMhovQDQe
ovFwBoQzIJwBKz8DLqrDwfeIfA+xOksDBpwYcBEMOBhwMOBgwMGAszDgyW0j sOCRBZfAgldu
wSWw4GDBwYKDBQcLXrkFX769jMy4IoIZ57/KdZhx6Yja9/mYpmDGwYyDGQcz DmacgRlferoU
2PHYjit12HG5kNQHaccVsONgx8GOgx0HO165Hc+0loKAemTBOxBQr9yCd8CC gwUHCw4WHCx4
5RYc7jUd3r0mYajIvBbda1LK3WvqsbrXRFARFqgwv9dEQEo0yPL3msgMYjpD nfeaCHA5BV7F
vSYyqULTpK57TQR+h4YP95qSn8a0P08avJdx7yu2YHd0Zy7S/f5d3HseGXvH 863CdpVtWutu
55KiCSgSrDT52m+9Nd+P2pWQTO9EvfXHiHyI8tmHFhyzjLUDf9RO3yyTp9Hy t5/Tt0kOcp/s
BqLQIFHIPYwhAxzkPrvl8b33BXblnfM1x048V4kjZzi2osVYBHowqua4WdIQ rDkTlkD2epOq
b0i8JVolCZ/EuK99OJZMxUd6gizyvc3xkdXpozCGb6G9de1Y2J9sF4wpG+rY 6Fai6WPh20H2
0v6su8je5u1/aYXtX6xwGb+tYpb39r9Nf3w+Q8q3PbNHnyz/HXq5nZdSNia5 VjdjjYuk33SD
1gD91chaPV/azL1yirRsuB2Rh8s2NK83pBQzpGg/CEpJTVpysYbt2sGkUSvs bLPCDbEziBhC
xLDKiGHB5aL4yVyQDYULwnBB+OlnQz9VmA3NVRj/Ozfd0A4/g8ZINAZcSIQL iaAxNsXtjkZ6
/2BSjgJyu1r3o7AgNNT9QN0P1P08/iketuQ2W3I99Eq25K7Pb2z+lsyI2tQb 2zeft984tOUb
zYMQLeIy/OxY4ys0STnr96ffh1r/qv979NDkoieDbhEw3nEbPhEC4dMoEKkE kRZHdvzM32pJ
BvasnD3b8jm0JC77I2e7IY60dFQItVT69Nk1oRahd1SxFngaItxVOXgHGc6s cGat88x60EoM
noYISgyU2IEqsYIH2ARRjQj0vKn4ATbFx5BiUh/kKQSeAgOnEDDgYMDBgLPt eaNIYMFr6j5b
TOqDtODQfRYsOFhwsOBgweEGC/S82dzzZmDIXY0f4p43ermeNyqrnjcEFWGB CvOeNwSkRIMs
3/OGzCCmM9TZ84YAl1PgVfS8IZMqNE3q6nlD4Hdo+NDzZqmcHVqRFPafaGjv icNogwOtT56g
6IEvV5YuCIeIkRqCAbcLk0gVdGeG7sxPOFLF9nZhkFUZ+A8OcBc+8+uY1IZa y2NZ5KNSGyqo
jcNQG+Z4jK8k00X2Sgc0B+Pilq0pf3iKpFoSVxZhfuk41q3p9P3bOY6V6Q8j KwpEcqfiEaUx
p1EhUiNqkVZZ9MHFnflw0qnu0+LMm81nZVN2WY62S+m0lQPoYqUrB/p4oYvI 443pBBtP65Wz
Qj8SRuhl2bAwRcy4AIlquBF+tDfCZ7HDxF1ccLg9Lff1K/cvcq2Xw+PgWm+h na45VQ8ublNd
3PSp8Efk0EJlPdTlHYO7A3V5UJdX5/1e2JJwAqnpBLLj8zpKH0C27290AL2R Tk/TzqRnXNQo
CVv5qF3SaeZtYP/bOj07F87OWrfQaqpSclrhO6Bo1RRNu/lfXHAkZABxAXAV wFUAVwFcBXAV
nig5l1pYIsuWRL7BtIFpA9N2HKatIdrr55cGKPe15Dn9+d17PavJ7UCfzrDq PvuRi75D8K+8
0HTiplKRRufPQJeDLgddDrq8RmW1rIewGsLqCdT7thRbUeg/LGpTvk/CUPA4 A0Z0hcMmK8JC
hJopbX17hE744Pc1o2wNbiWvuXm/SocDLRer8OGF5SsjoSNhXT2FJQUqH0uT NVcJO41rI2X0
ZJEXu7ysGGK5NlICz6qPFMFFWODCvI8UASnRIMv3kSIziOkMdfaRIsDlFHgV faTIpApNk7r6
SBH4HRo+9JHK9DrR7GDkzd2orX6n8IlTx2QCK2zKu03DJ5YEHFbR/Km0sBye EWcmFdXcJDkm
VjSww3MDUxZLd26zGQMyDtGaSka8st1PiK/hhBvNfR+5FxyadXmIIOydsMgD v1XCInmxlK24
qThbgfF9ZyLHAk9Pm+uS+YrJAecrmIUjl1ZY+U5aQ6I3yDF8th0RKq5obSKf wyvgdBxfPgZe
ezVJdPO5HZrHwW/TAY4v8kfHwvNhTdrsaXDdC46H7wFo+GVyRNm6P0vic5CB o5WB07OjlILT
M+4nkIQVkhytLHAKSEMOUSruZ/UU5ICvac1PTRKALP3fxyQBxLpcDkdgbRcn ZXGseDkSW1vk
fW0NXS6G2Wg57o+XfX8qKfKPQuds8RmZeuselpvJB9WG5egEKc0N/Kg9pfmn RMNwp385HmY4
JKnZgLzm1izJfe4TcIUaUHgxCjeMa2CusXktHJ6Ok+R6XF1+Ehj6cnSCawVQ APgYfhHUbDWp
ZmuVGxlVzZ0q3eNhSerbPH6HbOjJvAehG1h72LR2CdCTGXoyQ2wJYkvPF5Ze KHw45+Exo0Gx
JbBb0ObnaNv8/Pweuniso45+9eH9G9y+g0q9fs8JPNdGf+DRUg3xbCCYVsrj g4YSzINppSl+
eG5d433sYwymNcrFPuBgGtvnsoNWaZpWWQrTy0f0CEsI0x+UZoEubiCzLFJL G7u6QGoJUkvx
L5oTooMADCixrBITQYmBEgMldphKbJVOaRQWqwnXDtP3t+HzKGGuQvwUHccr DCmtKUYspvXh
HUt8HkJ1UPcGdh3sOth1NnVv/SmO1GpzKwqfFzZ7PyYzLtVhxotJfZBWXGqY FQebBDVtx1bT
VlS19UP0gfmAXp5zSwlVqOJqjJ3Gj8EJIhstg43mvyq12OhCUh+kjVYaZqMP +qQNEXQ4aT85
rwYs+B4WPPawwH5H9rsL9rty+91tmP0GawRnbDhjJzejenAxqmkGOcMfuAEU meVeLWb5uBLY
PTDLYJbBLDfALP90wYH9bYj9Db1LpEjc28j2imB7+a9CLeVjxbQ+SOMrQPkY lI8dvL8CQW0I
aj+CDYfmIluQM5c/+MOpOfK9zIcn7Z/+8z848s+Lto2W68e70PDNW7TcMEgH LH1NPn3RvrYm
5p3t+dEHL9qYoEMzsOKfvUjf4h13og9EReMNmdeHqiSIw15nKOp9lZcVQxYE bXiy4LvnXpyc
cK45tS5OYsJeoanOBeEkpsFJlpWTzyb6IcVM/O5yjizKSYJrgmoRLkj/9TK4 EOBovqmJ1dwv
H15yGImPyTwnC9KsUib62LFvLMd2i5ePQYo0yI9IiG9ekZ+ecLYbhKY7soLC GYR0hiV25nGT
ewjsZzEFh0imPPfjgKzm48vF8ODZ4Nf3r5HyM28t3R2frENfSoFnYCPo0/jn QXv5Y6RdZ5Yf
2utpItM04U+IU3yyRmObydZ7Z/nBDD885c462Qm+QsMXUvh4H0XbiMMPeVk8 ngXt4wJLsMYy
xaLNnXOpmCEpi6QWfabHy+Mutb/RZisr/UjWI067ptP6zfM/XVvuaPKb7Y69 +0Kjdb7WHVur
iIfR+djyW3+Yd2YZ975iAxa5Tdkp/hiHmAbvzNEnLK4PM8fz09v0K1q6TSvd 7TxSNEEsfOch
wtdHpqId+KN2+maJOjSoPUlRrau77kkOe9G46ByA9M3MCxBBNzzrgYX3sEFo c59VAnLbHLkF
f7AsXRAOA9PB/sLbeYgdhzEJfAk8BL5qeoZDMakPMu7ViGc4HEfYi3mDs6Fv je3wlT21Q1Aa
idKopQD8yJQGFIAfjtLAT0IDbZFoiw5oi8q1RQe0xWFoCzvoR2E5UBeJuqil DO7I1EXTyuBA
Xewov4EVEn1x7XmOZbpIbUjwMMraKniKaX2QegMqeA5IcWRDGWNvjpaAlEcX bsRh5VFh2/A1
5X9H9KgHPyIqKI9DUR5RSCOuGsZFw4XPBTwqrSHWoTXEI3qMgx8RFbTGE9Qa UDQMRcNHe8kp
nNhBCxfGteDZlWWoZP0L6FSOTnPTCU6j10grTk/PKm4Ltw/hoHZ/a18it66u rDuRqFT0f+QL
TCNt/xhOBI3P1PQ/WX7Qenj0xxjtdXI5PG+64iNKzUzZa68AX3bgy9onTaTM koXCMNYxHf6Z
phv25sRBbprHDwuscuql41i3ptP3b+f4PpH+MLKi21rcqSAeUauVKR8/fLOR PPrgIsUUnbIr
dk83xipm3mw+KxujyHK0XUrJrfi8i5WuXFmIF7q4nnWDDhYb7yNUzgr9SBih l2XDwjbVyIXj
vCuSe9BzHv0SsCHrXU0biIqqaWpHVw1D0TtGh5c7XWHNJeChN7bezx0rOBfE qu4Ar6LS4XU+
i8oq7J1v/xYAE2lgxbd/C2YQ0hlY3v4tAC6lwHe5/VswqUzThNXt3wL4Cg0f bv+mBs3FMRUO
7wgu2hJNVKMrSLIySxvv0OaIazi2Wlea/jqKIm3vzQ73ukXbhFTVCgHaX75o CK/Qymaa1meM
oiHyjskow3ZCHMDbKv9ER//MccX5JoIVvddLoDIaF+50aE7zBD0iRex1dbGP 3ZB1bVEu7enM
sQwE2PM/nwsSK68IodMXh2oGnco7oxSAFGmQ5X0jMoOQzlCnb0SASynwKnwj MqlM06Qu34jA
V2j44BttqjntQQC54prTPV2wyii4gzNWXPjWPa47Oo0rl22Cb7wuMpet4SLj ELEpn/iV7X5C
jA0n3Gju+8iuIf+ZGiIIO/rNlxPvngtccxZMPGQvb5C/EO5YxJW8WKrgetjR o648Xgg7kk2a
L7aI3GhhJKsk703sCRPq9oPAvnWxZ/dYxac0Xi5yMlojiSF94zUjFfG/c3v0 iSNHg2ijpiFk
Exkswojlz9BOrjuWsz5LsY6fxWmKLOtyAkR7Uqj8EbTIr0UeIk5CYAamyBA0 Shz9E5r4o2qO
/EXFgJWz+t7+t+mPz2fo3NMeeu6NfTv3LWrhFLcS5uBjxrMyi0rqCTNO+K/Y qw2Y1RCuLaDc
YcmFUo1rKuVtaMC3Kn76wGOtWtlm1QKP/6l66aubGAc76o2MxWQtUmsCL5TU TJvUE15Zqha/
S1XfypZafLWF1opW7KQEojXXZoO7mTNDx0vS/I0IWm7Ll3WluZtXb9iuHUwa JZmdppQlFzcF
PRof/48GViwfZ20GBBObE0yE8z9E5CAiV0lE7okkWKU+zxuqjjOanTUJ1vfW DakSSZOsMqsk
K0JJkiUtgxLzJCsBKdIgyydZyQxCOkOdSVYCXEqBV5FkJZPKNE3qSrIS+AoN H5KsyU/N8fit
P7b80+hv1EUQ+oFhjwiyq3vLy+F5dcwEY79DX8QLzsN/q2QFZIDolAJ343tT 9HaIjCpSO/gz
RHbutRVOvPFxZXxKUgQyPE8gw/OL5SJfMbQiPVJTeqcJBNMWx5RtM2KIWgEX 692319hdrZhs
EIyGYDQEo6vQCw0MRoNwViKcEM98YvFMZopm5VSqKnAofaw0w4EfOK8VhgfO 17hj5GLhp8EZ
F3rcX+3bCXI0L0fezDqKU2YpMux/tIwuRS7AxDNvcai8qehQuYrZL453nfKj IIBYOZ/XVt7E
GGXNkjt3lt6fdoQfhc7Z4qO1bCmxF6IYQt3CvpYIMUo7EGGH/im7C8kjEmhn Kdn+CnmJsOhh
XbeFs3KzjyNwVn6qTXVetEn2HBcEzHzvxnasZ1fvjKuk6ACN+X9QSwcIzgWg 8hglAACCxAIA
UEsBAhQAFAAIAAgApksQN84FoPIYJQAAgsQCABAAAAAAAAAAAAAAAAAAAAAA AFJlc291cmNl
Q29udGVudHNQSwUGAAAAAAEAAQA+AAAAViUAAAAA
name="AutomatedGUISuite.execution"
filename="AutomatedGUISuite.execution"
UEsDBBQACAAIAIZLEDcAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c91WyW7bMBC9
F+g/COylPVi0vESWYTfQ5tRAixaJE/QWsBRjE7VEgaTs5O87WuzKW+0kPrS9 SeTwzZt5b0QN
Lh/jubFgUnGRDJFlNpHBEioinkyH6HYyavTQ5ce3bwa+iGOR3E+Y0qkUD3zO +pNvo/CR0UzD
0Wumsrk2HmPeX4O1cjCAT1Qf1odopnXax3i5XJoinppCTvH3L+N1iNoMWbaL iFazaUHY5xs6
YzFp8ERpklC2OlXR8tiMLLiQ9+NEM0loTkltwDE656liBebsiURM4VhEbK4w LSDwjwoC8xqE
CcS3UtU68LwE+vfBEpZHQxQ6zshx22E76Lod1wo9exQEjtvsdD3PsgIfGQmJ IZGbaRETzaKr
2/FNxjU0APoccaqHKCVKIUM/pRAH2ddMShZmntckcN6cZrx4KwFAVcMYsJWC n7jSQj4Vq/X1
cMESrQyQp1+m2O+ECexFRSxQ4TFskjgFQ1k9u2U3ez2r020j/FL0cbIQlKwP lL0LPMB1/NC1
/Y7b9d0g9C3HtZodz/bz3r23PiBDLBMmxydEH6J90UMGrOoM/KQySplSD9kc VZVALTW/jCSZ
xsBvt569Bu17d9frCfpKaSYlK7w9k+xhiHKpGpIpkUnIincsUGip8qd3R4vD db4L8RO02hrd
Uzp6JtNVRA5Yb3v3BQY8h+gbbP49mQvOeKuJr+vwXan98ybwvnLMH0TxA791 YQebc7tHF6fd
trvbFsR/i2sqdmUy8HP6vzuotrc7wIM85fHuw6tP1DkK2TZR/YuH93/yVpfR gRpfOR9rNx27
4l9k93Pfz7vuLTMdEPl0eauflWfre/THKOc3wCf9lkLkL1BLBwhiqjeSfAIA AOgKAABQSwEC
FAAUAAgACACGSxA3Yqo3knwCAADoCgAAEAAAAAAAAAAAAAAAAAAAAAAAUmVz b3VyY2VDb250
ZW50c1BLBQYAAAAAAQABAD4AAAC6AgAAAAA=
--------------070806030408020504030300--
Re: [AGR] Multiple tests in Standard Mode [message #109369 is a reply to message #109157] |
Fri, 17 August 2007 14:40 |
Paul Slauenwhite Messages: 975 Registered: July 2009 |
Hi Joel,
You are not executing your other test case since you did not added their
invocations to the behavior of the test suite. You have only added Complete
Test and Automated GUI Test. I have added the remaining test case
invocations to the behavior of the attached test suite. Of course, I cannot
run your test suite since I do not have your application being tested but
everything else looks fine.
The only thing that is puzzling me about the test suite and execution
result you attached, is that the Automated GUI Test invocation did not get
executed. Could this execution result have been generated before you added
the Automated GUI Test invocation?
Paul
news:fa1kfa$ro4$1@build.eclipse.org...
> Hi Paul,
> not.
> Thanks!
> -J
>> Hi Joel,
>> invocations
>> test
>> Paul
>>> results
>>> fine.
>>> siblings)
>>> Thanks!
Re: [AGR] Multiple tests in Standard Mode [message #109385 is a reply to message #109220] |
Fri, 17 August 2007 14:41 |
Ho Joel,
Either way, I would like to understand what is causing this problem.
Can you attach the test suite you are running from ANT?
Paul
news:fa2k85$oll$1@build.eclipse.org...
> Hi Paul,
> Very odd -- this only wants to run the first test from the GUI, but if I
> run from ant, it all works fine.
> I can live with ant for now.
>> Hi Joel,
>> invocations for each of your 'mini tests', each invocation will be
>> invoked during test execution. For example,
>> Paul
>>> work fine.
>>> Thanks!
Re: [AGR] Multiple tests in Standard Mode [message #109603 is a reply to message #109560] |
Mon, 20 August 2007 16:33 |
Alessandro Tucci Messages: 33 Registered: July 2009 |
Member |
--------------090804090602080307020808
Content-Type: text/plain; charset=ISO-8859-15
Hi Paul,
the test-suite keeps on having no verdict.
I re-created and re-executed the test suite, as you will see from the
attachments. My JRE vendor is "Sun Microsystems Inc.", as you can read
in .log file. Thanks to the "wait" commands, I could clearly see:
- the workbench and the project window being opened;
- the text field being filled in with "Java Project";
- the project window and the workbench being closed.
Although this, The "Events" tab in .execution files still showed:
start
+ invocation
+ test execution
start
and no JavaProject appeared in the project explorer. Therefore, I looked
for the .log file and I surprisingly found a JavaProject directory in:
<Eclipse installation directory>/auto-gui-workspace
Creation date and time let me be sure about the fact that it was created
during the test.
Anyway, I can see from the log that there is some problem about JMX. I
already followed the tutorial about JMX:
http://www.eclipse.org/tptp/monitoring/documents/tutorials/t ptp_max_tomcat_demo/viewlet.htm
and everything worked good.
Thanks for your patience,
Alessandro Tucci
> Hi Alessandro,
> Everything looks fine in the test suite. The execution result is
> missing content on the actual execution of the test. Does the <Eclipse
> installation directory>/auto-gui-workspace/.metadata/.log file exist? If
> so, can you ZIP and attach it? What JRE vendor and version are you using?
> Can you trying adding a few waits to your test maco:
> <macro version="1.0">
> <shell descriptive="Java - TestContainer/test-resources/AutomatedGUISu..."
> referenceId="0" return-code="-1">
> <command descriptive="Java Project" type="select" referenceId="1"/>
> <shell descriptive="New Java Project" referenceId="2" return-code="0">
> <command descriptive="0.5 seconds" type="wait" time-to-wait="500"/>
> <command type="modify" referenceId="3">
> <![CDATA[JavaProject]]>
> </command>
> <command descriptive="Finish" type="select" referenced="4"/>
> </shell>
> </shell>
> </macro>
> Paul
> "Alessandro Tucci" <intucci@tin.it> wrote in message
> news:fa9abm$qc9$1@build.eclipse.org...
>> Hi Paul,
>> thanks for your interest. I am going to attach the .testsuite file to
>> provide a better vision of the problem.
>> Thanks again,
>> Alessandro Tucci
>>> Hi Alessandro,
>>> I wouldn't think that your problem is related to Joel's problem. Can
>>> you attach your execution result file (*.execution)?
>>> Paul
UEsDBBQACAAIAKOQFDcAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c81YbW/iRhD+
nl/hulK+nPALCQkhwAkM7nHNmwJJKp1OaGMW2Dvb63oXSBrlv3fWbxi/AKGt 1A9JzuPZmXlm
ZmceX/Pzi2NLS+wzQt2WrCuaLGHXohPizlryw8is1OXP7aOmQR2HuuMRZtzz 6ZTYuDG6M8Xj
cEE4ll4c0kisVIUVsOuyBshb8pxzr6Gqq9VKoc5Mof5M/eN6kKiwTZXVSaBR 1TQd1K6G1hw7
qEJcxpFr4fhUFFAXz9GSUH88cDn2kcUhALZhDls28RgObM5f0QQz1aETbDPV Ckyoz5EJlaRM
KBB4xlUK+8cc8PXB0CyZtOT+manX6+aFXq/V+j3zoluta51OVzs1T2q63jNk CQxZPvF4kFKT
+IxLvz0MJGFNYiLpsuQiB2LpLDh1EMcTeD0MX4TZ4gRF+Sjy1tMNPfYmZRV0 7aTTOe+IcM7C
cPirB74AZAI4BKuIgBQEMSizBQmeoiA80Q+MQzvhASD+EqibyII/95jRhQ/V bB9JUjOuLSvN
TDpWWbLJFNvExaW61bWuZSPGRkHsO1Ou7hmNWe+l6hQWoW9cDe6G/fHT7f3v 3f6N8eUj1vSs
tQewZDzc3/dvRimLUFYCNbUfkb0AJe4v8F5eoJhn8JwqZujltvu1b4zG14Ob ftb2sc0v6fMP
bPGKA5luH//60rmEXxeX6zcsLd18tW7eJW4d/7mg/HI4x7bdkL6iJZIqkrhM BnU5AuO+ynxL
Fdcn6qzgxjAV5gmZEktRlNCC5OMp9qN2CkVa9IbEgnR/QjcGV9pFtvJE/Z/P cHT+RNwJXYXK
ufh3grjG7mLAsRPhuPOpUCwNT4/eWIAUv/BE7oAZlpxi1AaogyII3ONe5oK5 YMsnSyhVFvvb
mwkjpnKDV8fI8S7FjwA0nJMp/9Sx+aebSjrq9/fK2xsM/Pf38LhaVE41TMUh lYY49stSdVsR
f0yRhZUV+Qv5E+Up+NMD7HR2aAlHUIjSUE5KChb6r3hohtUhcTwbR6CCuXwH 4n+9mpGD4Ko2
yiq0E213wTl1G5IJ15vNS3GfbsV9IDY0QUEo+T7Vzw5tvrU0nj5rSWpS7TsW MzuufLFEuvpa
9+OLJSYa27Zcbq/klvs4NiMHBRFbdHMtB8NTiYZnQACUOaU/mfKYEhkiegBM w8eWrOYmcrCb
gyQmtCiUgCxO1NaNXc1iGTNsT6+iozFJgerssfPVxHUqHNNHMxilnEnAIRsh QdnGCxvdx/v+
C7YW4unWshZ+cAuKCdlF7fSk1j3NLU3Dx1COeKjBKiPuMsqiLFE+x37su7iL 6trF2mYEq6lm
ktxMWGnwJEpqIFbex+eGfp6KdIM6hgEzCUkuTOQfYiJ7YfDFkA6gehGKrQ2e w17ofN3dRQWP
ZTs7MH9dP9qBueGgppz/wx68xozByui7k+LWE76Nfnfte+0anDvhaaZuSKGk wLc52ZIQMJlL
CHyoLUPGt7F0J1ywJ7G974DEe1AYmOPyIR6rWY964lGMbgdZPk2+PyPWpGj5 5Q66TPCKgh33
31BKH/OF71bgUzj2U9FLOAfEJj71kDspi26TAgVdEv4b+nEPAlm4HcvS8WHe lUdakP890WpK
TWIYaMSE5cGuEElSQBxc4bQiRNHbmqbtojmx35RN+NQm09ddhK7U4i/fjF5n 1PkWtHqYr+/f
S7XVKID/bWLyfjeI3/6Nd7qNlgWdl2VlaaF4Dm52e2NsqkVzM5nz2R2Y24Jq sgbbR011x/9I
tY/+BlBLBwhvRxOFHAUAANsSAABQSwECFAAUAAgACACjkBQ3b0cThRwFAADb EgAAEAAAAAAA
AAAAAAAAAAAAAAAAUmVzb3VyY2VDb250ZW50c1BLBQYAAAAAAQABAD4AAABa BQAAAAA=
UEsDBBQACAAIAF2RFDcAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c91VXW/aMBR9
51dE2cv20DgJBEIEVEDJirRpU0unvVWZY4jV2Ea2w8e/381HWQqpytD6srfY vveee+45jgfX
O5YaGyIVFXxoOpZtGoRjEVO+GpoPi/DKN69HrcFUMCb444IovZZiSVMSLL6H sx3BmYbMO6Ky
VBs7RoNDLTevBdW5CmB/aCZarwOEttutJdjKEnKFfn6dH0LUy5Btu4hwbduB sC/3OCEsuqJc
6Yhj8pxVtTUhSbShQj7OuSYywnlL6kU5glO6VqSomeyjmCjERExShXBRAv2q SiBaK2FB40dQ
tQn8HYD+k1iWpfHQnHVDx/fDvuN73uwm7E9c3x6PJ3YnbHuOczM1DR4xABpn WrBIk/jzw/w+
oxoGoPdrOAC4A3QJa+VAVgQJ1iqjxarMGLUMY0CeFbulSgu5zzfr27MN4VoZ oEZQAjQLv4Cz
uIiFRiiDw4itwT6O3+u6Xddz+3bPRBcWn/ONwNEhoXlSfa/T9iadfFLdfFIf nU+mIbacyPkZ
0a913XFNA3Z1Bu5RGcZEqWWWmiURoFIzRyijFYP2Tuk0ujGY/Lg7XJdvGGdS ksLIiSRLAJMY
5daptCzcohDcJbqk5SxQIsSTQidOKBRW+deHN1mjGpGNeAIJjy7wOZO+0HoV cLMBjw8vsOG/
0L7ezH+kdkEGHQ23pgl6XZRBjve2DrCcRup9+Tl2uzd1ek1uRs12rv4/Tcyb OZ/PtvoJvyPd
k6cA6A7QWe/wqPUbUEsHCFDpWicwAgAA1wcAAFBLAQIUABQACAAIAF2RFDdQ 6VonMAIAANcH
AAAQAAAAAAAAAAAAAAAAAAAAAABSZXNvdXJjZUNvbnRlbnRzUEsFBgAAAAAB AAEAPgAAAG4C
AAAAAA==
Content-Type: application/x-gzip;
name=".log.tar.gz"
Content-Disposition: inline;
filename=".log.tar.gz"
H4sICFu9yUYAA1d3OGRYYi50YXIA7Vxtb9s2EM7X+VcwQD+kQE1LsmQ7wTzA dd3WXZIWcYps
GIaCkRiZrUy6FJU4+/UjJb+bfmnctOt6DxAUkqi74/F495gHFSciPnhkOBo1 3zf/uvXAya/d
4loj8By/duA6tZpXrdZ8Vz93ncB3DpDz2IYZZKkiEqEDokaNYOM4KtNvYdC3 xWGv0+t1354j
z3HqZadR9hzkNk5c56TqYy8IUPnLUKJhwoYpxdcZS6Ju1OwawU7NC8pu4Dil j+SW4FvtSiZ4
08UBdj643uQuj4Rs9jKOzlgoRXqfKjpIUZeHuPRcCHUqSEQlCgXXa8ZVeoLe 9poJ49noGWpd
tF83R43aM3TVa8bq0zN0ftpk6kP3stQWgwHhUVmPpIjIOBvQ/GVUjogiqNIX A1rJl7/yTopY
ksGAVd5oiyrdF53KeD4ftAhVuRPyUzokIa1gXCGZEuU4Y+Xp3VLpsHN+efEn EjLGE0eooRri
geBMCcl4jLUgEtNI/3GFM4Y85Kw6329gzw9Kh2d6dVqvOqh71bp06t7xFWoT zoVCJIrQQEQ0
yd2hpyRLh73LVvt35JbmtYdCUiwzrtiA4ra+6IxCOlTa+yfoXZLFZcZ3t/bj YITuSIoyTq4T
ipRAiV4SFCYkTb9ICmZcUclJgklobEnxKcl42H9z9sdZMbRlhrbyh7j0C1Fo ZVJTEZLGLFXy
Hos0ZvhifNVTkiga37/tvepi1ZfibjrzI+sYE4MnbsN5ur+6UFJ90RnRMFPG U52Rojzdornm
7ax5Km8iboPG1bG5unqjsbO6tuA3LM60xVpMJ6Fm/2zQaB2eK/X86l5KX+tt nNAvVD1+KTcg
cFf1b9mfmI6GiTZRzmwswrIIVImHUoQ0TYubOoHcMp2kxrrTo8WxxUo7/te3 4lemX/3Npq5a
20Pb0MzHuFYrnN+Z77smeTCuVy9JaKgWZ58eWccWMeDsswZb7THVXG1Q7zqW uM938o1O/NSk
8pmL89B8npn40ZGl6Eh1B8PkiWcS6tHK/ULB8fFxoSCvaamOUcnUvV4tEyRm tDQekzgS7yS7
ZQnVdh6d64C9peiMqr6I9rWv8IFZkVui/bneUMtmfIimtQrqljjfQcFrkapC 8pUeQicTyG8X
Ee1bQnqj4Na1zim61BSSxmYv3Syis2bJ/0uiM8US3DMLS8cFqpC3cCuX5jvr qsmkIs/qYESG
erFwpxh1Sv7RNUJLNTGvJ/6S8ehUhCRpm1p7ZBlVRLdr2Vy5+dckpRMdSc6j cC5qSFR/ki5u
FpWsPC/m5NbXqJjOZV7XC3pDskTlsgr+tqzGMmJcio8fFD52LQvPxlG0fam3 yM9Fd8djLCr8
ByabZRU262t7e2et6GDfFTYBtnlxG9W5JJkQnfLt76+86NlK+O7znklenbf3 wIDLE9Oy4Fm2
8rx17twxW81E2zKW69ki4RtR1t3JMlDWR6Ss+gchu2EhKX5KLTDEnAJMCt70 utiDlh8cwISA
CQETAiYETAiYEDAhYEL/dSaUzW1FUyOvKQ/7xXnPEzcnJ0t3N8wlvdOOyVIl Bjqc0/sujwyl
MuypL+6u+pqgHC3eLzKbJeY2WDWd/2TWdvuqW6R2iEyKgpcNLzKen8fjmCpr ENnGjoukZUNu
VWO8ul5mzcJIFgp9j9xQ84pONkbS3GWRc7eYNPXXk8BfXOCx69zjrXvxo7hO cUGppiIm+oPg
6Y4NlL/cv0+W0/a5UC+FzklzXZZH64tsKBuzorZSNqpB44EFp+rUvk+p2olg eI/HAoBgAMEA
gvFzEgzoDkJ3EM7E4EwMzsTgTAzOxICyAmUFyvqDUVboDgITAiYETAiYEDAh YELAhH4eJgTd
QegOfv3u4GHv/fPiMy93QQr9nDEuRtM4R74eYP+yqz77suuH+Qhr/HnZ+BM+ aHlCyxNYE7Am
YE3/O9YELU9oecJBHxz0wUEfHPTBQR9QVqCsQFl/MMoKLU9gQsCEgAkBEwIm BEwImNDPw4Sg
5Qktz6/f8vze/0spAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGAd/gXZ JbMvAHgAAA==
--------------090804090602080307020808--
Re: [AGR] Multiple tests in Standard Mode [message #109720 is a reply to message #109603] |
Tue, 21 August 2007 10:51 |
Hi Alessandro,
This is very strange. Are you using the Integrated Agent Controller or
Agent Controller? I will find a SuSE 10.1 machine to see if I can reproduce
the problem. In the meantime, can you retry with a fresh workspace?
Paul
news:facfmn$ve7$1@build.eclipse.org...
> Hi Paul,
> start
> + invocation
> + test execution
> start
> during the test.
> Alessandro Tucci
>> Hi Alessandro,
>> using?
>> </command>
>> </shell>
>> </shell>
>> </macro>
>> Paul
>>> Hi Paul,
>>> Thanks again,
>>> Alessandro Tucci
>>>> Hi Alessandro,
>>>> Can
>>>> Paul
Re: [AGR] Multiple tests in Standard Mode [message #110029 is a reply to message #109720] |
Sat, 25 August 2007 16:17 |
Member |
--------------060301030104050401040809
Hi Paul,
I use IAC, therefore I retried with a fresh workspace using IAC the
first time and AC the second time. No difference.
The "Events" tab keeps on showing:
start
+ invocation
+ test execution
start
and no java project is created.
I'll re-attach the test suite, the execution file and the log file.
Thanks for your interest,
Alessandro Tucci
Paul Slauenwhite ha scritto:
> Hi Alessandro,
> Paul
>> Hi Paul,
>> start
>> + invocation
>> + test execution
>> start
>> during the test.
>> Alessandro Tucci
>>> Hi Alessandro,
>>> using?
>>> </command>
>>> </shell>
>>> </shell>
>>> </macro>
>>> Paul
>>>> Hi Paul,
>>>> Thanks again,
>>>> Alessandro Tucci
>>>>> Hi Alessandro,
>>>>> Can
>>>>> Paul
UEsDBBQACAAIACCRGTcAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c9VVTY/aMBC9
8yui9NIeiPNBRIiAVQJJi9Sq1S5b9bZyHQNWYxvZDh//vk7CQhayWkp76S2x Z96befMyGd7t
aG5ssJCEs5HpWLZpYIZ4RthyZD7O025g3o07wwmnlLOnOZZqLfiC5Dicf0uT HUaF0pn3WBa5
MnaUhEcst8TS6EyG+nxkrpRahwBst1uL06XFxRL8+DI7hsiXIVuvinBt29Fh nx/QClPYJUwq
yBB+zjqUFeMV3BAunmZMYQFRWZJ8AYdRTtYSV5irPcywBJRnOJcAVRDg5wEC kAaEpQs/o2oo
8GcE6pRYw5JsZE6TKB6kkTuI/dj27MhNEy+II9v3XMdxphPTYJBqoqhQnEKF s4+Ps4eCKC2A
2q/1haY7Ute0VklkQZ1gLQtSvdUZ445hDPHzxD4RqbjYl4fN42SDmZKGnkZY E7QPfq7vsipW
F0KovoR0re3jBIHtB47Xc/q+CW4En7ENR/CYUCs1SQdx4qZ+ZAe9JEliv+8F 6aRXKuWXSr13
PpgG3zIsZldEv1K167imoU9Vod0jC4SwlIsiN+tGdCsNc6QCLqku77KdVjeG 8ff74+fyFaFC
CFwZeSXwYmSWY+oKLHkhNCm4mHc1R1k+vXuzN9Aod8N/6UGdfabX6HmjwQ7E 7TY7v7zBbP9i
ws1i/ruZViWDMwkbyoPXpR+WfG+rrV8nUN7Sxfk268f9KJ4mp212ciZot+Zh Y7T1197Z9T0d
1uZfN3WxonVTQ3DV/3Hc+Q1QSwcIi/V7sjUCAABvBwAAUEsBAhQAFAAIAAgA IJEZN4v1e7I1
AgAAbwcAABAAAAAAAAAAAAAAAAAAAAAAAFJlc291cmNlQ29udGVudHNQSwUG AAAAAAEAAQA+
AAAAcwIAAAAA
UEsDBBQACAAIAAORGTcAAAAAAAAAAAAAAAAQAAAAUmVzb3VyY2VDb250ZW50 c81YWU/jSBB+
51d4vRJv8ZGDIxyj2HFmMsslCLDSaIQap5M02G5vdzuBRfz3LZ9xfJCQ2ZX2 BXB1ueqro6s+
c/zlxXWkOWacUO9E1hVNlrBn0zHxpify7WjQOJC/nO4cm9R1qfcwwlz4jE6I g7ujq0H4eBMQ
gaUXl3QzK83QCtj1eBfkJ/JMCL+rqovFQqHuVKFsqv55PsxU+KrKohVpNDVN B7WzG3uGXdQg
HhfIs3H6VgLIwDM0J5Q9DD2BGbIFAOAr5rDtEJ/jyObsFY0xV106xg5X7ciE +piYUEnOhALA
C65ysX/OgVi+GJsl4xO5b/WMw0GveWh0DK2l9ZoDq3Vg9LROq6nret+UJTBk M+KLKKUDwriQ
vt4OpdCaxMOky5KHXMDSCwR1kcBjOL6JD+JsCYKSfBS9tTS90+5pmTepqLBv HGgts5mDI159
8AVBZgHHwSohIAUBBmUakOgpAeGH/cAFtBMeQsTfIvUBsuHXNeY0YFDN0x1J Ok5ryyszU8Qq
Sw6ZYId4uFJ3T+t3crq2gzgfRdjXplzdDM2+bpk5D3ERLPNseHVjPdxfXv9h WBfmt89Y04vW
bsGSeXt9bV2MchahrARq6twhJwAlwQK8kZd9Y/+wY3VKmC+N75Y5ejgfXlhF 27uOOKKPT9gW
DRcyfbr7+0vvCH4cHi1PeF66erRs3jk+2f0roOLoZoYdpyt9R3MkNaTwMpnU EwiMs+iGNFjS
E1xdbWhFUWILEsMTzJJ2ikVackJSQb4/oRujK+0hR7mn7PkRXp3dE29MF7Fy Cf/aIM6xFwwF
dpM4rhgNFWvh6cmJDZHiF5HJfeoHvjoneKHmAT+NRQj6CtnPaIqtF9+hDLLz 9qa+vzfe3mA4
v79nvjh1YOAOqwIXvvAL19IDBIzMocDFjL29XeBFIx9O0ZlaVWc1ztE2LQD+ Nktf86PqPk2Q
jZUF+RuxsXIf/epDeHS6bW1HUKFaKK2aSsb+Gz7US70hru/gJKhoYF+B+F8v WOIgusPdugqt
jdYIhKBeVxrAveez2rjbH8a9ZWxojCIo5VbU97ZtvqU0HUtLSW6EbTgvi8uv fuMkuvqvbJyU
gdStiHa/3S8N79LWf0jNyFI6Slf3dVgErkCdyITYETNQZpQ+c+UuJzJD9BAw jR9PZHV1VHNm
R0s7SmLGl2IJyNJE1a67wnqOY3ng2JmcJa+m7AWqswEZUDPXOTgDhqYu9gSX gFx2Y+byEWHs
GnfX1gu2g/Dp0rYDFt2CmKmZg0PDag46Pe2gbVmW0dlvHQzMdgihU1mQiKaF WYM9R7x5kklZ
omKGWeq/upP0jl4K7VgtJPo4o6zRU1hWE/H63d8z+lYdrzQZBshcQpKXTmU/ ni/1YW3BBZNI
Pmz0Uvy1AJadXlX8VLa2G8tX97PdWBoUas75L/bjOeY8ZAHeuPqDAXzrzb2D pe+la3Duxm9z
dUUKpQVSLkh9QnSzWea28DU3j2lhBVsJe+YKmL4PPQMzXd7GY6kEeuYxHOMu shnNPlITaqVo
5UUPujzkGBX77r/hnQyLgHkN+F5O/TT0Gv4B2MLvQeSN69Ct0qGoS+K/oR83 YJmVm7IuHZ/m
YOVIK/K/YbSa0pE4Bkox5uVgF4hkKSAubgjaCEXJaUfT1lGe1G/OJnyPk8nr OnJXa/G3H2a/
N+r9iFo9ztfPn7XaagLgf5uYst8VErh547U/omhR5xUZWl4YPkc3+3RlbKpV czOb88VdWNqG
arYOT3eO1TX/tjrd+QdQSwcI0msgdSYFAAAAEwAAUEsBAhQAFAAIAAgAA5EZ N9JrIHUmBQAA
ABMAABAAAAAAAAAAAAAAAAAAAAAAAFJlc291cmNlQ29udGVudHNQSwUGAAAA AAEAAQA+AAAA
ZAUAAAAA
Content-Type: text/x-log;
name=".log"
filename=".log"
!SESSION 2007-08-25 16:59:58.615 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.version=1.6.0_02
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=it_IT
Command-line arguments: -os linux -ws gtk -arch x86
!ENTRY org.eclipse.tptp.monitoring.managedagent.ui 2 0 2007-08-25 17:25:35.666
!MESSAGE IWAT0729W Cannot add model consumer
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in org.eclipse.tptp.monitoring.managedagent.jmx was unable to load class org.eclipse.tptp.monitoring.managedagent.jmx.internal.action s.LaunchJMXManagedAgentAction.
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
at org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.tptp.monitoring.managedagent.ui.explorer.interna l.ActionManager.processActionProviderElements(ActionManager. java:104)
at org.eclipse.tptp.monitoring.managedagent.ui.explorer.interna l.ActionManager. <init>(ActionManager.java:36)
at org.eclipse.tptp.monitoring.managedagent.ui.explorer.provisi onal.ManagedAgentUIPlugin.collectActionProviders(ManagedAgen tUIPlugin.java:201)
at org.eclipse.tptp.monitoring.managedagent.ui.explorer.provisi onal.ManagedAgentUIPlugin.start(ManagedAgentUIPlugin.java:10 8)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at org.eclipse.tptp.monitoring.notifications.internal.Activator .start(Activator.java:82)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:243)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:49)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:239)
at org.eclipse.ui.internal.EarlyStartupRunnable.getExecutableEx tension(EarlyStartupRunnable.java:117)
at org.eclipse.ui.internal.EarlyStartupRunnable.run(EarlyStartu pRunnable.java:66)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.ui.internal.Workbench$54.run(Workbench.java:2190 )
org.eclipse.core.runtime.CoreException[1]: java.lang.ClassNotFoundException: org.eclipse.tptp.monitoring.managedagent.jmx.internal.action s.LaunchJMXManagedAgentAction
at java.lang.ClassLoader.findClass(ClassLoader.java:358)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:429)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2007-08-25 17:25:35.668
!MESSAGE Plug-in org.eclipse.tptp.monitoring.managedagent.jmx was unable to load class org.eclipse.tptp.monitoring.managedagent.jmx.internal.action s.LaunchJMXManagedAgentAction.
!STACK 0
!ENTRY org.eclipse.jdt.core 4 4 2007-08-25 17:31:30.992
!MESSAGE Background Indexer Crash Recovery
!STACK 0
java.lang.OutOfMemoryError: Java heap space
at org.eclipse.jdt.core.compiler.CharOperation.subarray(CharOpe ration.java:3266)
at org.eclipse.jdt.internal.core.search.indexing.BinaryIndexer. decodeFieldType(BinaryIndexer.java:272)
at org.eclipse.jdt.internal.core.search.indexing.BinaryIndexer. indexDocument(BinaryIndexer.java:735)
at org.eclipse.jdt.internal.core.search.JavaSearchParticipant.i ndexDocument(JavaSearchParticipant.java:74)
at org.eclipse.jdt.internal.core.search.indexing.IndexManager.i ndexDocument(IndexManager.java:314)
at org.eclipse.jdt.internal.core.search.indexing.AddJarFileToIn dex.execute(AddJarFileToIndex.java:197)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:392)
at java.lang.Thread.run(Thread.java:619)
!ENTRY org.eclipse.core.jobs 4 2 2007-08-25 17:31:31.639
!MESSAGE An internal error occurred during: "Building workspace".
!STACK 0
at java.util.zip.ZipEntry.initFields(Native Method)
at java.util.zip.ZipEntry.<init>(ZipEntry.java:96)
at java.util.zip.ZipFile$2.nextElement(ZipFile.java:329)
at java.util.zip.ZipFile$2.nextElement(ZipFile.java:299)
at org.eclipse.jdt.internal.core.JarPackageFragmentRoot.compute Children(JarPackageFragmentRoot.java:86)
at org.eclipse.jdt.internal.core.JavaProjectElementInfo.initial izePackageNames(JavaProjectElementInfo.java:248)
at org.eclipse.jdt.internal.core.JavaProjectElementInfo.getProj ectCache(JavaProjectElementInfo.java:221)
at org.eclipse.jdt.internal.core.JavaProjectElementInfo.newName Lookup(JavaProjectElementInfo.java:285)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:2201)
at org.eclipse.jdt.internal.core.JavaProject.newNameLookup(Java Project.java:2211)
at org.eclipse.jdt.internal.core.JavaProject.findType(JavaProje ct.java:1263)
at org.eclipse.jdt.internal.core.JavaProject.findType(JavaProje ct.java:1170)
at org.eclipse.pde.internal.core.util.PDEJavaHelper.isOnClasspa th(PDEJavaHelper.java:61)
at org.eclipse.pde.internal.core.builders.BundleErrorReporter.v alidateBundleActivator(BundleErrorReporter.java:452)
at org.eclipse.pde.internal.core.builders.BundleErrorReporter.v alidateContent(BundleErrorReporter.java:99)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.validateManifestFile(ManifestConsistencyChecker.java:2 55)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.validateProject(ManifestConsistencyChecker.java:240)
at org.eclipse.pde.internal.core.builders.ManifestConsistencyCh ecker.build(ManifestConsistencyChecker.java:174)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildMan ager.java:624)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:166)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:197)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:246)
at org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:249)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop (BuildManager.java:302)
at org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:334)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBu ildJob.java:137)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJ ob.java:235)
!SESSION 2007-08-25 17:32:05.058 -----------------------------------------------
!ENTRY org.eclipse.tptp.monitoring.managedagent.ui 2 0 2007-08-25 17:32:22.245
!STACK 1
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2007-08-25 17:32:22.262
!STACK 0
!ENTRY org.eclipse.jdt.core 4 4 2007-08-25 17:33:00.482
!STACK 0
at org.eclipse.jdt.internal.compiler.util.SimpleLookupTable.<init >(SimpleLookupTable.java:37)
at org.eclipse.jdt.internal.compiler.util.SimpleLookupTable.reh ash(SimpleLookupTable.java:147)
at org.eclipse.jdt.internal.compiler.util.SimpleLookupTable.put (SimpleLookupTable.java:108)
at org.eclipse.jdt.internal.core.index.DiskIndex.computeDocumen tNames(DiskIndex.java:249)
at org.eclipse.jdt.internal.core.index.DiskIndex.mergeWith(Disk Index.java:481)
at org.eclipse.jdt.internal.core.index.Index.save(Index.java:17 6)
at org.eclipse.jdt.internal.core.search.indexing.IndexManager.s aveIndex(IndexManager.java:583)
at org.eclipse.jdt.internal.core.search.indexing.AddJarFileToIn dex.execute(AddJarFileToIndex.java:200)
!ENTRY org.eclipse.jdt.core 4 4 2007-08-25 17:34:37.509
!STACK 0
at org.eclipse.jdt.internal.compiler.util.HashtableOfObject.<init >(HashtableOfObject.java:38)
at org.eclipse.jdt.internal.compiler.util.HashtableOfObject.reh ash(HashtableOfObject.java:139)
at org.eclipse.jdt.internal.compiler.util.HashtableOfObject.put (HashtableOfObject.java:112)
at org.eclipse.jdt.internal.core.index.DiskIndex.copyQueryResul ts(DiskIndex.java:348)
at org.eclipse.jdt.internal.core.index.DiskIndex.mergeWith(Disk Index.java:506)
!ENTRY org.eclipse.jdt.core 4 4 2007-08-25 17:40:59.042
!STACK 0
at org.eclipse.jdt.internal.core.index.DiskIndex.copyQueryResul ts(DiskIndex.java:352)
!ENTRY org.eclipse.hyades.trace.ui 4 0 2007-08-25 17:48:43.710
!MESSAGE
!STACK 0
org.osgi.framework.BundleException: Exception in org.eclipse.hyades.trace.ui.UIPlugin.stop() of bundle org.eclipse.hyades.trace.ui.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s top(BundleContextImpl.java:1056)
at org.eclipse.osgi.framework.internal.core.BundleHost.stopWork er(BundleHost.java:457)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.susp end(AbstractBundle.java:526)
at org.eclipse.osgi.framework.internal.core.Framework.suspendBu ndle(Framework.java:1148)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d ecFWSL(StartLevelManager.java:675)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:291)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.s hutdown(StartLevelManager.java:261)
at org.eclipse.osgi.framework.internal.core.SystemBundle.suspen d(SystemBundle.java:188)
at org.eclipse.osgi.framework.internal.core.Framework.shutdown( Framework.java:622)
at org.eclipse.osgi.framework.internal.core.Framework.close(Fra mework.java:525)
at org.eclipse.osgi.framework.internal.core.OSGi.close(OSGi.jav a:41)
at org.eclipse.core.runtime.adaptor.EclipseStarter.
Re: [AGR] Multiple tests in Standard Mode [message #111516 is a reply to message #109720] |
Thu, 06 September 2007 12:37 |
Hi Alessandro,
I was able to run your test suite using TPTP 4.4.1
(TPTP-4.4.1-200708280100) with the IBM 1.5.0 JRE. Can you try the IBM 1.5.0
JRE:
http://www.ibm.com/developerworks/java/jdk/linux/download.ht ml
Paul
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:faeg4a$41d$1@build.eclipse.org...
> Hi Alessandro,
> reproduce the problem. In the meantime, can you retry with a fresh
> workspace?
> Paul
>> Hi Paul,
>> start
>> + invocation
>> + test execution
>> start
>> during the test.
>> Alessandro Tucci
>>> Hi Alessandro,
>>> If
>>> using?
>>> </command>
>>> </shell>
>>> </shell>
>>> </macro>
>>> Paul
>>>> Hi Paul,
>>>> Thanks again,
>>>> Alessandro Tucci
>>>>> Hi Alessandro,
>>>>> Can
>>>>> Paul
Current Time: Thu Apr 25 02:00:07 GMT 2024
Powered by FUDForum. Page generated in 0.04728 seconds
