Home » Archived » M2M (model-to-model transformation) » question about "ATL/Tutorials - Create a simple ATL transformation"
question about "ATL/Tutorials - Create a simple ATL transformation" [message #850706] Fri, 20 April 2012 08:49
Luke Ji is currently offline Luke JiFriend
I am learning ATL. I tried to follow the tutorial "ATL/Tutorials - Create a simple ATL transformation" at wiki.eclipse.org/ATL/Tutorials_-_Create_a_simple_ATL_transformation
but the transformation does not work out. I got exactly the same results as described in
www.eclipse.org/forums/index.php/m/630233/
Upon close examination of the ecore files generated by Eclipse on my PC, I noticed that it is quite different from the text listed at the wiki tutorial page. Some of the differences are marked in red. I tried several versions of Eclipse and ATL SDK on my PC, and the files on my PC remain the same.
If I simply copy the files from wiki page to my PC and use them in the ATL project, the transformation could generate the same result as the wiki page.
Can anyone give an explanation for this and how I can generate the same files as on Wiki page?
Thanks in advance!
wiki file
<?xml version="1.0" encoding="ISO-8859-1"?>
[color=red]<xmi:XMI xmi:version="2.0"
xmlns:xmi="//www.omg.org/XMI" xmlns:xsi="//www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="//www.eclipse.org/emf/2002/Ecore">[/color]
<ecore:EPackage name="Families">
<eClassifiers xsi:type="ecore:EClass" name="Family">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" ordered="false"
unique="false" lowerBound="1" eType="ecore:EDataType //www.eclipse.org/emf/2002/Ecore#//EString"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="father" ordered="false"
lowerBound="1" eType="#/0/Member" containment="true" eOpposite="#/0/Member/familyFather"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="mother" ordered="false"
lowerBound="1" eType="#/0/Member" containment="true" eOpposite="#/0/Member/familyMother"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="sons" ordered="false"
upperBound="-1" eType="#/0/Member" containment="true" eOpposite="#/0/Member/familySon"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="daughters" ordered="false"
upperBound="-1" eType="#/0/Member" containment="true" eOpposite="#/0/Member/familyDaughter"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Member">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" ordered="false"
<eStructuralFeatures xsi:type="ecore:EReference" name="familyFather" ordered="false"
eType="#/0/Family" eOpposite="#/0/Family/father"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="familyMother" ordered="false"
eType="#/0/Family" eOpposite="#/0/Family/mother"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="familySon" ordered="false"
eType="#/0/Family" eOpposite="#/0/Family/sons"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="familyDaughter" ordered="false"
eType="#/0/Family" eOpposite="#/0/Family/daughters"/>
</eClassifiers>
</ecore:EPackage>
</xmi:XMI>
my file
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="//www.eclipse.org/emf/2002/Ecore" name="Families">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName" lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="father" lowerBound="1"
eType="#//Member" containment="true" eOpposite="#//Member/familyFather"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="mother" lowerBound="1"
eType="#//Member" containment="true" eOpposite="#//Member/familyMother"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="sons" upperBound="-1" eType="#//Member"
containment="true" eOpposite="#//Member/familySon"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="daughters" upperBound="-1"
eType="#//Member" containment="true" eOpposite="#//Member/familyDaughter"/>
</eClassifiers>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName" lowerBound="1"
<eStructuralFeatures xsi:type="ecore:EReference" name="familyFather" eType="#//Family"
eOpposite="#//Family/father"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="familyMother" eType="#//Family"
eOpposite="#//Family/mother"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="familySon" eType="#//Family"
eOpposite="#//Family/sons"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="familyDaughter" eType="#//Family"
eOpposite="#//Family/daughters"/>
</eClassifiers>
</ecore:EPackage>
[Updated on: Fri, 20 April 2012 08:51]
Report message to a moderator
Previous Topic:[Solved][ATL] Inconsistencies between normal and programmatic execution mode
Next Topic:ATL from XMI files
Current Time: Sat Feb 22 11:34:28 GMT 2020
Powered by FUDForum. Page generated in 0.06346 seconds
