AGR 4.3 -> AGR 4.4 [message #108461] |
Fri, 10 August 2007 20:00 |
Originally posted by: joel_patterson.verizon.net
I recorded a number of AGR tests in TPTP 4.3 under Eclipse 3.2.1.
Will they run in TPTP/AGR 4.4 with Eclipse 3.3 -- I brought up the
workspace there and it's acting odd -- I see the list of tests, but not
the tests themselves.
Re: AGR 4.3 -> AGR 4.4 [message #108837 is a reply to message #108585] |
Mon, 13 August 2007 15:24 |
Hi Paul,
I recorded tests under 3.2.1 and TPTP 4.3 with AGR.
I then downloaded TPTP 4.4 with AGR and opened the same workspace.
The TestCases tab comes up and I see the list of tests, but I can't
select anything, see the recorded tests or do a playback.
Paul Slauenwhite wrote:
> Hi Joel,
> Yes, AGR tests recorded in TPTP 4.3 will run in TPTP 4.4 (e.g. backward
> compatible). What do you mean, 'I see the list of tests, but not the tests
> themselves'? Are you referring to the test navigator?
> Paul
> "Joel Patterson" <joel_patterson@verizon.net> wrote in message
> news:f9ig40$sjf$1@build.eclipse.org...
>> Hi,
>> I recorded a number of AGR tests in TPTP 4.3 under Eclipse 3.2.1. Will
>> they run in TPTP/AGR 4.4 with Eclipse 3.3 -- I brought up the workspace
>> there and it's acting odd -- I see the list of tests, but not the tests
>> themselves.
Re: AGR 4.3 -> AGR 4.4 (Fixed) [message #108876 is a reply to message #108837] |
Mon, 13 August 2007 17:09 |
Nevermind! Fixed it.
Joel Patterson wrote:
> Hi Paul,
>> Hi Joel,
>> backward compatible). What do you mean, 'I see the list of tests, but
>> not the tests themselves'? Are you referring to the test navigator?
>> Paul
>>> Hi,
>>> not the tests themselves.
FUDForum. Page generated in 0.03478 seconds
