Re: Relation between plugin activation and enabling/disabling Eclipse Feature [message #108016 is a reply to message #107944] |
Sun, 13 April 2008 20:22 |
Originally posted by: manahan.NOSPAM.ca.ibm.com
org.eclipse.update.configurator is listed in the config.ini as a startup
bundle. This bundle determines which bundles (aka plugins) contributed
by Update Manager (i.e via features, sites, extension directories etc)
should be passed to the runtime. Each feature contains an explicit list
of bundles. The features that are active are read and the list of the
bundles they contain passed to the runtime. Features which are inactive
do not have their bundles passed to the runtime.
So in the case you describe Feature 1.0 is active and therefore eclipse
knows about Plugin 1.0 and doesn't know about Plugin 2.0 so it loads
1.0. Plugin 2.0 was basically filtered out.
So while features don't define how the eclipse runtime loads bundles
they can define which bundles the eclipse runtime knows about.
P2 may change all this since it will replace update manager eventually.
-Peter
abhi wrote:
> Hi All,
> What is the impact of enabling/disabling an Eclipse Feature version (through Help-->Software Updates-->Manage Configuration) on activation/deactivation/installation of plugins referenced by such a Feature?
> e.g. Feature F1 version 1.0.0 references Plugin P1 version 1.0.0 and Feature F1 version 2.0.0 references Plugin P1 version 2.0.0. If F1 version 2.0.0 is disabled, F1 version 1.0.0 enabled, and a class from Plugin P1 is loaded, this class is loaded from P1 version 1.0.0.
> How is it that plugin versions referenced by a Feature version that is disabled are not considered when plugin activation takes place?
> Any pointers in understanding this would be most appreciated.
> TIA,
> Kind Regards,
> -abhi
FUDForum. Page generated in 0.02085 seconds
