Home » Eclipse Projects » BIRT » How can I retrieve data?
How can I retrieve data? [message #848123] Wed, 18 April 2012 00:35 Go to next message
Colin  is currently offline Colin Friend
I have a database table that contains the names of other, dynamically
created, database tables. I can retrieve that data and from it compose a
query. I tried to use the composed query in a subreport table, but cannot
see how to pass it to the beforeopen of the dataset. The subreport example
shows how to pass a parameter of a where clause, but I need to pass the
whole query. How can that be done?
Colin
Re: How can I retrieve data? [message #849123 is a reply to message #848123] Wed, 18 April 2012 22:40 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Does the query change, change the column definitions? Ie are you just
changing the table name and not the column names and column types in the
sub report?
Jason
Re: How can I retrieve data? [message #849589 is a reply to message #849123] Thu, 19 April 2012 09:15 Go to previous messageGo to next message
I retrieve one column, converting it to a string in the query and renaming
it to one name using sql 'as'
> changing the table name and not the column names and column types in the sub report?
> Jason
Colin Sutton
Re: How can I retrieve data? [message #850436 is a reply to message #849589] Fri, 20 April 2012 03:17 Go to previous messageGo to next message
Colin,
Look at the attached example and give it a try. It may cache the
dataset defeating your purpose but it may be worth a try. Look at the
outer table oncreate on the detail row and the beforeOpen script on the
inner data set.
Jason
>> Jason
Re: How can I retrieve data? [message #851345 is a reply to message #850436] Fri, 20 April 2012 22:28 Go to previous message
Thanks, Jason, that showed me exactly what I needed..
Colin
> Colin,
> outer table oncreate on the detail row and the beforeOpen script on the inner data set.
> Jason
> renaming it to one name using sql 'as'
> Jason
> example shows how to pass a parameter of a where clause, but I need to
> pass the whole query. How can that be done?
Previous Topic:Dynamically changing the date format on the X axis
Next Topic:Using BIRT with jsf4birt.jar on tomcat server/websphere
Current Time: Sun Dec 05 03:08:26 GMT 2021
Powered by FUDForum. Page generated in 0.01752 seconds
