Report generation failing at excel generation [message #847895] |
Tue, 17 April 2012 19:07 |
anki an Messages: 1 Registered: April 2012 |
hi,
We are using birt 3.7 with native excel emitter.
One particular report is failing when more than 16k records with the following error.
Did any one faced this kind of error?
If so how can I fix it?
2012-04-17 11:30:11,377, INFO [reporting.utility.ExcelDocumentsUtil.generateDocument] : Enter generate excel document
2012-04-17 11:31:01,657, SEVERE [org.eclipse.birt.report.engine.api.impl.RenderTask.render] : Error happened while running the report.java.lang.StackOverflowError
at org.eclipse.birt.report.engine.emitter.xls.BlankData.setHeight(BlankData.java:62)
at org.eclipse.birt.report.engine.emitter.xls.BlankData.setHeight(BlankData.java:61)
at org.eclipse.birt.report.engine.emitter.xls.layout.Page.calculateRowHeight(Page.java:936)
at org.eclipse.birt.report.engine.emitter.xls.layout.ExcelLayoutEngine.complete(ExcelLayoutEngine.java:1005)
at org.eclipse.birt.report.engine.emitter.xls.layout.ExcelLayoutEngine.outputCacheData(ExcelLayoutEngine.java:1023)
at org.eclipse.birt.report.engine.emitter.xls.layout.ExcelLayoutEngine.outputSheet(ExcelLayoutEngine.java:891)
at org.eclipse.birt.report.engine.emitter.xls.layout.ExcelLayoutEngine.endPage(ExcelLayoutEngine.java:187)
at org.eclipse.birt.report.engine.emitter.xls.ExcelEmitter.endPage(ExcelEmitter.java:86)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.endContent(ContentEmitterUtil.java:102)
at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageBuffer.endContainer(DummyPageBuffer.java:60)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.end(HTMLPageLM.java:183)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:98)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.api.impl.RenderTask$PageRangeRender.render(RenderTask.java:661)
at org.eclipse.birt.report.engine.api.impl.RenderTask.render(RenderTask.java:294)
at reporting.utility.ExcelDocumentsUtil.generateDocument(ExcelDocumentsUtil.java:48)
at reporting.manager.ReportGenerator.generateOuputDocuments(ReportGenerator.java:624)
at
reporting.manager.ReportGenerator.runReport(ReportGenerator.java:270)
at reporting.jms.ReportingMDP.onMessage(ReportingMDP.java:45)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:543)
at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:482)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:451)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:323)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:261)
... 4 more
[Updated on: Wed, 18 April 2012 15:28] Report message to a moderator
Re: Report generation failing at excel generation [message #849109 is a reply to message #847895] |
Wed, 18 April 2012 22:22 |
I am not sure but this may be a poi issue
http://stackoverflow.com/questions/2159635/excel-poi-3-5-workbook-java-heap-space-exception
What are jvm parameters set to? Do you get the error using the Tribix
xls emitter.
Jason
On 4/17/2012 3:07 PM, anki an wrote:
> hi,
> following error.
> [com.wellsfargo.reporting.utility.ExcelDocumentsUtil.generateDocument] :
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> com.wellsfargo.reporting.utility.ExcelDocumentsUtil.generateDocument(ExcelDocumentsUtil.java:48)
> at
> com.wellsfargo.reporting.manager.ReportGenerator.generateOuputDocuments(ReportGenerator.java:624)
> at
> com.wellsfargo.reporting.manager.ReportGenerator.runReport(ReportGenerator.java:270)
> at
> com.wellsfargo.reporting.jms.ReportingMDP.onMessage(ReportingMDP.java:45)
> at
> at
> at
> at
> at
> ... 4 more
FUDForum. Page generated in 0.03425 seconds
