Home » Modeling » M2T (model-to-text transformation) » Dynamic parameter for a java method defined in the jet file
Dynamic parameter for a java method defined in the jet file [message #9793] Sun, 01 April 2007 07:17 Go to next message
Originally posted by: thomas.pellegrin.gmail.com
Good morning,
I need some help for JET. I would like to use a method defined in my jet
file and use dynamic parameter when I call it. how can I do that? is it
possible?
eg:
public String getType(String t) {
if (t.compareTo("s")==0){
return "String";
return "To define";
<%= getType( [Dynamic value] ) %>
something like that
<%= getType(<c:get select="$p/@type" />)%> is it possible? or how can I do
something like that?
Thanks in advance,
Thomas
Re: Dynamic parameter for a java method defined in the jet file [message #9976 is a reply to message #9793] Wed, 04 April 2007 12:55 Go to previous message
Paul Elder is currently offline Paul ElderFriend
Thomas
No,
is not valid syntax.
However, the JET context and XPath engine are available to you in Java code.
I'd recommend a class like the following:
import org.eclipse.jet.XPathContextExtender;
public class DoXPath {
public static String get(JET2Context context, String xpath) {
XPathContextExtender xpe =
XPathContextExtender.getInstance(context);
return xpe.resolveAsString(xpe.currentXPathContextObject(), xpath);
Depending on where you place DoXPath, you may have to add a
<%@jet imports="....DoXPath" %>
to your template.
Then, your Java expression becomes:
<%= getType(DoXPath.get(context, "$p/@type")) %>
Paul
"Thomas" <thomas.pellegrin@gmail.com> wrote in message
news:euqaln$hje$1@build.eclipse.org...
> Good morning,
> possible?
> eg:
> return "String";
> return "To define";
> something like that
> Thanks in advance,
> Thomas
Previous Topic:How to get setVariable value back
Next Topic:JET2 - invoking with a different input file.
Current Time: Tue Apr 16 19:16:52 GMT 2024
Powered by FUDForum. Page generated in 2.11954 seconds
