Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Ecore Tools] Search references popup menu
Re: [Ecore Tools] Search references popup menu [message #107798 is a reply to message #107784] |
Tue, 22 January 2008 14:41 |
Cyril Faucher Messages: 63 Registered: July 2009 |
Member |
Ok, Jacques. All these shortcuts are very useful with large and unknown
metamodels.
Another question, maybe it is a "EMF Search" topic, but I think the
search exec is very long (15s) with my metamodel.
Cyril.
Jacques LESCOT a écrit :
> Cyril,
> This action is currently brought by the EMFT Search Component, but that
> is true we need to think of a better/similar way of letting the user
> searching/navigating along the existing EReference related to a given
> EClass. This action and the References View developed as part of the
> Ecore Tools project provide same functionality using two ways.
> Cyril Faucher a écrit :
>> Hi,
>> In the Ecore editor, I have tried to use the search references on an
>> EClass.
>> It seems this ability is available and similar both througth the
>> graphical area and the outline, but the icons are not the same.
>> Regards, Cyril.
Cyril Faucher
IRISA-INRIA - Rennes, France
[Breathe life into your metamodels www.kermeta.org]
Re: [Ecore Tools] Search references popup menu [message #107813 is a reply to message #107798] |
Tue, 22 January 2008 15:06 |
Jacques LESCOT Messages: 247 Registered: July 2009 |
Yes, this is an EMFT Search related question. When you perform the
search request on your large metamodel, did you restricted the Search
scope on the metamodel only ? If your metamodel loads external
Resources, this might be a reason of the slow search process.
> metamodels.
> Cyril.
>> Cyril,
>> that is true we need to think of a better/similar way of letting the
>> user searching/navigating along the existing EReference related to a
>> given EClass. This action and the References View developed as part of
>> the Ecore Tools project provide same functionality using two ways.
>>> Hi,
>>> EClass.
>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #107827 is a reply to message #107813] |
Tue, 22 January 2008 18:33 |
lucas bigeardel Messages: 155 Registered: July 2009 |
did you discriminate your search participants to the sole EClass meta
element ?
If it is the case I would be more than happy grabbing an ecore model
example to find the cause of such slowish execution.
I also maybe have to explore efficiency about EMFT Search model loading
which is a not optimized for large models for the moment.
cheers,
>> unknown metamodels.
>> Cyril.
>>> Cyril,
>>> of the Ecore Tools project provide same functionality using two ways.
>>>> Hi,
>>>> EClass.
>>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #108050 is a reply to message #107827] |
Thu, 24 January 2008 10:53 |
Member |
Hi Lucas,
Comments below.
> element ?
You can download the famous Kermeta metamodel at:
http://gforge.inria.fr/plugins/scmcvs/cvsweb.php/kermeta_pro jects/fr.irisa.triskell.kermeta.model/build/ecore/kermeta_ja va.ecore?cvsroot=kermeta
A detail: this problem has been detected during the search launched by
the EReferences search feature from the Ecore Tools Ecore editor
(right-clic on an EClass) and not directly via the classical Eclipse Search.
I guess this feature discriminates the search participants to the sole
EReference meta-element...
Cyril.
> cheers,
>>> unknown metamodels.
>>> Cyril.
>>>> Cyril,
>>>>> Hi,
>>>>> an EClass.
>>>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614056 is a reply to message #107784] |
Member |
metamodels.
Cyril.
> Cyril,
>> Hi,
>> EClass.
>> Regards, Cyril.
Cyril Faucher
Re: [Ecore Tools] Search references popup menu [message #614057 is a reply to message #107798] |
> metamodels.
> Cyril.
>> Cyril,
>>> Hi,
>>> EClass.
>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614058 is a reply to message #107813] |
element ?
cheers,
>> unknown metamodels.
>> Cyril.
>>> Cyril,
>>>> Hi,
>>>> EClass.
>>>> Regards, Cyril.
Re: [Ecore Tools] Search references popup menu [message #614074 is a reply to message #107827] |
Member |
Hi Lucas,
Comments below.
> element ?
Cyril.
> cheers,
>>> unknown metamodels.
>>> Cyril.
>>>> Cyril,
>>>>> Hi,
>>>>> an EClass.
>>>>> Regards, Cyril.
Current Time: Tue Apr 23 07:03:52 GMT 2024
Powered by FUDForum. Page generated in 0.05000 seconds
