same osgi application in differnt tomcat contexts [message #107769] |
Wed, 09 April 2008 08:24 |
Originally posted by: christian.wiedemann.key-tec.de
i want to use the same osgi equinox application in the same tomcat in
differnt tomcat context. Each customer should get his own application with
differnt configuration.
So the question is. is there allways the same osgi framework in the
background or for each tomcat context an own osgi framework? Or how to deal
with this point?
thanks
Christian
Re: same osgi application in differnt tomcat contexts [message #107823 is a reply to message #107811] |
Wed, 09 April 2008 16:31 |
thanks fort he answer. Yes i use the servlet bridge. how can i access each
equinox framework from console (or somehow else).
"ss" lists all bundles once. an bundle with the same version is just shown
once. So how can i control(start/stop) an bundle in an framework?
thanks a lot
Christian
"Simon Kaegi" <simon_kaegi@ca.ibm.com> schrieb im Newsbeitrag
news:ftinqe$ko7$1@build.eclipse.org...
> Hi Christian,
> If you're using the servletbridge then each webapp gets its own "private"
> instance of Equinox so there is no sharing across frameworks.
> There is early talk at the OSGi association about providing something
> along the lines of application level scoping however nothing concrete yet.
> For now, I'd suggest working with a framework instance per
> customer/context.
> HTH
> -Simon
> "Christian Wiedemann" <christian.wiedemann@key-tec.de> wrote in message
> news:fthug4$nj6$1@build.eclipse.org...
>> Hi,
>> with differnt configuration.
>> deal with this point?
>> thanks
>> Christian
FUDForum. Page generated in 0.03958 seconds
