virgo ide installation failed [message #847385] |
Tue, 17 April 2012 08:49 |
I tried to install 'download.eclipse.org/virgo/milestone/IDE/' on springsource-tool-suite-2.8.1|eclipse-jee-indigo-SR2-win32-x86_64|springsource-tool-suite-2.9.1,but all failed at last.
Installation on offline mode is the same.
could any one help me?
thanks in advance.
Re: virgo ide installation failed [message #848329 is a reply to message #848317] |
Wed, 18 April 2012 05:55 |
Hi,Miles
i used springsource-tool-suite-2.9.1 to install 'virgo tools' following the guide from 'wiki.eclipse.org/Virgo/Tooling#Snapshot'
I could select feature ' Eclipse Virgo Tools 1.0.0.201204170135-SNAPSHOT' only,click button 'Next'.
Response with the following logs,could you help me to check it.
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse Virgo Tools 1.0.0.201204170135-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.0.201204170135-SNAPSHOT)
Missing requirement: Eclipse Virgo IDE (Server Core) 1.0.0.201204170135-SNAPSHOT (org.eclipse.virgo.ide.runtime.core 1.0.0.201204170135-SNAPSHOT) requires 'bundle org.json 0.0.0' but it could not be found
Cannot satisfy dependency:
From: Eclipse Virgo Tools 1.0.0.201204170135-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.0.201204170135-SNAPSHOT)
To: org.eclipse.virgo.ide.runtime.core [1.0.0.201204170135-SNAPSHOT]
Abrams
Re: virgo ide installation failed [message #848779 is a reply to message #848706] |
Wed, 18 April 2012 15:09 |
thanks,lorian
your tips are ususally applied when install on offline-mode.
i try on online-mode,will get the lastest version by default.
this time,'Eclipse Virgo Tools 1.0.0.201204170135-SNAPSHOT' by default.
still failed.
BR,
Abrams
Re: virgo ide installation failed [message #853933 is a reply to message #850339] |
Mon, 23 April 2012 13:34 |
thanks,Miles,
I have just re-tried the lastest version of virgo-tooling with link 'download.eclipse.org/virgo/milestone/tooling/',and select the lastest version of virgo tooling.
The eclipse was also fresh with link 'www.eclipse.org/downloads/download.php?file=/technology/epp/downloads/release/indigo/SR2/eclipse-jee-indigo-SR2-win32-x86_64.zip'.
If you make sure that your eclipse is fresh ,i don't think it could work.
By the way, i have installed it successfully on a other way.
I use a offline package 'eclipse-plugin-VirgoIDE-1.0.0.201106220519-M01.zip' in links way on eclipse 'springsource-tool-suite-2.9.1'.
But i want it to be installed on any platform independently
Re: virgo ide installation failed [message #857498 is a reply to message #854727] |
Thu, 26 April 2012 15:39 |
Miles Parker Messages: 1341 Registered: July 2009 |
Frieder, thanks that's very helpful.
Abrams, I'm not going to follow up on this combination right now unless we have confirmation from someone else that they aren't able to install into Indigo, but please do open a bug with details if you're still having issues.
As a note to everyone, if you do have a specific installation issue, please open up a bug. That way we can ensure that we're tracking these issues transparantly.
[Updated on: Thu, 26 April 2012 15:40] Report message to a moderator
FUDForum. Page generated in 0.05643 seconds
