Re: Birt and JSF [message #848887 is a reply to message #848262] |
Wed, 18 April 2012 17:11   |
I believe the jsf4birt lib is JSF 1.2. Instead of using the tag library
it may be better to just use a backing bean to run the report and return
the output. You could also create your own custom ui component. Do you
want your report output as a single html page? Give some more details
on what you need.
Jason
On 4/18/2012 12:17 AM, Noor ul Huda wrote:
> can u tell how to use tag lib uri in .xhtml JSF page??
Re: Birt and JSF [message #850423 is a reply to message #849338] |
Fri, 20 April 2012 02:56  |
If you have the viewer deployed can you use an iframe?
Jason
On 4/19/2012 12:06 AM, Noor ul Huda wrote:
> actually i want to render birt viewer on .xhtml page??
> is there any possible way to render birt viewer?? any suggestion?
FUDForum. Page generated in 0.01778 seconds
