Home » Archived » BIRT » Birt and JSF
icon1.gif  Birt and JSF [message #847248] Tue, 17 April 2012 06:04 Go to next message
Noor ul Huda is currently offline Noor ul HudaFriend
Can any one help?? how to show birt report viewer on JSF page??
Birt report can rendered by using birt tags on jsf page.
but birt viwer is not show on JSF page
Re: Birt and JSF [message #847717 is a reply to message #847248] Tue, 17 April 2012 15:25 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Have you tried the jsf4birt wrapper?
http://www.birt-exchange.org/org/wiki/index.php?title=Using_BIRT_and_Actuate_with_JavaServer_Faces(JSF)
You may also want to look at the first couple of comments on this post:
http://birtworld.blogspot.com/2007/09/22-birt-tag-library-building-custom.html
Jason
Re: Birt and JSF [message #848262 is a reply to message #847717] Wed, 18 April 2012 04:17 Go to previous messageGo to next message
can u tell how to use tag lib uri in .xhtml JSF page??
Re: Birt and JSF [message #848887 is a reply to message #848262] Wed, 18 April 2012 17:11 Go to previous messageGo to next message
I believe the jsf4birt lib is JSF 1.2. Instead of using the tag library
it may be better to just use a backing bean to run the report and return
the output. You could also create your own custom ui component. Do you
want your report output as a single html page? Give some more details
on what you need.
Jason
Re: Birt and JSF [message #849338 is a reply to message #848887] Thu, 19 April 2012 04:06 Go to previous messageGo to next message
actually i want to render birt viewer on .xhtml page??
is there any possible way to render birt viewer?? any suggestion?
Re: Birt and JSF [message #850423 is a reply to message #849338] Fri, 20 April 2012 02:56 Go to previous message
If you have the viewer deployed can you use an iframe?
Jason
Previous Topic:Using BIRT with jsf4birt.jar on tomcat server/websphere
Next Topic:Setting data using JavaScript on BIRT DE
Current Time: Fri Mar 24 18:36:05 GMT 2023
Powered by FUDForum. Page generated in 0.02112 seconds
